2TR rebuild
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco Nation, Jan 30, 2016.
  1. Jun 10, 2016 at 5:21 PM
    #101
    Taco Nation
    Taco Nation [OP] Well-Known Member
    Zack
    Clinton, MS
    94.5 F350, 77 F150, 74 F100, 11 Jeep Grand Cherokee
    Lift, wheels, tires
    That's what's really tipping me off about the timing
  2. Jun 10, 2016 at 6:30 PM
    #102
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
  3. Jun 11, 2016 at 4:30 AM
    #103
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    That's why I went on to add that it's not building compression. Fuel pump is now working and have fuel flowing through the fuel rail. Also double checked and we do have spark. I think the cams are just not set right in reference to the crank.
  4. Jun 11, 2016 at 10:22 AM
    #104
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If the valves are not fully closed it cannot build compression.
  5. Jun 11, 2016 at 11:02 AM
    #105
    ecoterragaia
    Central Virginia
    Yeah, I'm a dummy, thought we were talking about ignition timing.
  6. Jun 28, 2016 at 9:52 PM
    #106
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    So the timing was set wrong or the chain was wrong. Anyway it ended up bending valves on 1 and 3 and had 0 compression. Replaced those and got a new chain, set everything right and it runs. It's super weak on startup and shows that it's at operating temp even when it's stone cold. Those are the only two issues left to fix. Drove it 30 miles already.
    Torspd likes this.
  7. Jun 29, 2016 at 1:18 PM
    #107
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    So it feels like it has no power trying to take off and is overheating. If it's not one thing it's another with the dang thing.
  8. Jun 29, 2016 at 2:54 PM
    #108
    327
    327 Well-Known Member
    Mark
    Covington, LA
    Former 06 TRD Sport Silver Current 06 Sport 4Runner
    Just read this whole thread. Holy jeez I'm not approaching water in my truck anymore :eek:
  9. Jun 29, 2016 at 3:01 PM
    #109
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    This whole thread is a PSA. Don't be dumb like me. Go wheeling when it's dry.
  10. Jun 29, 2016 at 3:08 PM
    #110
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    Looking back at the beginning, man did I sound dumb. Sure learned a lot through this whole process. Still not out of the woods yet though
  11. Jul 3, 2016 at 7:42 AM
    #111
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    So temperature gauge still doesn't work. It shows operating temp even when it's stone cold. Gotta figure that out. Hopefully I don't have to buy a new sensor because $50 for something so small bothers me. And I am going to look into the cooling issue today. Thinking the radiator could be clogged up from sitting empty for 5 months and rusting up. Will know more when I deside to fool with it.
  12. Jul 3, 2016 at 7:50 AM
    #112
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    Also read operating temp when the coolant was obviously boiling.
  13. Jul 3, 2016 at 10:43 AM
    #113
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Sensor is damaged or the plug. Does the needle drop when the key is moved from the ignition?
  14. Jul 3, 2016 at 4:24 PM
    #114
    Depoxy
    Depoxy Well-Known Member
    SoCal
    2010 Regular Cab 5-speed 4x4
    URD S/S, Eibach pro-truck @ 0.8" lift, hanook 265/75r16 AT
    This thread makes me want a snorkel
  15. Jul 3, 2016 at 4:32 PM
    #115
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    When the key is off it drops to the bottom like normal. Turn the key on even when cold and it shows opporating temp.
  16. Jul 3, 2016 at 4:53 PM
    #116
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    If you unplug the temp sensor, what does the gauge read with the ignition on?
  17. Jul 3, 2016 at 5:04 PM
    #117
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    The sensor is electrical correct? It should be a simple resistance sensor.
    Check the resistance, you should be able to find the correct specs online.
  18. Jul 3, 2016 at 5:04 PM
    #118
    95 taco
    95 taco Battle Born
    Unplug as in disconnect?
    It should stay at the default "0" (all the way down) and possibly throw a CEL.
  19. Jul 3, 2016 at 5:57 PM
    #119
    landphil
    BC, Canada
    Tundra 5.7 mod
    I know what it should read, I'm asking him what it DOES read with the sensor unplugged / disconnected. One does not equal the other.
  20. Jul 3, 2016 at 8:37 PM
    #120
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    I won't have time to mess with it till at least Tuesday so until then I do not know.
