2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Sep 17, 2019 at 6:38 PM
    HeyMrCarter
    HeyMrCarter Well-Known Member
    Just wanted to provide some feedback on the 04A71 2.0 Beta 93 Octane file after 75ish miles. (zendesk ticket #10087)
    previous tune 1.05 FOB93
    Pros:
    - Linear power throughout the power band
    - Seems much more responsive
    - Smooth and easy to shift
    Con:
    - Throttle seems very touchy in 1st gear at low RPMs. 1.05 FOB93 had very nice low rpm throttle control (1k-1.5k). I could crawl along very easily in stop and go traffic or when offroading over uneven/loose terrain. I would never break the wheels loose or lurch forward. With 2.0 beta, if i'm crawling along at low rpms and try to give it just a little gas the truck jumps/lurches forward a bit.
    Overall, its a great file and if i could have the low rpm throttle control of the 1.05 FOB file with all the other pros of this file i'd be ecstatic. That said, i will continue to run the beta as the pros definitely outweigh the one con i have so far (which may settle in as i put more miles on it). I remain impressed with the progress of each new file!
    Thanks Mat!
  2. Sep 17, 2019 at 8:23 PM
    Garab
    Garab Well-Known Member
    2018 TRD Sport MT6 DCSB
    OVtune 2.0 TRD Sema wheels 265/70/17 Falken Wildpeak AT/3 SL ADM BAKflip mx4
    Im having trouble figuring out where to get in on this 04a70 2.0 beta action.
    Also what is this i read about converting 04a70 to 71?
  3. Sep 17, 2019 at 8:49 PM
    nxcess
    nxcess Well-Known Member
    '17 Tacoma MT 4x4
    OVTuned
  4. Sep 17, 2019 at 8:55 PM
    basshole
    basshole Well-Known Member
    chicagoland
    2018 OR MT
    Flashed my 2018 to 04A71 before flashing beta2.0 tonight. Drove some usual routes around 15 miles. Impressed so far.
    Most noticeable is how damn smooth the truck shifts. That nagging upper rpm rev hang is nearly gone.
    I will data log and send info to zendesk after 50miles.
    CygnusX191, 2001 4x4 and CorbinDallas like this.
  5. Sep 18, 2019 at 12:55 AM
    Garab
    So is the update from a70 to a71 necessary prior to installing 2.0 when it comes out? If its not needed is it something that i should do?
  6. Sep 18, 2019 at 1:14 AM
    Livinserene
    Livinserene Thejerkyguy
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    I went from 70-71 and that alone made a decent difference,, not only that but 71 seems to get the updates before 70 ,,
  7. Sep 18, 2019 at 2:41 AM
    Garab
    I know, what im asking is if its recommended to update to a71
  8. Sep 18, 2019 at 3:46 AM
    iexc
    iexc WerXED BH2.0 AD
    Kalede
    Toronto
    2023 TRD Sport MT
    Beta2.0 update
    Another 45km and I have noticed :burnrubber::bikewheelie2::burnrubber::bikewheelie2:
    Ticket#10070
    Livinserene, 2001 4x4 and CygnusX191 like this.
  9. Sep 18, 2019 at 6:13 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Hey folks just to let you guys know I am not sure how much of the "rev hang" can be eliminated in very low RPM (under 2000) because this is when the ECU has active idle feedback so that when the RPM falls the ECU doesn't have to catch it and stumble
  10. Sep 18, 2019 at 6:17 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Order 5227 Report 9992
    Got an email about Reg. Nothing was attached. Thanks.
  11. Sep 18, 2019 at 6:19 AM
    OVTune
    OVTune
    Response sent, attachment is at the bottom, sent you a picture where it is
    CorbinDallas and CygnusX191 like this.
  12. Sep 18, 2019 at 6:22 AM
    iexc
    Kalede
    Toronto
    2023 TRD Sport MT
    If you can do 2000rpm ,that would be better than 2700rpm were it is now and also if possible drop the activation from 30kmh to 25 or 20kmh ,the lower the better.
    By the way your KILLING IT:thumbsup:
    Shellshock, MOC221_ and CygnusX191 like this.
  13. Sep 18, 2019 at 6:24 AM
    OVTune
    OVTune
    The 2700 RPM point is the low rpm control point of ACIS actually, not the idle control. I can send you a file that lowers this RPM even further if you want to test. The Caveat is lowering this RPM has a torque reduction effect at very low RPM and full throttle :( (under 2000).
    It's funny that Toyota employs every possible hardware advantage to make power and efficiency and wraps it all together with a poopy tune.
    AKGSD, Shellshock, 4low and 6 others like this.
  14. Sep 18, 2019 at 6:27 AM
    iexc
    Kalede
    Toronto
    2023 TRD Sport MT
    Count me in
    #10070
  15. Sep 18, 2019 at 6:30 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Thank you!
    Got it this time. Maybe my email virus blocker stopped it from being active or something.
    CygnusX191 and tonered like this.
  16. Sep 18, 2019 at 6:41 AM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Yes, this. I don't go full throttle lower than 2k. I would be interested in trying this as well.
  17. Sep 18, 2019 at 7:05 AM
    basshole
    chicagoland
    2018 OR MT
    Has anyone noticed a change in throttle response when the drive train isn't loaded? Example revving in neutral, or to rev match a gear. I was expecting a change, but I assume the pcm can only do so much.
  18. Sep 18, 2019 at 7:07 AM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Did you get your resolved?
    CorbinDallas and tonered like this.
  19. Sep 18, 2019 at 10:09 AM
    CaptainVoodoo
    CaptainVoodoo Well-Known Member
    Charles
    Quebec
    2019 TRD Pro Voodoo Blue M/T
    None yet
    @OVTune I sent you an email last week for my order, I'm just looking for a quick update if you have one! #9206 as always
  20. Sep 18, 2019 at 12:33 PM
    dspec
    dspec Well-Known Member
    In the same boat as you @CaptainVoodoo but my guess is they'll be shipped out end of this week or early next week.
Thread Status:
