2LM PnP - Plug and play 2WD low range for the 3rd gen. Tacoma
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by lapoltba, Jun 15, 2019.
  1. Jun 22, 2025 at 9:32 PM
    #1961
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    At least a dozen parallels with my own journey, so much rings true.
  2. Jul 30, 2025 at 5:12 AM
    #1962
    secher
    secher Well-Known Member
    2015 OR v6 6MT
    CygnusX191 likes this.
  3. Jul 30, 2025 at 5:13 AM
    #1963
    lapoltba
    lapoltba [OP] Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Last I knew there was someone here still making one for the 2nd gen?
    CygnusX191 and NoOne like this.
  4. Jul 30, 2025 at 5:16 AM
    #1964
    secher
    2015 OR v6 6MT
    Unfortunately, they haven't been on in over a year, and the person actually making the modules hasn't been on in somewhat longer than that.
  5. Jul 30, 2025 at 5:17 AM
    #1965
    secher
    2015 OR v6 6MT
    Grant83 hasn’t been on since March 2024.
  6. Aug 3, 2025 at 11:43 AM
    #1966
    mikesfarm
    mikesfarm Well-Known Member
    Florida
    2025 4wd Tacoma SR5 DC
    Is there a version for gen4 sr5 ?
    NoOne and CygnusX191 like this.
  7. Aug 3, 2025 at 12:10 PM
    #1967
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Does it need it?
    NoOne likes this.
  8. Aug 3, 2025 at 12:15 PM
    #1968
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    Shouldn't. They have much more low end torque and a 4.1:1 reverse.
    CygnusX191[QUOTED] likes this.
  9. Aug 3, 2025 at 12:26 PM
    #1969
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Eh, it would think it would still be useful based on how that transmission is in the 3rd gen. They have more low end torque if boost kicks in…but I doubt anyone is getting boost in reverse. The reverse gear is still relatively tall, especially if you’re trying to back something up, especially uphill.
  10. Aug 3, 2025 at 12:27 PM
    #1970
    BLtheP
    Plano, TX
    Nobody makes one yet. I don’t have a 4G but based on the t-case and ADD actuator, it would function pretty much identical to 3G. My problem is since I don’t own one I can’t do any testing, and the connectors I think are needed, I can’t find.
  11. Aug 3, 2025 at 1:22 PM
    #1971
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    That's what I was thinking.
  12. Aug 3, 2025 at 1:30 PM
    #1972
    Mach
    Mach Well-Known Member
    2022 Lunar Rock DCLB TRD Off-Road
    Still useful for slow winding offroading where you are turning a lot so don't want the binding of 4wd but want the control and torque of low range.
    secher, Pyrotech and CygnusX191 like this.
  13. Aug 3, 2025 at 3:39 PM
    #1973
    Pyrotech
    Pyrotech Well-Known Member
    That is the what mine is used for 99.5% of the time I use 2low, steep winding descent where the low range is nice to keep speed down, but no binding of the front wheels when making tight turns. even then making a 3 point turn on a switch back is not rare for the trails we end up on
  14. Aug 3, 2025 at 5:02 PM
    #1974
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    I guess I've been lucky with the heavy off-roading I do. Even when it does get tight There's enough wheel slip that I don't have binding in 4Lo
    Of course I have the harness because a manual 3rd gen is just obnoxious in reverse
    TeecoTaco likes this.
  15. Aug 3, 2025 at 5:28 PM
    #1975
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    It's really not if you're into Dutch reverse racing...cuz if you're not dutch you're not much.
    Think of Radar Love played in reverse.
  16. Aug 5, 2025 at 6:11 AM
    #1976
    secher
    2015 OR v6 6MT
    Yes, in a manual transmission, the 2 wheel has a much higher ratio than the 4Lo. So, particularly when pulling loads up steeps and even moreso when pulling loads via winding steep, and most particularly (which applies to me), when backing up winding steeps with loads... Two wheel low is basically necessary. I am smoking my clutch.
  17. Aug 5, 2025 at 6:12 AM
    #1977
    secher
    2015 OR v6 6MT
    In a manual transmission, the 2 wheel has a much higher ratio than the 4Lo. So, particularly when pulling loads up steeps and even moreso when pulling loads via winding steep, and most particularly (which applies to me), when backing up winding steeps with loads... Two wheel low is basically necessary. I am smoking my clutch.
  18. Aug 5, 2025 at 6:14 AM
    #1978
    secher
    2015 OR v6 6MT
  19. Aug 5, 2025 at 9:14 AM
    #1979
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    For some reason in my head I thought you were in a 4th gen.
  20. Aug 5, 2025 at 11:25 AM
    #1980
    Cetacean Sensation
    PNW
    I'm sure it has some use, but is it necessary? The 2.4 makes a good amount of boost and torque below 1500rpm. Plus, with the 4th gen transmission's lower gearing, you can reverse at parking lot speeds with the clutch fully released.
    I've always just done multi-point turns in that situation. Going down a steep hill on full engine braking on just my rear wheels gives me some bad thoughts about overall vehicle stability.
    Wish I bought one while they were available. I've definitely have occasional issues with stalling the truck in reverse on hills.
    This is really patronizing. I own a manual Tacoma and understand how it works, thanks.
    I just have an opinion, idk. I'll stop being a grandpa.
