3" lift w/ 33" tires or 6" lift w/ 35" tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nomaxpi, Jan 28, 2012.
Lift and Tires
Poll closed Feb 27, 2012.
  1. 3" Lift w/ 33" Tires
    232 vote(s)
    74.8%
  2. 6" Lift w/ 35" Tires
    53 vote(s)
    17.1%
  3. Save the money and buy stock in Apple
    25 vote(s)
    8.1%
  1. Jan 28, 2012 at 4:28 PM
    #61
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Seriously though... do a 1" BL 33s on 17s and a 3" lift and you'll be golden.
    18s at max.
    20s and you'll wreck the wheels off road and the ride will suck and the traction will suck and you'll get laughed off any real trails.
  2. Jan 28, 2012 at 4:29 PM
    #62
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    A body lift is not doing it right.
    I dont like your attitude, people are telling you the right answers to your question and you refuse to listen to them, sounds like you already have you mind made up.
    If you really want "extreme" capabilities, 3'' lift with 35s and lockers front and rear. Thats about as capable as it gets. Of course you got to have sliders, skids, bumpers, and other things
  3. Jan 28, 2012 at 4:30 PM
    #63
    nomaxpi
    nomaxpi [OP] Member
  4. Jan 28, 2012 at 4:40 PM
    #64
    jsexton
    jsexton Member
    check out this guys... 6" db modified to 8" with 35's http://www.tacomaworld.com/forum/2nd-gen-builds/147761-white2010taco-super-white-build.html
    Then there is the RCD 4-5" db that works well with 33's http://www.tacomaworld.com/forum/2nd-gen-tacomas/98012-rcd-club-how-many.html
    or you can do the RCD and install 6" icon coilovers and run 35's.. then you get 35 and a little added ground clearance (not sure if anyone has actually done this though)
    or you can do a 3" lift and run 255/80/17 (33.3" x 10") and have no rubbing issues.. http://www.tacomaworld.com/forum/wheels-tires/155849-255-85-r16-owners-experience.html
    if you want to run a 3" and 285/70/17 you are going to have to do some cutting
  5. Jan 28, 2012 at 4:41 PM
    #65
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    Why do you think that the diameter of the wheels has ANYTHING to do with the gears? A 33" inch tire is a 33" tire no matter the diameter of the wheel. And the diameter of the tire (not the wheel) is what will affect your final drive ratio.
    The advice you are getting regarding the size of the wheel has to do with sidewall flex in an offroad situation. This may not matter much in the mud, but certainly will in the rocks, where one would want their tire to flex and conform to the contours of the obstacle. A 33" tire with a 20" wheel will have a substantially shorter sidewall than a 33" tire on a 16" wheel.
  6. Jan 28, 2012 at 4:44 PM
    #66
    DPR921
    DPR921 Well-Known Member
    Dylan
    Cheshire, MA
    08 SR5 4x4 2.7
    People like this ruin perfectly good trucks... PLEASE research some more about lifting for the sake of toyota.
  7. Jan 28, 2012 at 4:48 PM
    #67
    nomaxpi
    nomaxpi [OP] Member
    This is closer to what I was originally wanting to go with (except on 20's). Now that I've seen a pic of 20" wheels on the Taco, it's a little goofy looking with 35's. Since the 6 on 5.5 bolt pattern seems to be less common, the wheel selection is more limited. I can find more 17's than any other size with that pattern. So at the moment, this sounds like the right idea for what I want.
    Thanks
  8. Jan 28, 2012 at 5:02 PM
    #68
    nomaxpi
    nomaxpi [OP] Member
  9. Jan 28, 2012 at 5:09 PM
    #69
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    3" with 35s DUH
  10. Jan 28, 2012 at 5:14 PM
    #70
    nomaxpi
    nomaxpi [OP] Member
    No, i'm going with the 6" lift similar to what white2010taco has ... not the 3".
  11. Jan 28, 2012 at 5:20 PM
    #71
    nomaxpi
    nomaxpi [OP] Member
    Yea, I know it'll be top heavy, so it'll take some getting use to. My 97 wasn't quite as high as my new one will be :thumbsup:
  12. Jan 28, 2012 at 5:21 PM
    #72
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    Lt is not a lift. Lt is a full suspension swap
    so is a sas.
    If you use a 3" body lift for "extreme" offroading you will end up with holes in your cab mounts.
    If you want no rub at all go with 32s on 16s.
  13. Jan 28, 2012 at 5:42 PM
    #73
    nomaxpi
    nomaxpi [OP] Member
    I know the LT is a full swap out. This is what I intend on going with.
    Regarding the BL, I was going for 1" and then add 3" kit. I never intended to lift the body 3" .... as I said in a previous post, that would be just stupid.
  14. Jan 28, 2012 at 6:01 PM
    #74
    Irish020
    Irish020 Well-Known Member
    Phil
    Pennsylvania
    '05 Tacoma TRD Sport 4 Door Longbed
    ARE Hard Tonneau Cover Flowmaster American Thunder Super 50 Series Stainless Dual Exhaust Toytec Ultimate 3" w/ UCA's
  15. Jan 28, 2012 at 6:35 PM
    #75
    NoDrAmA357HK
    NoDrAmA357HK Well-Known Member
    Michael
    North Carolina
    2011 Timberland Mica DBL CAB 4x4 TRD Sport
    3" Pro Comp w/ AAL, 17x9 -6 Offset 4.75 Backspace Pro Comp 7033, LT285/70/17, Xtreme M/T Pro Comp - 67285
    3" with 32.70s (285/70/17)
  16. Jan 28, 2012 at 6:52 PM
    #76
    JstreetS
    JstreetS Well-Known Member
    Jay
    DFW, TX
    09 TRD Sport DCLB
    -6" Procomp -18" Method Race Rims -285/70R18 (34.1x11.5) Toyo MTs -TRD CAT Exhaust -Trifecta Tonneau
    I went with a 6in with 33s if that helps :p. check out build thread for pics!
  17. Jan 28, 2012 at 6:53 PM
    #77
    Konaborne
    Cody
    Kealakekua, Hawaii
    3+1 =/= 6 :)
    take into account what we've told you, and do a little more research. :thumbsup:
  18. Jan 28, 2012 at 6:58 PM
    #78
    tbturner47
    tbturner47 Well-Known Member
    Hickory, NC
    '16 Barcelona Red TRD Off Road
    Lol..
  19. Jan 28, 2012 at 7:52 PM
    #79
    4X42HEL
    4X42HEL Well-Known Member
    San Diego
    2019 DCSB TRD-OR 4x4
    Everybody has their own opinion...
    But I would highly recommend getting a 6" lift with 34's or 35's. You will not regret it. Either way, you are going to want to re-gear (since you want to off-road), so might as well get the truck that looks good too.
    3" lifted tacos with 33's are a dime-a-dozen. Since I lifted my rig 6", I have received nothing but compliments from everybody, including every 3" taco I have come across.
    Yes, I'm making a point here because seems like anybody who doesn't have a 6" kit just bags on them. I guaranty I have just as much, if not more, ground clearance than any 3" kit out there.
    About off-road performance, 10% of that truck, 90% is Driver.
    I called 15+ shops as I was deciding 3" or 6"... and every shop had one consistent thing to tell me about my decision: "Half my 3 inch customers come back wishing they had gone 6", but never has a 6" returned wishing they gone 3".
    /rant
  20. Jan 28, 2012 at 7:54 PM
    #80
    Konaborne
    Cody
    Kealakekua, Hawaii
    Have you measured diff clearance?
