2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Feb 3, 2018 at 7:36 AM
    #1841
    JJ18ORDBSBMT
    JJ18ORDBSBMT Well-Known Member
    1.05 FOB 91 2018 Off road White DC M/T
    Do you have to reflash it? Is that part of the SOP?
  2. Feb 3, 2018 at 7:45 AM
    #1842
    speedtre
    speedtre Well-Known Member
    DirtySouth
    '17 DCLB TRD OR AT 4x4
    Some claim the learning comes back so they reflash... other's say it doesn't...YMMV.
    JJ18ORDBSBMT[QUOTED] likes this.
  3. Feb 3, 2018 at 9:35 AM
    #1843
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    So I kinda lost track of this thread and only checked in once or twice a week for a while. Did I miss something with 1.03? I got 1.03 87 and 91 files back on 11/11/17, but never saw a mention of released A,B, or C versions.
    Boxerocks likes this.
  4. Feb 3, 2018 at 10:53 AM
    #1844
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    Agreed, I don't think I saw anything about a,b,c, versions
  5. Feb 3, 2018 at 10:55 AM
    #1845
    2016trdtacoma
    Trevor
    Utah
    Kind of sucks that it's a YMMV situation..... wonder why it keeps reverting for some and not otheres? But it can only get better as he keeps developing.
  6. Feb 3, 2018 at 11:20 AM
    #1846
    Livinserene
    Livinserene Thejerkyguy
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    Where do I find this !!
  7. Feb 3, 2018 at 11:31 AM
    #1847
    lapoltba
    CT - 06076
    Livinserene[QUOTED] likes this.
  8. Feb 3, 2018 at 11:32 AM
    #1848
    Livinserene
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
  9. Feb 3, 2018 at 11:56 AM
    #1849
    speedtre
    DirtySouth
  10. Feb 3, 2018 at 1:45 PM
    #1850
    speedtre
    DirtySouth
    It could just be people getting used to it (hence my suggestion for a flash back to stock to compare) OR it could be relearning bad habits. Hard to tell because we are talking about human interpretation, not actual data analysis. That's the YMMV part. :)
    2016trdtacoma[QUOTED] likes this.
  11. Feb 3, 2018 at 3:28 PM
    #1851
    speedtre
    DirtySouth
    A, B, and C versions refer to different shift mappings for ATs. You have a MT, so your shift mappings are infinite in number...:thumbsup:
    2016trdtacoma and taco 16 like this.
  12. Feb 3, 2018 at 4:02 PM
    #1852
    lapoltba
    CT - 06076
    Well yeah, but that was posted in this thread thread and he is talking about torque throttling which isn't onlo for the a/t. It is well known that the ecu does torque limiting and i am super curious about what Matt has in store for us
    TeecoTaco, Livinserene and MOC221_ like this.
  13. Feb 3, 2018 at 5:42 PM
    #1853
    JJ18ORDBSBMT
    I can’t get a second mulligan can I? Lol.
    :burnrubber:
  14. Feb 3, 2018 at 6:11 PM
    #1854
    JJ18ORDBSBMT
    :boink:
    Ruggybuggy likes this.
  15. Feb 3, 2018 at 7:56 PM
    #1855
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    So I have a question about flashing the ECU. When you open the flash program can you write to the ecu without reading? I have been running the 87 octane tune and I want to return to the stock tune for comparison reasons. I read the ecu and it gives you a copy of the file to save. I'm assuming this is the 87 octane file that I installed but the file name is not the same as what was flashed. Is this the 87 octane tune that has been renamed? When I open the flash software can I not just flash the the new tune (or stock tune) and not bother with the read? If I do read first what are you suppose to do with the copy of the tune?
  16. Feb 3, 2018 at 7:58 PM
    #1856
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    No need to read, just hit identify and then write the ECU file you sent Mat when you first read
    MOC221_ and speedtre like this.
  17. Feb 3, 2018 at 8:16 PM
    #1857
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    If you do read, why is the name of the file not indicated what it is, 87tune, 91 or stock? It asks you to save it but the name is different and it's easy to confuse with the original stock tune. If you do read your 87 octane tune and you save it, is it a copy of it even though the name is different?
  18. Feb 3, 2018 at 9:28 PM
    #1858
    nxcess
    nxcess Well-Known Member
    '17 Tacoma MT 4x4
    OVTuned
    From a software standpoint, it is PCM-Flash naming convention. You have the option to rename the file however you want so long as you keep the ".bin" extension. Rename your stock tune to stock.bin to make it easier to find in the future.
    MOC221_ and Ruggybuggy[QUOTED] like this.
  19. Feb 4, 2018 at 3:18 AM
    #1859
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I just created separate folders on my desktop for the original stock calibration, and then one for each OV release received from Mat. You can also create subfolders for 87/91.. whatever u want. There's no real need to read again once you pull that initial file and send it to Mat, and hence no more confusion over file names (the OEM one should be the only one with a non_descript file name). Any time you want to re-flash with an OV file just use the ones you get from Mat - they do have descriptive file names as you know. In other words, you're complicating the process more than u need to :)
    Ruggybuggy[QUOTED] likes this.
  20. Feb 4, 2018 at 7:03 AM
    #1860
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    So if you do take a read of the 87 octane tune is the saved read file a copy of the original 87 octane tune?
    MOC221_[QUOTED] likes this.
Thread Status:
