2TR-FE Performance Thread
Discussion in '4 Cylinder' started by BassAckwards, Oct 30, 2019.
  1. Jan 18, 2022 at 6:20 PM
    #1181
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I had it as well, before I re-routed my A/C lines. Held up for all the way until no longer necessary.
  2. Jan 18, 2022 at 7:02 PM
    #1182
    BassAckwards
    BassAckwards [OP] Well-Known Member
    2009 Tacoma AWD Turbo 2TR-FE
    Mine came in the mail today and it definitely feels quality.
    On a different note, i was looking back at your pics of Mike’s setup, and it looks like yall have that line running from the top of the valve cover back to the intake like it was on the URD SC. Would this get routed to a catch can if he had one installed?
  3. Jan 18, 2022 at 7:13 PM
    #1183
    Hayrider
    Hayrider Over the hill & going down fast...
    Hey You…
    Convection Oven AZ
    15 DCSB & X-cab SOLD for more than new‼️ Now 05 & 07
    Reg Cabs, 5 lug, 5 spd, Magnuson & LS Swap, StopTech’s, Yada Yada Yada…
    Pay once and cry once! Plus it will make the truck faster as your wallet is lighter!
    Im beginning to think we purchased a boat and not a Tacoma… :rofl:
    :spending:
    Torspd, 05Taco4x4 and 5 Lug Fury like this.
  4. Jan 19, 2022 at 3:33 AM
    #1184
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    For when that time comes, yes.
  5. Jan 19, 2022 at 5:56 AM
    #1185
    Bizquick
    Bizquick Well-Known Member
    Ethan
    Birmingham
    5 lug 2.7 AC 5spd
    Hey y’all, this is a little off topic from the current discussion. Is it possible to do head work(ported, performance valve train kit, cams) without going turbo? I’m trying to preserve NA status as to keep some of the reliability
  6. Jan 19, 2022 at 5:59 AM
    #1186
    BassAckwards
    I dont see why not. You should reach out to LCEngineering and see what they can do for you. I have been thinking about having them port/rework my old cyl head
    Bizquick[QUOTED] likes this.
  7. Jan 19, 2022 at 6:12 AM
    #1187
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yes
  8. Jan 19, 2022 at 6:21 AM
    #1188
    Bizquick
    Ethan
    Birmingham
    5 lug 2.7 AC 5spd
    Ok, thank y’all. @BananaMan had mentioned in a different thread that I would need an external ecu to actual tune the motor and see the benefits of the upgraded valve train? Recommendations? And how would I do that without knowing how to tune?
  9. Jan 19, 2022 at 9:24 AM
    #1189
    WeekendWarrior
    WeekendWarrior Member
    NH
    08 AC 4x4 4Cyl
    That EFR has an integrated blow off valve right? Just wondering why you are running both the integrated BOV and HKS?
  10. Jan 19, 2022 at 9:29 AM
    #1190
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The HKS is currently only being used as a block off. It has no vacuum sources run to it, since that photo.
  11. Jan 19, 2022 at 10:01 AM
    #1191
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    From the owner of the turbo build:
    "It is in full boost at 2k. Tried it on the freeway this morning. I mean 7 psi in 4th gear. 5th gear in useful again as well. It can be used for the passing lane again."
    dirtdigginjoe likes this.
  12. Jan 20, 2022 at 6:55 AM
    #1192
    mason33x
    mason33x Well-Known Member
    Mason
    2009 Tacoma 2.7 regular cab
    k&n filter , cherry bomb muffler , 2/3 drop
    Once I hit 2nd gear in my 09 auto Tacoma it’s just a dud what can I do
  13. Jan 20, 2022 at 7:08 AM
    #1193
    BassAckwards
    Add boost and or regear. Mine will light up the tires in second
    edit: mines a 5 speed, i missed that yours was an auto at first glance. That definitely isnt helping your situation
  14. Jan 20, 2022 at 8:19 AM
    #1194
    Hayrider
    Hey You…
    Convection Oven AZ
  15. Jan 20, 2022 at 9:24 AM
    #1195
    mason33x
    Mason
    I’m thinking of putting 4.11s
    BassAckwards[OP] likes this.
  16. Jan 20, 2022 at 9:26 AM
    #1196
    BassAckwards
    That'd be a solid upgrade. Try to find a 3rd member/carrier in a junk yard out of an 05-15 6lug prerunner/4wd that has the 2.7L 4 banger. They all came with 4.10 gears.
    whatstcp likes this.
  17. Jan 20, 2022 at 10:36 AM
    #1197
    mason33x
    Mason
    Cause I’m not lifted or anything I’m dropped on x runner wheels I just need some more go
  18. Jan 20, 2022 at 10:39 AM
    #1198
    mason33x
    Mason
    So that will go right in even tho it’s 5 lug
  19. Jan 20, 2022 at 11:05 AM
    #1199
    BassAckwards
    Yes, 4.10 diff swaps are a popular upgrade for the Xrunner 5 lug trucks
  20. Jan 20, 2022 at 11:45 AM
    #1200
    Hayrider
    Hey You…
    Convection Oven AZ
    Most likely on the low side depends on rubber size and how much high speed driving. I like this website it’s not perfect but you get a really good idea. I found that the 2nd Gen 2TR Tacoma is over geared about a 150 RPM’s @65 mph.
    I had a 3.31 in a manual 2TR and went from a 26.9” stock tire to a 28.9” tire. Per the link, to go back to a stock gear ratio I should have installed a 3.58. I first tried a 4.10 with the 28.9” tire but the motor was really turning on the freeway at speed. So I swapped another member for a 3.73 and went with a new 28.5” tire, my opinion this is perfect. Sorry I forgot the link!
    https://www.differentials.com/technical-help-2/differential-gear-ratio-calculator/
    Yep plug & play. You should have 3.58 gear now if you have an auto?
    First Gen Tundra, Sequoia, T-100 and some first Gen Tacoma’s came with the 8.4 (actually 8.25”).
    Try also looking for a 3.90 from Toyota. You might have to change the front flange on the carrier/3rd. member. 4.10 from 2.7L from a six lug might be a little low but then again you do have an auto so. ¯\_(ツ)_/¯
    I wonder if anyone makes any performance parts for the trans!
    Now I need to get out to the garage and put the stock muffler back on. I purchased a Magnaflow Overland cat-back for the truck but the 2.7L with the supercharger, header and a single cat this exhaust makes women & children run at anything over 3500 rpm plus but it doesn’t drone one bit!
    It’s Magnaflow No Drone system and the tip dumps right pass the rear spring hanger. I even extended it to the rear bumper with a turn down. But it still screams and I’m to old for this $h!t! Anyone interested in an exhaust system with lass then 200 miles? :frusty:
    I swear I purchased a boat not a Tacoma❗️:anonymous:
