2022 Tundra Redesign
Discussion in 'Tundras' started by RedWings44, Oct 14, 2020.
  1. Aug 10, 2021 at 4:51 AM
    #221
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Offset pusher fan on the condenser. Note the lack of recovery hooks on this TRD Pro model, though there appear to be threaded holes on the crossmember:
    Aluminum spindles. Wheel bearing bolts have been flipped with the head on the inside. Wonder if the nub on the outer tie rod is another steering stop?
    4-link rear axle officially revealed. Note the fully boxed frame and little shin guard in front of the shock resi:
    Note March spy shots show an electronic parking brake built into the rear calipers:
  2. Aug 10, 2021 at 8:26 PM
    #222
    kucifer
    kucifer Member
    Same. Love my Taco but... jaysus the gearing.
    Bannerman[QUOTED] and DJB1 like this.
  3. Aug 10, 2021 at 8:36 PM
    #223
    Bishop84
    Bishop84 Well-Known Member
    Gas tank on the right? Pan hard bar is reverse of Prado so its all new. Looks like a narrow frame.
  4. Aug 11, 2021 at 4:39 PM
    #224
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Yeah interesting because the official photo of the white truck from the front three-quarters view had both the tailpipe and the fuel filler door on the left. It may be a charge port. Recall the earlier engine cover teaser showed orange cables in the background.
    https://twitter.com/Toyota/status/1406016659844997123
    Frame looks as wide as current-gen, but curves inward just before the rear axle for the shock mounts.
    enforcertaco91 likes this.
  5. Aug 11, 2021 at 4:41 PM
    #225
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Vertical LED light-tube tail lights. TFL says they light up sequentially:
  6. Aug 11, 2021 at 4:50 PM
    #226
    RealLeisure
    RealLeisure Well-Known Member
    Ray
    01 DCSB 4WD V6
    I don't understand the trend of late to update the face of a vehicle and call it an update like making the grilles as large as possible and changing the headlights every other year. Am I the only one seeing this?
  7. Aug 11, 2021 at 4:58 PM
    #227
    RealLeisure
    Ray
    01 DCSB 4WD V6
    Also it seems to me newer vehicles, trucks most noticeably, are getting lower to the ground.. Stock trucks and SUVs are what, 12-16 inches from the ground? because they have that low skirt/plastic fender around it. Then Manufacturers are creating new echelons of models where we have to pay an additional $5-10k for reasonable ground clearance.. I have 2 first gen tacos and to the eye they sit much higher than these newer trucks... just a thought.
  8. Aug 11, 2021 at 5:04 PM
    #228
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    The Tundra always sat low. Press photo from 14 years ago:
  9. Aug 11, 2021 at 5:07 PM
    #229
    RealLeisure
    Ray
    01 DCSB 4WD V6
    Interesting.. is there a reason why they sit so low? Better yet, is there any reason why additional ground clearance wouldn't be preferable to less? Besides maybe aerodynamics..
  10. Aug 11, 2021 at 5:08 PM
    #230
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Have you seen the MSRP on the F-150 Tremor? 70k+ I think that's what the Raptor used to list for.
  11. Aug 11, 2021 at 5:10 PM
    #231
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Off-roading probably wasn't one of Toyota's priorities when designing the full-size truck, as evidenced by the absence of a rear locker. Lower cab floor means more legroom.
    Barsoom likes this.
  12. Aug 11, 2021 at 5:15 PM
    #232
    RealLeisure
    Ray
    01 DCSB 4WD V6
    Wouldn't that be another niche model though? It's kind of like the srunner. Maybe my real thoughts are that the stock trucks ought to be a tad higher than they are now.
    Another valid point..
  13. Aug 11, 2021 at 5:17 PM
    #233
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    Ground clearance on the Tundra has always been higher than the Tacoma. I think first gen Tacomas were listed at like 10", Tundra 2nd and 3rd gen are 10 1/2".
    My coworker drives a 02 Tacoma 4x4, parks behind me almost daily, its considerable lower than my Tundra, seat height, hood line, all of it.
    The front bumpers and rear bumpers do hang lower on the Tundra giving it the illusion its lower I guess, but ground clearance is measured from the lowest part of the vehicle, I guess rear diff housings in our case. I owned a 3rd gen Taco for a while, again the frame is higher on the Tundra. Its difficult to lift with my jack even.
  14. Aug 11, 2021 at 5:17 PM
    #234
    bigoldbeef
    bigoldbeef Well-Known Member
    18 DCSB OR MT, 22 DCSB OR AUTO
    So is this 3.5L essentially the tacoma engine with added OEM boost? Any details if it is different bore/stroke?
  15. Aug 11, 2021 at 5:22 PM
    #235
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    UGLY Truck !!
  16. Aug 11, 2021 at 5:25 PM
    #236
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Engine specs haven't been announced for the Tundra. If it's shared with the new foreign FJ300-series Land Cruiser, then it's the V35A 3.4L turbo shared with the Lexus LS500. It's different from the 2GR.
    Earlier released photo shows it's a V6 judging by the rib count on the plastic engine cover. Orange cables indicate hybrid. The electric assist will probably negate any need for low-end torque optimization from the engine.
  17. Aug 11, 2021 at 5:37 PM
    #237
    Abject4x4
    Abject4x4 Just another idiot on the internet
    Marcus
    White SR5 Access Cab
    tundra classic should be a first gen Tundra.
    I’d pay $60k for 1st gen tundra fresh out of the factory with a couple small updates.
    First gen tundras and 9th gen f-150s are the best looking trucks ever sold in the US, in my opinion.
    batacoma[QUOTED] and RealLeisure like this.
  18. Aug 11, 2021 at 6:10 PM
    #238
    batacoma
    batacoma Truck Wars
    Tremor looks like another trim level for the F-150.
  19. Aug 12, 2021 at 8:55 AM
    #239
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    I would love a new T100.
  20. Aug 22, 2021 at 10:40 AM
    #240
    enforcertaco91
    enforcertaco91 Well-Known Member
    West is best !
    2024 Tundra Terra (terror) Pro
    PPF Front grill, bumpers and headlights.
