3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Jan 26, 2022 at 7:55 PM
    #3921
    Milor
    Milor Well-Known Member
    shaun
    03 Tacoma sr5 .TrD offroad 5spd..
    supercharged 2" pulley 6 puck clutch
    unstpible likes this.
  2. Jan 26, 2022 at 7:57 PM
    #3922
    Milor
    shaun
    it only wants to be at 180-200 naturally aspirated. I can feel the power difference right before its at full temp
  3. Jan 26, 2022 at 7:59 PM
    #3923
    Milor
    shaun
  4. Jan 26, 2022 at 8:00 PM
    #3924
    1997tacomav6
    Denver
    Yes, I’m going to say thats in the OEM map setup tune for warm up not the temperature making a difference between 160 and 180
    austinmtb and Milor[QUOTED] like this.
  5. Jan 26, 2022 at 8:01 PM
    #3925
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    180 is the idea temp for the metal components internally. Nothing about power. 180 is the temp for most engines period.
    Milor and 1997tacomav6 like this.
  6. Jan 26, 2022 at 8:05 PM
    #3926
    Milor
    shaun
    oof you burst my bubble with that one... thats got to be it.
  7. Feb 3, 2022 at 3:16 PM
    #3927
    yotadude520
    yotadude520 Well-Known Member
    Will
    The Dirty T
    1986 Toyota Land Cruiser
    OME Lift - FJ62 Axles - 33x10.50 BFGs
    I've read a lot of great information between this thread and the rebuild thread. I’m thinking about supercharging my 1998 4Runner, but not looking to build a whole lot of boost. Just want some help getting up some mountain grades.
    From what I’ve gathered there are a few high milers out there that have just slapped on SC’s with no issues. My truck’s got 230k miles on it and runs like a top. I’m going to do a compression test and ensure that all is well before I do anything.
    From what I’ve understand if I just want to run a ‘stock’ supercharger as they’d come from the dealer I need to:
    • Find a SC and all hardware
    • Get a 170 degree thermostat
    • Run Premium through the tank before hand (ideally a few cycles)
    • Different injectors (read that 98’s have smaller fuel spray nozzles – can someone confirm?)
    • Get cold iridium spark plugs
    • AFR gauge or boost gauge (or both)
    I’ve read a few conflicting arguments that the fuel pump and fuel filter needs to be replaced but seems like a few people have just slapped them on regardless. Is that really necessary?
    My truck has a manual transmission, so no need for the zip kit or an external tranny cooler. Prior to installing the SC I will be changing out all the drivetrain fluids and replacing them as well as the valve cover gaskets and what not.
    Last question – for those of you who live in CA or AZ where it gets warmer, is this an issue for the SC’s? I know that they make things run a little hotter so would just like a little more input on that.
    Can’t wait to hopefully slap my SC on, and I appreciate all the info that’s been on these threads. I feel like I have a pretty good grasp as to what is needed.
  8. Feb 3, 2022 at 4:26 PM
    #3928
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    IMO, you also need a way to manage fuel and timing. By default, the ECU has no way of knowing you've added a supercharger and the two will not play nice together without some outside help.
  9. Feb 3, 2022 at 9:51 PM
    #3929
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I live in Scottsdale 300,000+ miles stock injectors, fuel pump is stock but 2 years old. I wouldn't worry about injectors with stock pulley size. A water/meth injection system helps with pinging issues. I also run 1/3 of a can of VP Fuels Ocutane octane booster with every fill up of premium fuel. AFR and boost gauge are a must.
  10. Feb 3, 2022 at 10:02 PM
    #3930
    Milor
    shaun
    I finally got afr wideband installed. what should I be seeing with wide open throttle. driving casually its in the 14s and during WOT it is usually about low 12's to low 13's... It seems way too lean to me
    1997tacomav6 likes this.
  11. Feb 3, 2022 at 10:52 PM
    #3931
    1997tacomav6
    Denver
    WOT=10.5-11-12
    Milor[QUOTED] likes this.
  12. Feb 3, 2022 at 10:58 PM
    #3932
    eon_blue
    Azusa, CA
    I usually see low to mid 11s at WOT
    Milor[QUOTED] and 1997tacomav6 like this.
  13. Feb 3, 2022 at 11:05 PM
    #3933
    1997tacomav6
    Denver
    Haltech you adjust your AFR number in the fuel map section to any number you want and your golden on the entire rpm range,
    Such a game changer system
  14. Feb 4, 2022 at 1:07 PM
    #3934
    mechanicjon
    Jon
    Scottsdale Arizona
    Why did you go with the 2000 model over say a 950?
  15. Feb 4, 2022 at 1:10 PM
    #3935
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    479,999mi
    unstpible and mechanicjon like this.
  16. Feb 4, 2022 at 1:16 PM
    #3936
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I view it as a gentler climb. Load will dictate the swing and ramp rates but 160 gives you more margin... good thing when warming up, bad thing if letting it cool then driving the piss out of it (greater thermal shock)
  17. Feb 4, 2022 at 1:19 PM
    #3937
    mechanicjon
    Jon
    Scottsdale Arizona
    I have the stock 2.7 pulley. (i think that's the size) time to go smaller. Who's got a good one they want to part with?
  18. Feb 4, 2022 at 8:15 PM
    #3938
    1997tacomav6
    Denver
    It has more options and more expandable if I want to add something later down the line.
  19. Feb 4, 2022 at 8:36 PM
    #3939
    Digiratus
    Roaming the PNW
    The RedHead
    IIRC, the options are 750, 1500 and 2000, at least through snp speed. I chose the 2000 for a couple of reasons. First, it was recommended for the 5VZ-FE and it also has the ability, on top of everything else, to control/manage a methanol controller.
    unstpible and 1997tacomav6 like this.
  20. Feb 4, 2022 at 11:32 PM
    #3940
    Milor
    shaun
    so I guess I wasn't pedal to the floor because tonight at wot I saw it hit as low as 11.6
