2nd Gen Tips, Mods & More
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tcBob, Mar 26, 2008.
  1. Mar 17, 2015 at 8:32 AM
    #341
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    wheel spacers will be dependent on what size tire you want to run after the lift and if you do not get the right backspacing for the wheels.
  2. Mar 17, 2015 at 10:58 AM
    #342
    fatvet
    fatvet Member
    Angelo
    Suffield, CT.
    None yet...
    Is there a thread or link to a list of things to look for when shopping for
    a used 2nd gen Tacoma ?
    I tried searching the site and did not see anything.
    My experience is with my own car, and there are typical things
    you ask a seller when buying a used one. Like did you replace that,
    or fix this, etc... cuz you know the weak spots of a particular
    model vehicle.
    I would like to buy a tacoma if my current DD ever dies/gets totaled
    and want to have a list of things to look for and stay away from.
    Are there any bad years? drive train options to stay away from ?
    Anyway thanx for any advice you all have.
    -ALF out...
  3. Mar 17, 2015 at 11:07 AM
    #343
    la0d0g
    running for the hills
    For crawling not hauling
    Rust. Crawl under that bad boy and look for the cancer.
    And get a 2008 or older if you want less of the nanny electronics.
  4. Mar 17, 2015 at 11:12 AM
    #344
    The_Hodge
    SC
    2005-2008. 09+ started the added gizmos. early 2nd gens have weaker tailgates and possible bad motor mounts too.
    and yes, being in the NE, definitely need to look for rusted frames. most have it happen near the down pipes from the engine.
    Melinda likes this.
  5. Mar 17, 2015 at 11:14 AM
    #345
    la0d0g
    Technically I'm correct then...
    Fixed :D
  6. Mar 22, 2015 at 5:31 PM
    #346
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    Finally someone else that did what I've done! seems like were the only ones that think 20's are cool here in the forums, but i get props and stares at my truck everywhere i go. I put 34" BFG AT KO's on too though, so she looks pretty mean.
  7. Mar 23, 2015 at 4:14 PM
    #347
    Taco Dude
    Taco Dude Active Member
    Corona
    '13 taco
    How 'bout pics so everyone can see how nice 20's look?
  8. Mar 30, 2015 at 3:18 AM
    #348
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    One thing in the rust belt that some have been doing for years, is crawl under once a year and squirt bio degradable motor oil onto the frame or paint suspected areas with wheel bearing grease using a foam brush. There is little you can do to stop rust in NE if you aren't aggressive about treating for it. A lot of new Subarus and 4 wd Toyota trucks are sold in NE, not only because they are so good in snow, but because they need replacement becasue of the rust problem.
  9. Mar 30, 2015 at 1:51 PM
    #349
    fatvet
    fatvet Member
    Angelo
    Suffield, CT.
    None yet...
    I know in Ct. they changed the formula of the stuff they spray on the road a few years back. My mech was starting to get brand new cars (less than 1 year old) that needed brake lines replaced due to corrosion....SMH.
    Nothing you can do except move...or deal.
    -ALF out...
  10. Apr 7, 2015 at 5:36 AM
    #350
    TylerTacoma
    TylerTacoma Member
    I have a 2015 4.0L V6 Access Cab Toyota Tacoma. I am trying to get more horsepower/torque and I don't want to go with a super/turbo charger. I am looking to just get new headers mainly.
    1. What are some good headers to go with?
    2. Am I able to just get new headers and keep the stock exhaust, or do I have to replace both?
    3. Will the new headers fit with the stock exhaust good?
  11. Apr 7, 2015 at 8:48 AM
    #351
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    This isn't the right place to present this question. Best bet is to start a separate thread in this same subforum to ask your question as you'll get a lot more viewers and a lot more input. This thread is more for quick tips and pointers and not in-depth conversations.
  12. Apr 11, 2015 at 3:57 PM
    #352
    Madams345
    Madams345 Member
    Mark
    Clermont, FL
    08 PreRunner SR5
    3" Pro Comp lift 33" Toyo m/t 20" Fuel Hostage
    Does anyone know if you can install 4" spindles in conjunction with my 3" pro comp coil spring lift? Will I need any other suspension parts?
  13. Apr 13, 2015 at 8:53 AM
    #353
    DirtyMyrtle
    DirtyMyrtle Active Member
    Jordan
    Myrtle Beach
    12 Pro Comp Taco
    6in Pro Comp es9000 rear shocks Bilstein 5100 adj 37x13.50x22 Toyo M/T 22" Fuel Full Blown Thule MOAB basket Yakima Racks
    Pretty new here to the taco world. Had my truck since 2012 and have come a pretty good ways with it. No I don't off-road anymore due to putting my last truck into a pond haha, so I've built a mall crawler. I'm sure some will hate on it, but I'm the type of person to always respect a build. Leaving you guys some pictures of it's transformation. :cookiemonster:
    Currently:
    6" Pro comp w/es9000 rear shocks
    5100s at .86"
    22" Fuel Full Blowns
    Thule MOAB basket
    Yakima roof bars
    starting on retrofit headlights soon and then it's on to the interior.
    custom center console w/8" JL audio sub. Black neop. seat covers. Double din touch. just have a lot of stuff in mind. I'm 21 and love anything with wheels on it. Hope you guys enjoy.
    Arkie-Marty likes this.
  14. Apr 13, 2015 at 9:18 AM
    #354
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Looks good, Start up a build page man!
  15. Apr 13, 2015 at 10:34 AM
    #355
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Above = get an 08 ;)
  16. Apr 17, 2015 at 4:38 AM
    #356
    Tonka
    Tonka Pro-Darwinism
    Taylor
    America's Basement
    14 DCSB prerunner 04 AC 4x4 TRD OR. '16 DCSB 4x4 TRD OR
    '04 265/70R16 Dueler A/T, Softopper, Bilstein 5100's, Toytec AAL, DIY Satoshi, Midland CB, ARB front. Self fabb'd rear bumper. Smittybilt X20 winch '16 custom car grill, Cooper ST Maxx
    So i failed to get pictures. But i was tired of everything sliding around in the bed of my truck and didnt want to pay for a bed mat. I took my cheap ass down to the local Tractor Supply and picked up approx. 6 ft of 1/4" horse stall mat for about $30. (its 4ft wide and sold by the ft) took it home took some measurements and cut to fit with a 4ft lvl as a straight edge and a razor blade. works great and looks good too.
    http://www.tractorsupply.com/en/sto...t-rolled-rubber-1-4-in-thick-sold-by-the-foot
    Cod Tac Oma likes this.
  17. Apr 20, 2015 at 3:17 PM
    #357
    TacoBella
    TacoBella Well-Known Member
    Tom
    2016 Tacoma (SOLD) leased RTL-E Ridgeline
    AVS Bug Deflector. TruXedo Lo Pro
    I am using a 2" square (or round) piece of soft Foam insulation between the seats to catch french fries and my phone from going into the abyss between the seats and console.
    Arkie-Marty and overhill like this.
  18. Apr 26, 2015 at 6:59 AM
    #358
    Red_Taco33
    Red_Taco33 Well-Known Member
    Upstate New York
    2021 TRD Off-Road MT
  19. May 14, 2015 at 2:06 PM
    #359
    Rudy
    Rudy Member
    2015 Tacoma
    ToyTec 3" adjustable coil-over front lift Front Dif Drop Sway bar Relocation kit. ToyTec 2" AAL Bilstein 5160 shocks in the rear Rear Axel shims
    This helped a lot more than the instructions included on my ToyTec lift. Thanks!
  20. Jun 5, 2015 at 9:06 AM
    #360
    mAtTyG04
    mAtTyG04 Well-Known Member
    Edmonton
    2019 Quick Sand OR
    6112 Front Suspension, Fox 2.0 Rear Shocks, Nitto Ridge Grappler - LT285/75R17 C, Rear Blackout Tacoma Badge, De-badged, Icon Rebound Wheels, TRD Grill Gights, CBI Ditch Light Brackets w/ Baja Design Lights, Husky Liners, JBA UCAs, Geenlane Off-road Sliders, Tacotrooper Decal, DuraBump Rear Bump Stops, Pro-clip USA Phone Mount
