2020 SR5 Headlight Upgrade
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ORMarine, Aug 31, 2020.
  1. Aug 31, 2020 at 11:23 AM
    ORMarine
    ORMarine [OP] Well-Known Member
    Thank you in advance for any suggestions you can offer.
    I have a new SR5 4X4 with the
    Projector-beam-headlights with turn Daytime Running Lights (DRL) and integrated fog lights. I would like to upgrade these bulbs to get better light coverage, both in width and distance. I really don't want to do a LED conversion if I don't have to but would appreciate suggestions given what others have done to achieve better results.
    Thanks again
  2. Aug 31, 2020 at 11:23 AM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
  3. Aug 31, 2020 at 11:31 AM
    El Duderino
    Jeremy
    HI->PNW
    All the lighting upgrade info is in that thread
  4. Aug 31, 2020 at 11:43 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Additionally, the hylux hid kit works great, and I've never been high beamed for throwing out excessive light. Cost me around 70ish for the kit and I'm using the same bulbs for the last 3 years.
    https://www.tacomaworld.com/threads/hyluxtek-hid-kit-with-cnlight-ball-bulbs.457461/
  5. Aug 31, 2020 at 11:52 AM
    Kairide
    Kairide Well-Known Member
    2020 White SR5
    I would just throw in some Amazon LEDs and call it a day. Just kidding!!
    The thread mentioned above by @crashnburn80 has all the lighting info you will need. I'm also weighing options to improve my SR5 lighting. I'm between the Morimoto XBs or doing a retro with the M LED 2.0.
    ORMarine[OP] likes this.
  6. Aug 31, 2020 at 2:26 PM
    Scott4032
    Scott4032 Well-Known Member
    Michael
    2020 SR5 4x2 V6
    coming soon!
  7. Aug 31, 2020 at 4:08 PM
    avi8or_co
    avi8or_co Well-Known Member
    2019 Cavalry Blue TRD Sport, 2023 Lexus IS500
    Did you put those Hella H11s in the lows? You know you can put those same 2.0 H9s in the lows and get quite an improvement over most any H11. Just slightly trim the bulb mount tabs and trim out the plastic tab in the plug so the H11 plug will fit it.
  8. Aug 31, 2020 at 4:33 PM
    Scott4032
    Michael
    2020 SR5 4x2 V6
    coming soon!
    H9 bulbs in the lows causes bad glare for oncoming drivers. Done it, got tired of being brighted. The yellows go in place of the H16 fogs, have to remove a tab with a pair of needle nosed pliers for them to fit. These Hella 2.0 H11's are brighter that the factory Hi beam H9's, but without the glare. The Hella H9's blow the original H9's out of the water, at least twice as bright. I prefer the halogen bulbs cause I see more than with LED. LED's can seem bright, but you missing a lot of detail vs Halogens.
