2020 TACOMA WONT SHIFT OUT OF 3RD
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bulletproofmafia, May 4, 2021.
  1. May 4, 2021 at 1:05 PM
    #41
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    CC works in S4 -S6.
  2. May 4, 2021 at 1:05 PM
    #42
    StayinStock
    StayinStock Pepsi > Coke
    Bob
    Missouri
    Yes I do
    Some
    Best of luck.
  3. May 4, 2021 at 1:08 PM
    #43
    Vlady
    Issy, WA
    If they call you back, ask them why it won't upshift from 4th at speeds above 65
  4. May 4, 2021 at 1:10 PM
    #44
    angerbot
    angerbot Well-Known Member
    Bulletproofmafia[OP] likes this.
  5. May 4, 2021 at 1:18 PM
    #45
    Bulletproofmafia
    Bulletproofmafia [OP] Well-Known Member
    Shane
    2020 Tacoma trd off-road 4x4 voodoo blue
    at first i thought it was gearing, but every time the dealer did an update to the computer it would resolve this issue for about 500 miles, so it really made me re think gearing problems
  6. May 4, 2021 at 1:20 PM
    #46
    angerbot
    Well a regear won't make it worse and if it doesn't solve it at least you have new gears when they finally do get it fixed.
  7. May 4, 2021 at 1:21 PM
    #47
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    The reason is because the ECU learning allows for the ECU to "learn" that this rpm is most efficient for the conditions you are driving. That is why the issue resolves for 500 miles after a reset only to come back.
    Your truck is operating exactly as designed by the Engineers at Toyota, and the flaws are in the ECU code.
    If you want to wade into the weeds of vF Tuner, this flaw can be fixed by modifying the 17 different transmission torque tables that control when the truck shifts.
  8. May 4, 2021 at 1:25 PM
    #48
    Bulletproofmafia
    Shane
    if thats what must be done thats what i shall do thank you.
  9. May 4, 2021 at 1:33 PM
    #49
    Vlady
    Issy, WA
    Been there, done it.. ain't working on any available versions of tunes since October 2020. I bet yours is not working either. If you downshift to 4th somewhere between 70-80 mph, you will be stuck in 4th even you hit a level ground.
  10. May 4, 2021 at 1:36 PM
    #50
    dunlap837
    2018QSDCLBSR5
    Incorrect. My truck will reliably and repeatably upshift from 4th to 5th at any speed, even travelling uphill. I accomplished this by tuning the transmission torque tables to my liking.
    Junkhead likes this.
  11. May 4, 2021 at 1:36 PM
    #51
    Bulletproofmafia
    Shane
    yeah thats my problem right now, its stuck in gear for miles on flat land and down hill....
  12. May 4, 2021 at 1:37 PM
    #52
    Bulletproofmafia
    Shane
    i would need this done for me as I am not savvy with tuning or creating tunes
  13. May 4, 2021 at 1:39 PM
    #53
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    First shot, try the unedited tune. You might be surprised.
  14. May 4, 2021 at 1:44 PM
    #54
    Bulletproofmafia
    Shane
    perfect, I will try that, tonered are you able to hook me up with everything i need? and in the case i need the tune edited are you also able to get that done for me?
  15. May 4, 2021 at 1:49 PM
    #55
    dunlap837
    2018QSDCLBSR5
    You can expect to see a big improvement from the unedited base tune. Although those tunes do still allow for some level of learning, you may find you do not need any further custom editing. If you do, there are forum members offering tuning services who may do something custom for you.
  16. May 4, 2021 at 1:49 PM
    #56
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Depends on if you're local to him or not.
    Junkhead and tonered like this.
  17. May 4, 2021 at 1:55 PM
    #57
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    lemon law that bad boy
    Skydvrr likes this.
  18. May 4, 2021 at 1:56 PM
    #58
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I'm just a forum monkey. @OVTune is the man.
    I do not share edited tunes.
  19. May 4, 2021 at 2:03 PM
    #59
    Vlady
    Issy, WA
    Great, care to share the values from one of those tables?
  20. May 4, 2021 at 2:03 PM
    #60
    Bulletproofmafia
    Shane
    I tried lemon law but i got turned down by 5 lawyers because of the modifications they said my battle is between me and dealer for them advertising the truck with mods and not with toyota corp cause in the lagality of corp no where does it approve said mods
