2H 4H 4L switch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BigRedWeather, Nov 25, 2010.
  1. Nov 25, 2010 at 5:18 AM
    BigRedWeather
    BigRedWeather [OP] Member
    How reliable is the switch that controls 2H 4H 4L. I had that on a Jeep Cherokee 25 years ago, and it rarely got into 4x4 drive. I would much prefer a manual stick to shift. Your experience
    I am probably going to buy a 2008 Certified Tacoma V6.
    Is there a web site that tells you what kind of differential you have based on the VIN?
  2. Nov 25, 2010 at 5:36 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    I had no issues with the Tacoma, however in past vehicles i had more issues with the actuator than the knob itself.
  3. Nov 25, 2010 at 7:44 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    No manuall 4x4 on Tacoma unless you swap transfer case with some other Toyota vehicle.
    Knob works but needs to be exercised once a month to be lubricated. I only had problem day after I bought the truck and first few times I tried engaging 4x4. Now has been working with out any problems.
  4. Nov 25, 2010 at 8:05 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Had mine 6 years as of next week, and no problems whatsoever with it or the actuator. And it gets used a lot in the winter and regularly in the summer.
    You should be able to tell what type of rear diff is on the '08 based on the model or by looking under the rear of the truck at the back of the diff. TRD Off-Road will have a locker, TRD Sport will have a LSD, and some SR5's depending on the SR5 package will have LSD. For the LSD, simply look at the back of the rear diff and there'll be a white sticker with red letters saying LSD Oil Only. Link to the picture is in my sig below.
  5. Nov 25, 2010 at 8:12 AM
    NorthwestRC
    NorthwestRC Well-Known Member
    Rachelle
    Prince Rupert, BC, Canada
    11' TRD Sport MGM
    Dealer installed 3"lift/levelling kit,side-step bars,window visors,D-rings in box,
    granted i have only had my truck for a week but the switch has worked well...no issues....was hwy driving and pulling a trailer, so up the steeper hills would switch into 4H for better traction on the compact snow...worked wonderful and could maintain the same speed to do so!
  6. Nov 25, 2010 at 10:58 AM
    Eurosport
    Eurosport Well-Known Member
    around the world
    thinking about what happened 25 years ago is not a good comparison about today's switches and mechanisms
  7. Nov 25, 2010 at 8:27 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    I have had now 2 second gen Tacomas (with 4WD dial), over 6 years, over 120,000 miles... zillions of times 4 wheeling, NEVER any problems with them working.
    A mechanical limited slip differential was only available on SPORT TRDs from 2005-2008 (as best I know)... The OFF ROAD TRDs has a locking rear differential (better for off road conditions)... 2009 + have 'traction control' which provided various levels of limited slip using the brake system.. works great!
  8. Nov 26, 2010 at 5:07 PM
    05Moose
    Jim
    And most SR5 packages. It's been said that you could not get a DC LB without a LSD. My SR5 package came with it, and EVERY Xtra Cab SR5 I've seen around here has it too. So now you know better.:D
  9. Nov 26, 2010 at 5:22 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    all second gens have an 8" front diff, reverse 30 spline
    trd offroads have a 8" rear with eaton e-locker
    the rest have 8.4" rearends
  10. Nov 26, 2010 at 10:18 PM
    David K
    It would be more correct to change the several words 'axle' to the word 'differential' in the above post. An axle is the entire drive area from the left wheel to the right wheel, seperated by the differential, which gets its drive force from the driveshaft. A differential is sometimes refered to as a 'pumpkin'.
  11. Nov 26, 2010 at 10:20 PM
    cameronlane
    cameronlane Well-Known Member
    cameron
    Anywhere but there
    2014 Dbl Cab TRD OR 4x4
    mine works great, never had anyprobs with my 08. I've had more probs with my 85 4runner manual shifter.
  12. Nov 26, 2010 at 10:20 PM
    WABOOM
    WABOOM Well-Known Member
    Minnesota yeah sure ya betcha
    2013 F-150 XLT Supercrew 4x4
    debadged
    this^
  13. Nov 26, 2010 at 11:01 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    My 08 refused too engage 4L unless I actually shut the truck off and restarted it and getting it out of 4L was pretty much the same joke.
    I'd try all the usual, back up, go forward, turn wheels, ect ect
    Had the dealer work on it twice and it is better but it still can have it's moments.
    I call it the Plastic Piece of Shit Knob and I hate it
    Wish I had a mechanical system like I had in my past Toyota's, they never failed me.
  14. Nov 26, 2010 at 11:10 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Dumb question maybe , but you are stopped and in neutral when shifting to 4L ?
  15. Nov 26, 2010 at 11:17 PM
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    Lets just say it takes me about 20 minutes to get in and out of 4L
  16. Nov 27, 2010 at 12:17 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    Of course the electronic transfer case will never hold up like the mechanical lever engaged versions.. But, with proper maintenance (using it monthly) it will last a good long time.
  17. Nov 27, 2010 at 7:22 AM
    David K
    If anyone is having that much of a problem, then there is something wrong... It is not that the dial is bad, only your dial is bad.
    Three Tacomas, three with dial or push button transfer case, three with a total of 256,000 miles over 9 years with hundreds of 4WD engagements and NO PROBLEMS.
