2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Aug 9, 2020 at 7:05 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    This...
    Lol
  2. Aug 9, 2020 at 7:25 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :D
    CygnusX191 likes this.
  3. Aug 9, 2020 at 7:25 PM
    Xer0 SiN
    Xer0 SiN Well-Known Member
    Hilo, HI
    19 TRD SPORT TACOMA / 21 LIMITED RAV4
    this and that...
  4. Aug 9, 2020 at 8:21 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    This. Worth it
    Also this. Triple worth it
  5. Aug 10, 2020 at 5:36 AM
    Norsk
    Norsk Well-Known Member
    2024 Underground Gray Tacoma TRDOR Premium
    What’s 2lo?
    CygnusX191[QUOTED] likes this.
  6. Aug 10, 2020 at 5:37 AM
    Norsk
    Can you explain more about these?
  7. Aug 10, 2020 at 5:42 AM
    Karminski
    Karminski Well-Known Member
    Virginia
    2016 Tacoma D/C M/T TRD Off-Road
    Basically Low Gear 2 Wheel Drive. Take a gander here.
    Used to do this via manual locking hubs on my Gen-1. Makes backing and maneuvering a trailer a breeze.
    canyonchaser, tonered and CygnusX191 like this.
  8. Aug 10, 2020 at 5:44 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    ADM: accumulator delete mod. There's a number of ways to either bypass or replace the accumulator in the clutch assembly for the manuals. with it gone you actually get a real feel out of the clutch and more consistent gra b with the clutch when shifting. Makes driving the manual more natural.
    2lo: The reverse gear in these manual trucks is way too high. For some reason Toyota decided that nobody ever needed to use reverse hence the weird ass gearing. The two-wheel drive low-range mod allows you to trick the four-wheel drive ECU into low range without actually engaging your front diff or axle. This allows you to have two-wheel drive while using your transfer case for a low-range doubler in effect, letting you back up with low gears like you should be able to. This is especially useful if you have to move a trailer or back up a hill. Doing all of that in four-wheel low is possible, but sharp steering angles in four-wheel low can put a lot of strain on your CV boots etc.
    VFTuner: what this thread is all about. basically it modifies some of the throttle control maps and fuel control maps and your engine's ECU to allow more linear response. Effectively letting you use more power and torque lower on in the RPM range, it makes the truck more drivable and more fun. Also more functional. There are a few other fun things involved, but that's the gist of it.
  9. Aug 10, 2020 at 5:48 AM
    Shellshock
    Iowa
  10. Aug 10, 2020 at 5:51 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
  11. Aug 10, 2020 at 5:54 AM
    Norsk
    aw man, I want it all.
    I did the clutch restriction delete in my old MK7 GTI, and it feels great! I want to do the same with my Tacoma.
    Junkhead, tonered and Karminski like this.
  12. Aug 10, 2020 at 6:05 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    It's totally worth it in these tacos. The 2lo is badass too.
  13. Aug 10, 2020 at 2:23 PM
    PistolPete412
    PistolPete412 Well-Known Member
    Pete
    Pennsylvania
    2017 TRD Sport MT
    Just fired the 2.0 OL Reg tune on my truck yesterday, and put about 250 miles on it today. Boy oh boy does it feel better. That torque hole around 2500 rpm is gone. Cruising on the highways is easier with less downshifting. Though my right and left foot are a bit out of sync now - I’m not timed for smooth shifts anymore - I gotta relearn a bit myself
    I wish I’d done this a week ago before lugging my camper up and down the mountains of WV - I bet it would have helped!
    thanks to @OVTune for the great product and to @tonered and @lapoltba for their advice
    :burnrubber:
    Junkhead, AKGSD, CygnusX191 and 2 others like this.
  14. Aug 10, 2020 at 2:25 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
    There is always the next trip to enjoy. :D
  15. Aug 10, 2020 at 4:40 PM
    Norsk
    Okay so, do I have to get PC laptop? What specs for the PC laptop do I need to make the OV Tune happen on my Tacoma?
    4x4spiegel likes this.
  16. Aug 10, 2020 at 5:48 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    @Shellshock sez Bootcamp works like a champ.
    Otherwise, any low rent PC will do as long as you are not on the portable version of Windows.
    CygnusX191 and 4x4spiegel like this.
  17. Aug 10, 2020 at 5:49 PM
    Norsk
    Gotcha, I have a MacBook.
    4x4spiegel and tonered[QUOTED] like this.
  18. Aug 10, 2020 at 5:50 PM
    Shellshock
    Iowa
    Sure does :thumbsup: been using it for nearly 3 years
  19. Aug 10, 2020 at 6:09 PM
    Emanresu
    Emanresu Well-Known Member
    Hey Guys. Thanks for your help with this, finally ordered flash cable, tuner software and tune pack! Also, thanks @tonered for the link in your sig to Techstream, however as soon as i download and extracted files got a notification from Macafee that it blocked a virus?..
    tonered and lapoltba like this.
  20. Aug 10, 2020 at 6:24 PM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    I can vouch for the software (not that it means much). I'm pretty sure the files in his signature are the same ones I have in mine. The file gets flagged due to code obfuscation methods used when compiling it.
Thread Status:
