2LO Plug & Play Harness Discussion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lapoltba, Feb 7, 2019.
  1. Feb 7, 2019 at 8:14 PM
    Reluctanse
    Reluctanse Granny shiftin, not double clutchin
    Sam
    Newberg, Oregon
    '17 Tacoma DCSB Inferno TRD OR 6MT
    OVTuned, Grabbers, 5100s, Bakflip VP
    1. 100% plug n play, everything included (except switch, see #3)
    2. PCB is G2G
    3. EDIT: I'm good with the linked switch, actually!
    Thank you!!
  2. Feb 7, 2019 at 8:17 PM
    Reluctanse
    Sam
    Newberg, Oregon
    Manual truck (assuming most here are). Not sure how the sunroof guys are, but I have one extra slot in the overhead with all the other 4wd related switches that it would be most awesome to put this switch in.... i realize more work to wire, but that would be 100% ideal, if someone can figure it out. I would, and might, if I get some time.... (lol)....
    rlj251 likes this.
  3. Feb 7, 2019 at 8:37 PM
    Shellshock
    Iowa
    I forgot there was blanks up there. That would be pretty nice to have everything together up there. I’ve got the sunroof, I think there’s a blank next to atrac - id have to go check
  4. Feb 7, 2019 at 9:40 PM
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Plug and play
  5. Feb 7, 2019 at 9:44 PM
    304_Taco
    304_Taco Well-Known Member
    Curtis
    Morgantown, WV
    16 TRD Sport DCSB MT
    Sub'd for price. Extremely interested
  6. Feb 7, 2019 at 9:55 PM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    subbed for price!
  7. Feb 7, 2019 at 9:55 PM
    Marcmtb1
    Marcmtb1 Well-Known Member
    PHX, USA
    2016 Tacoma TRD OR DCSB 4x4
    5100/885 w/ 1/4 lean spacer, Icon RXT w/ B110’s, 255/80/17 FWP, AP Apex Sliders, KDMax 87, ADD W1, BD mirror riser
    Nearly went titanium before my jeweler told me a story of another customer who broke his ring finger with one...4 fire departments later, they found a jaws of life strong enough to cut it off. LOL
    Shellshock likes this.
  8. Feb 7, 2019 at 10:17 PM
    ian rogers
    ian rogers Well-Known Member
    Ian
    Sf Bay Area
    69 fj40, 2019 OR manual
    Locked Sliders Roll cage H41
    I want in!! Plug and play not required.
    Thanks for the efforts
  9. Feb 7, 2019 at 11:19 PM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    I'm in favor of a complete pnp setup.
    Only place i have room for a switch is below the hvac controls. I could get my own switch or the switch you have listed.
    Would love this setup.
  10. Feb 7, 2019 at 11:24 PM
    MrBrooks
    MrBrooks Well-Known Member
    Midwest
    2018 DCSB - 2021 Rav4
    Interested in PnP
    Marcmtb1 likes this.
  11. Feb 7, 2019 at 11:29 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    Put me down for a plug and play please.
  12. Feb 8, 2019 at 3:47 AM
    lapoltba
    lapoltba [OP] Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Updated the list. Thank you for all the input guys. Looks like this is going to be more popular than I expected which is great!
    It seems like the general consensus is that the aironboard switch is going to be acceptable to most people.
    Is that switch the same size as the one under the HVAC controls? I can leave the wire long and leave the final cutting to length and soldering/crimping to you probably?
    If you PM'ed me I have responded and added you. Please don't use the profile posts as they are very easy to miss.
    tonered likes this.
  13. Feb 8, 2019 at 3:55 AM
    lapoltba
    CT - 06076
    Cute anecdote, but it's not kryptonite. LOL! The cross section of a wedding band would be easily cut with a pair of standard bolt cutters. Next time I visit the facility that does Ti recycling I'll grab a piece of 1/4" bar and test that theory.
  14. Feb 8, 2019 at 5:19 AM
    lapoltba
    CT - 06076
    You are welcome to your opinion, but this is the route I and many others have chosen to take. The fact that you believe adding components (that are consumer grade at best) will make the system simpler and more reliable is curious.
    If you would like to develop your solution you are welcome to do so. It will probably work fine, I just like this method.
    tonered and Shellshock like this.
  15. Feb 8, 2019 at 5:45 AM
    #35
    Accessorides
    Accessorides Well-Known Member
    If you have any problems sourcing the connectors or getting the harnesses made, feel free to reach out!
    tonered and lapoltba[QUOTED][OP] like this.
  16. Feb 8, 2019 at 6:29 AM
    #36
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    I’m on the list twice.
    1)True plug and play
    2) No need to design a new board the industrial LEGO already exists.
    KNACRO DC 12V 2-Channel Relay Moudle High/Low level Trigger Optocoupler isolation (DC 12V) https://www.amazon.com/dp/B077Z7RB7L/ref=cm_sw_r_cp_api_i_JczxCbEDWEB1T
    3) I’m good with the switch you have chosen. Center lower panel is where I would put this switch anyway.
  17. Feb 8, 2019 at 6:40 AM
    #37
    OrangeToy
    OrangeToy Member
    Knoxville, TN
    2018TRD-OR-DCSB
    Subbed for price
  18. Feb 8, 2019 at 6:43 AM
    #38
    nevadabugle
    Elko, NV
    You may want to edit this post and remove the discussion with the poster who's posts have been deleted. It is confusing now without the context.
  19. Feb 8, 2019 at 6:50 AM
    #39
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Hilarious... although then you will have to delete your post. Then I will have to delete my post...
    Ah what the hell. Deletes for everyone.
    10
    9
    8
    7
    (Sorry OP)
    nevadabugle[QUOTED] and tonered like this.
  20. Feb 8, 2019 at 6:50 AM
    #40
    lapoltba
    CT - 06076
    I personally prefer to leave them in for context and a reminder not to interact with certain people.
