2nd Gen DIY Big Brake KIt -OEM parts- Part #'s provided (INSTALLED)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by craigFLA, Jul 31, 2016.
  1. Jan 21, 2023 at 3:22 PM
    #441
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    running a 17in kmc wheel, wonder if i should get it set up for a 16in wheel think my spare is a 16
  2. Jan 21, 2023 at 3:25 PM
    #442
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
    False. If you read the very first post it says this:
    13WH calipers match 338mm OD (13.30 inch dia) and 28mm thick rotors and accept the 231mm pads (this is from 2003-2009 Lexus GX470 and select 2003-2009 4runner)
    338mm rotors need a 17" wheel. I can confirm this because I originally had 16's and it definitely needs 17's to clear.
    Just get a 17" for your spare and you're good to go.
  3. Jan 21, 2023 at 3:28 PM
    #443
    BigCountry762x39
    TL
    PNW, Oregon!
    also, what i was thinking, need to find a set of used FJ steels or something
    wi_taco[QUOTED] likes this.
  4. Jan 21, 2023 at 6:49 PM
    #444
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    2010 to 14 4Runner
  5. Jan 21, 2023 at 8:00 PM
    #445
    wi_taco
    Adam
    Yes, but also no. This particular BBK thread is about using the 13WH calipers. Punching in for a 2010-2014 4Runner you will get a 14WA caliper that is slightly different (+3mm larger piston, overall larger caliper). Using those newer 14WA calipers you should also use the matching rotor because they are thicker. Different backing plates too. Lots of small but important differences. But that's in a different thread, not this one.
    So yes they will work but this is a different thread about the 13WH setup. Anyone wanting the 13WH setup should go back to post #1 in this thread and match years 2003-2009 Lexus GX470 and select 2003-2009 4runner
    AR15xAR10 and Texoma[QUOTED] like this.
  6. Jan 22, 2023 at 4:57 AM
    #446
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    What would be the better brake kit? The 13WH or the 14WA? Seems like the 14WA is the better one.
  7. Jan 22, 2023 at 5:12 AM
    #447
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    I’m debating go this or just saving up my pennies for a BBK kit.
  8. Jan 22, 2023 at 7:27 AM
    #448
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    The larger piston uses more fluid. If you have a vacuum break booster you will notice you have to push the peddle farther.
    Then you can upgrade to a tundra master for more fluid and pressure. While doing that increase the rear wheel cylinders to take more fluid and slows them to take more of the breaking load.
    the 13wh calipers being the same amount of piston all your getting is a larger rotor that can take more heat before it warps
    wi_taco likes this.
  9. Jan 22, 2023 at 9:16 AM
    #449
    wi_taco
    Adam
    Bingo. And if you have an OffRoad with the electronic assisted booster, the 13WH setup is maybe the safer option because we can’t upgrade boosters.
  10. Jul 27, 2023 at 7:08 AM
    #450
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
  11. Sep 13, 2023 at 10:52 PM
    #451
    super g
    super g Well-Known Member
    garrett
    north carolina
    09 trd off road with high hopes
    Afe stage 2 cai pro dry s, magna flow exhaust
    @crashnburn80 's post is using the OE size calipers and rotors... it works well in my opinion as I've been using the same combo sine I found that post some 5 or 6 years ago, but this thread is basically a mid brake kit( vs big brake kit) as you're using larger size calipers capable of more clamping force and larger/thicker rotors capable of withstanding higher temps( more spirited braking) all while using factory parts, sensors and backing/dust shields to keep brake disks cool. So after having read this I'm for sure ready to toss my cryo centric slotted Rotors and trd pads for 14 t4r brake components to and perhaps some upgraded Rotors and pads.
  12. Oct 15, 2023 at 4:16 AM
    #452
    super g
    garrett
    north carolina
    I know this is from a while back, but do you still have this truck? Or did you have any issues with this set up? I've got an '09 trdor with the electronic brake master like yours vs the vacuum booster type and I was wondering if you had any issues with that system and having larger pistons in the calipers requiring more fluid. Wish there were a way to make this work with the 4 runner rear disc conversion vs needing the sequoia booster.
  13. Oct 16, 2023 at 10:27 AM
    #453
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Yes, I still have the truck. Works fine with the rear 4runner setup. I can't confirm, but I recall the 4runner and Tacoma use similar masters. With the 4runner fronts, there was some softness, but not too bad. The heavier the truck got it did, the less effective it naturally would be. Just make sure you bleed them well and use good pads.
    My brake path has been:
    • Stock Tacoma Setup
    • 5th Gen T4R Calipers w/ Slotted Stoptech, stock rear drums (I was going to put in TRD pads and DBA 4000 T3 rotors but swapped them before doing so) I ran this with stock pads (Tacoma and T4R use the same pads)
    • Willwood Aero-6 T4R caliper w/ slotted stoptech
    • Willwood Aero-6 T4R calipers w/ Stoptech ST40 rear and slotted rotors (Rear Disc Conversion with BBK)
    • [current setup] Stoptech ST60 - (Tacoma piston size) w/ 2 piece Stoptech Slotted rotors and Stoptech ST40 rear and slotted rotors (Rear Disc Conversion with BBK)
    Overall T4R was a great truck that got heavier. RR Racing has calipers that work with the T4R stock setup. Since it's not easy to upgrade the master, I decided to try Tacoma spec—no issues with Willwood. The mixed Willwood/stoptech was nice, but I got some nice deals, 15-20% off the Stoptech setups, and had picked up the rear conversion off a member a while back. More info is in the other thread on the 5th gen setup in 1st post or my signature.
  14. Nov 15, 2023 at 8:50 AM
    #454
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    Ive got the front ST60 kit on my FJC now (electric assist) and I noticed no difference in braking vs OEM calipers in respect to the master.
    I just got sick and tired of replacing seized OEM-style calipers every so often.
  15. Nov 15, 2023 at 8:52 AM
    #455
    nudavinci64
    Robert
    I switched out from OEM > T4R > Wilwood Aero6 and now have Stoptech ST60 kit as well and agree I do not notice any difference in terms of feel to the Master. Did you go with the SOS kit?
  16. Nov 15, 2023 at 8:56 AM
    #456
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    Yeah...the smaller 323mm one to fit my 16s
    I do wish I had "bitier" pads (but not race pads of course)...these Stoptech street pads, while better than the Powerstops I had in OEM form, just seem like they are leaving some of these calipers abilities on the table.
    May be my 255 mud tires too...not a lot of rubber on the road. I should be putting on some 285 winters this week or next and can finally test that theory.
  17. Nov 15, 2023 at 9:44 AM
    #457
    nudavinci64
    Robert
    I would agree. I had the willwood aero-6 with the BP-20 and swapped to the BP-10 pads. These were more aggressive and had a great bite. I have Hawk Street pads on the front but looking at another pad with more bite. The Hawk are similar to the stoptech sport but supposed to have more bite.
  18. Nov 16, 2023 at 9:16 PM
    #458
    lbhsbz
    lbhsbz Well-Known Member
    I've got some pads you should try...way more bite than the StopTech street pads. I sent you a PM.
  19. Nov 23, 2023 at 11:31 PM
    #459
    08BajaBoy
    08BajaBoy Well-Known Member
    Brian
    Southern Cal
    08 Rugged Trail PreRunner
    AFE Pro Dry S air filter, Magnaflow muffler, FabTech DirtLogic UCA, FabTech 2.5 remote resi (front) and 2.25 remote resi (rear)
    Why not share with the group @lbhsbz?
  20. Nov 24, 2023 at 6:46 AM
    #460
    lbhsbz
    Because a TRD BBK and a StopTech kit sourced through SOS Performance may use different pads. I'd rather communicate before purchase because I try to avoid dealing with returns. The SOS kits are not Stoptech kits....they sourced some component from Stoptech but assembled the kit as their own....we could not sell a kit for the applications that we made TRD kits for due to a non-compete, and I'm not sure how they've configured the calipers. The standard ST-60 uses a D1247 pad, which is a shape used only in aftermarket/race calipers (AP, Alcon also use this shape). When we make ST-60 kits for OE contracts (Salleen, maybe Roush, TRD)..we used different abutment clips such that they would accept an D756 pad shape, which is an off the shelf pad for a Ford Truck. It should be noted that the ford pad requires a minor modification in most cases for use in an ST-60 caliper...there are 2 lugs on the back of the back that retain/locate the shim. These need to be removed with a grinder/cold chisel so that the backing plate is flat, otherwise the lugs will land right smack on top of the 2 pistons as the only area of contact between the pad and those 2 pistons, which can cause some sideloading of those pistons and accelerated wear of the pistons/bores as well as noise issues.
    We also offer these pads for the OEM calipers.
