2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Jun 13, 2019 at 10:53 AM
    su.b.rat
    su.b.rat broken truck
    i'm with this guy
    CygnusX191 and Shellshock like this.
  2. Jun 13, 2019 at 10:55 AM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Seriously though... It's about a cheap as "performance" mods can get. The ROI is basically immediate.
    su.b.rat[QUOTED] likes this.
  3. Jun 13, 2019 at 10:58 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I think the hardest part for me is remember to get back under there and look at my weaksauce safety wire. I keep forgetting when the truck is cold.
  4. Jun 13, 2019 at 11:09 AM
    Shellshock
    Iowa
    just add some duct tape and you'll be set
    iexc, MOC221_ and tonered[QUOTED] like this.
  5. Jun 13, 2019 at 11:12 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :rofl::rofl:
    iexc and Shellshock[QUOTED] like this.
  6. Jun 13, 2019 at 3:48 PM
    Tacoma816
    Tacoma816 Microwaving a cantaloupe, you know why
    I-70E KS exit 336 rest stop, 2nd stall
    Fred and Ginger
    custom interior stains
    I'm (in theory) doing my ADM this weekend....
    CygnusX191 and MOC221_ like this.
  7. Jun 13, 2019 at 4:33 PM
    06ltd
    06ltd Well-Known Member
    Maryland
    2019 TRD OR 6MT
  8. Jun 13, 2019 at 4:42 PM
    lapoltba
    CT - 06076
    Yes, I had two different configurations of custom hoses made (about $25 each). It's not worth the effort. There isn't enough room to get the flex hose routed nicely where it wouldn't rub on anything once the shield is back on. They do function, but I wasn't happy with the fit.
    The hard line is super easy to bend and get fit just right. I got the union and line for under $10 locally.
    https://shop.advanceautoparts.com/p...x-12-paj-312/22190031-P?searchTerm=poly+armor
    https://shop.advanceautoparts.com/p...rted-blu-9c/22190058-P?searchTerm=brake+union
    Bleeding isn't bad as long as you clamp off the reservoir hose. I gravity bled mine for about 10 minutes and it only took a few pumps of the clutch pedal by my wife to get normal operation. I just cracked the bleeder wide open with a piece of tubing on it to a catch can and kept the reservoir topped off. I used these to pinch off the line:
  9. Jun 13, 2019 at 6:11 PM
    Toyotafanforlife1991
    Toyotafanforlife1991 Live FREE and drive a TOYOTA!!!
    Brandon
    Dickson, Tennessee
    2016 QS Tacoma DCSB OR M/T, 1970 Toyota Land Cruiser FJ40 351W M/T, 1982 Toyota Hilux SR5 M/T, 1983 Toyota Hilux SR5 M/T (undergoing frame off restoration)
    I second this, I bought my pre cut steel line at advance and just shaped it and it was super easy to do. Biggest pain for me was unbloting the cat bracket and putting back. All said and done took about an hour, and definitely worth it. Just take your time! And I just used some needle nose vice grips to clamp the line, just be careful.
    CygnusX191 and tonered like this.
  10. Jun 13, 2019 at 6:27 PM
    Garab
    Garab Well-Known Member
    2018 TRD Sport MT6 DCSB
    OVtune 2.0 TRD Sema wheels 265/70/17 Falken Wildpeak AT/3 SL ADM BAKflip mx4
    Does he really though?... :rolleyes:
  11. Jun 13, 2019 at 7:22 PM
    Juice33
    Juice33 Well-Known Member
    L.J.
    Mass
    2018 6MT Tacoma TRD Pro
    I feel like my 18 TRD Pro drives pretty well as it sits but this Tune is piquing my interest. I am ordering the ADM. I can't believe how frustrating it a gear change can be when trying to hammer it, makes no sense.
    CygnusX191 likes this.
  12. Jun 14, 2019 at 4:49 AM
    cylon58
    cylon58 Active Member
    Geoff
    East Tennessee
    2018 TRD Pro MT Black
    I promise the 18 Pro will be 1000x better with the tune. You will be able to drive under 3000 RPMs up a slight incline without downshifting. It’s amazing.
  13. Jun 14, 2019 at 8:15 AM
    su.b.rat
    yeah, even with a passenger or two!
    Shellshock, CygnusX191 and tonered like this.
  14. Jun 14, 2019 at 12:12 PM
    Shellshock
    Iowa
    GOD I SHOULD HAVE DONE THIS A LONG TIME AGO. If you haven’t done it, go do it now!
    0uTkAsT, iexc, TD90S and 5 others like this.
  15. Jun 14, 2019 at 12:15 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    So, I take it that you went on your first drive? :cheers:
    :burnrubber:
    iexc likes this.
  16. Jun 14, 2019 at 12:17 PM
    Shellshock
    Iowa
    Sure did. Totally changes things. Amazing how much that POS changes the driving experience.
    iexc and tonered[QUOTED] like this.
  17. Jun 14, 2019 at 12:18 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nothing like designing and installing a $100 part the just makes the experience and wear worse.
    0uTkAsT and Shellshock[QUOTED] like this.
  18. Jun 14, 2019 at 1:51 PM
    Tacoma816
    Fred and Ginger
    How painful was the bleed? I duno why, but it kind of intimidates me.
  19. Jun 14, 2019 at 1:53 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl:
    :canada: Sorry, eh?
    :crapstorm:
    Comb likes this.
  20. Jun 14, 2019 at 1:59 PM
    Shellshock
    Iowa
    Well the first time I did it I had no idea what I was doing and failed miserably. Mostly due to frustration and it was getting cold.
    My method is pump the clutch a bunch, bleed, then repeat more times than necessary.
    Today I only did a couple cycles before I had all the air out of the system.
    I did a write up a while back that’s fairly detailed. Follow this process and you’ll be golden.
    https://www.tacomaworld.com/threads...dm-and-bs-thread.568303/page-41#post-19760830
    0uTkAsT, iexc, nxcess and 4 others like this.
Thread Status:
