2016+ Toyota Tacoma OVTUNE 1.05 - Tune Development thread
Discussion in '3rd Gen. Tacomas (2016+)' started by OVTune, Jun 9, 2017.
  1. May 22, 2020 at 6:13 PM
    MacFly
    MacFly Well-Known Member
    2018 Cement Tacoma TRD Off Road AT
    OVTune, AT Habitat, Firestone RRs, ARB CKMA12 compressor
    The orange adapter that you plug into the port on your truck with a cable to flash is not a dongle, the dongles were a software key stored on a USB stick that you plugged into your computer to authorize the program to work.
    BlkTaco47 likes this.
  2. May 22, 2020 at 6:14 PM
    Tacohumper13
    Tacohumper13 IG @_.mfa_
    Menifee
    2017 TRD Off-road DCSB 4x4
    6112/5160s w/ camburg UCAs 265/70/17 wildpeaks JP8 conversion kit
    Got em!
    ihatemytruck likes this.
  3. May 22, 2020 at 6:14 PM
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    Good to know, I had not read that. Easy to miss in here. What version did it start do show up on the MTs?
    I am sure Matt will figure it out and fix it for all of us. I will change back to earlier beta once I have 200 mile on it. There is something wrong with this tune and wont continue to run a tune that has this kind of startup issue. If it was improving that would be one thing but it is not. It is actually taking longer to start. If you shut it off and restart within 15 minutes or less it doesn't do it.
    tonered likes this.
  4. May 22, 2020 at 6:16 PM
    lapoltba
    lapoltba Well-Known Member
    '17 Sport, ACLB, V6,MT, 04B13 OV-Tuned
    I cant say for sure which tune I was on when I noticed it. I was on one of the 2.0 test tunes for quite a long time (loved it) and I think it was present there.
    tonered and ihatemytruck like this.
  5. May 22, 2020 at 6:18 PM
    MacFly
    Just got told over the phone by the dealership today that there's a recall on my vehicle, but they don't have a fix for it :bananadead:
  6. May 22, 2020 at 6:20 PM
    lapoltba
    If it's just a ECM update, do it yourself...
    Shellshock and MacFly like this.
  7. May 22, 2020 at 6:25 PM
    Inferno__Taco
    Inferno__Taco Well-Known Member
    Georgia
    2016 DCSB 4x4 TRD Sport
    @OVTune any updated ETA for those of us still waiting on P5FLASH registration after mailing in our license dongles last month?
    Thank you.
  8. May 22, 2020 at 6:26 PM
    MacFly
    I forget what she called it, but it was the stall out or limp or whatever at high speed, she said they don't have a fix for it yet. Being not terribly vehicle savvy, I just found it funny that they'd tell me that there's a recall about a potentially dangerous condition, but that they don't have a fix lol The stupid thing hasn't killed me yet, so I'm not worried for now.
    lapoltba likes this.
  9. May 22, 2020 at 6:34 PM
    Glenn_R
    Glenn
    @OVTune will the speed limiter be removed or set higher for the 34-36 5.29 2.0F tune? Or will we be able to adjust it in vF ourselves?
  10. May 22, 2020 at 6:45 PM
    Shellshock
    Shellshock Guy who drives a lot
    Iowa
    2017 DCSB TRD OR MT QUICKSAND
    It’s probably the fuel pump recall they still don’t have a fix for
  11. May 22, 2020 at 7:21 PM
    thelifeaquatic
    thelifeaquatic Well-Known Member
    2018 TRD OR DCSB
    Definitely the case.
    Tacoma driver:
    And if the vehicle shuts down and goes into limp mode at highway speeds??
    Toyota corporate:
    You might die, but it’s cool, we sent this recall notice letting you know that we know.
    And also, operating as designed.
    SC4333, paleh0rse, chittyrox and 3 others like this.
  12. May 22, 2020 at 7:22 PM
    crunchytaco13
    crunchytaco13 Well-Known Member
    ‘17 PRO MT Cement
    TRD CAT
    I envy your problem
    tonered likes this.
  13. May 22, 2020 at 7:32 PM
    tonered
    tonered tacorider
    tony
    Lynnwood, WA
    What problem?
    The MTs don't have the start up issue.
    You did a great deed. I am sure that you will get taken care of and tuned.
    I unlocked 04B14 on vF in anticipation.
    Hang tight!
    :cheers:
    Shellshock likes this.
  14. May 22, 2020 at 7:33 PM
    tonered
    tonered tacorider
    tony
    Lynnwood, WA
    No problem!
  15. May 22, 2020 at 7:37 PM
    2017TRDpro
    2017TRDpro Well-Known Member
    2017 TRD Pro
    Toyota is currently doing a high pressure fuel pump part recovery campaign. My friend who is a master tech at Toyota dealership told me about it. They have to check your VIN to make sure you qualify.
    Bring truck in, answer simple questionnaire, tech replace HP fuel pump (took him 45 minutes). In return, Toyota gave me $100 gift card. And I got a brand new HP fuel pump.
    The campaign is any vehicle with 3.5L engine, so Camary, Highlander, Sienna, etc. Call your service advisor if interested. My truck is 2017 with 44k miles, own it since new with original fuel pump.
    SC4333, CO_Taco125, sorevilo and 4 others like this.
  16. May 22, 2020 at 7:37 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    04B14 is 99.95 percent Identical to 04B13
  17. May 22, 2020 at 7:54 PM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    I have the CEL on the M/T 2.0 91 dump tube SFOB file. CEL is on at all times,trac light and check engine light on with O2 sensor codes. Only noticeable on 2 low as far as I can tell,truck runs and drives fine otherwise. I tried to put it in 2 lo and got an error message and it would not go in 2 low. I don't recall what the message was and I have not tried to use 2 low since then.
  18. May 22, 2020 at 7:57 PM
    Doogle
    Doogle Well-Known Member
    Jonathan
    2017 Black Tacoma Dbl Cab
    Hesitation doesn’t bother me as I dig the 91 gearlock... If You Like It You Lick It. Everybody Knows That.
  19. May 22, 2020 at 8:08 PM
    MacFly
    Great, something else to worry about, in addition to the limp and the brake master cylinder recall I just found out about... That first sticker I put on the truck sure is appropriate lol
  20. May 22, 2020 at 8:10 PM
    MacFly
    So *that's* where the rash on my tongue came from....
    TS7xTaco, dingel5 and Doogle like this.
