3rd Gen 2016 Tacoma Thud When Coming to Stop - Axle Wrap or?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 49Tacoma, Mar 7, 2016.
  1. Apr 14, 2016 at 4:12 PM
    #61
    mello03
    mello03 Dr. Dirty
    Greensboro, NC
    2020 F250 6.7
    Yeah I just can't believe that none of my other trucks did it. My 04 Tacoma never did it. My Dodge 2500 didn't with 800+ lb/ft of torque. I also had a Titan and a Silverado that didn't either. It makes me wonder if they just don't want to sack up and spend the money to fix it, or they truly don't know the cause.
    Brie and eseckinger like this.
  2. Apr 14, 2016 at 4:52 PM
    #62
    eseckinger
    eseckinger Well-Known Member
    Eric
    2018 TRD Sport
    I've owned them all and none have did this. This is the only one and it only does it when cold so....
    smitty99 likes this.
  3. Apr 14, 2016 at 5:19 PM
    #63
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ^^^ ... I "slightly" get this "thump" sometimes (sounds like a loose shaft bumping forward).
    Only had truck 6 days and maybe 250 miles in burbs driving ... :eek:
    EDIT: 04-15-2016 = Out of maybe 50 stops at lights and red lights & etc. today ... I only had 1 slight thump.
  4. Apr 15, 2016 at 5:21 PM
    #64
    skyking3
    skyking3 Well-Known Member
    Tom
    2016 Silver Tacoma SR5 DCSB
    TRD cai, TRD cat back, JFR y pipe,Wilwood BBK,LEDs, Limited Homelink mirror,debadged,WeatherTechs,Dynamat Extreme sound deadening,sabm second snorkle to fender, Huper Optik ceramic tint, TRD Sema wheels, aerodynamic under body pan, OEM Audio Plus 500Q reference system, Depo faux pro headlights, real pro fog lights, OV tune, OEM aluminum filter housing, Mobtown IFS skid,TRD oil cap,TRD radiator cap, Osram Night Breaker 150 halogen headlamps, Fumoto valve,dashboard blackout,OEM tailgate power lock, MESO steering wheel logo, MESO two color dome light, TRD Pro coilovers, Artec LCA skids, Volk TE37 XT forged wheels, Roadmaster Active Suspension Garmin Minicam, Garmin minicam II
    I have only had my truck for less than 300 miles and have experienced it several times. I thought it might be the transmission since I have read of many posts of trucks being delivered with low transmission fluid. The dealer that I bought it from would not check the transmission before delivery and since I have a warranty they told me it will be covered anyway. This does not take away the pain in the butt from having to go to the dealer for things other than routine maintenance. Hopefully, someone will find a solution since it is detracting from my customer satisfaction.
    Brie likes this.
  5. Apr 15, 2016 at 7:59 PM
    #65
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    I've had my tranny topped and I still get it occasionally. Mine seems to happen when cold and road is wet, but it is not often, maybe 4 times after 1200 miles on my truck. Varying degrees, couple harder, couple just noticeable. Each time on a slight incline, so not sure if that plays into it or not, but yet to feel it on level ground. Never had it on my Gen 2, so gives me a little concern.
  6. Apr 15, 2016 at 9:02 PM
    #66
    viking15
    viking15 Well-Known Member
    Joe
    To sum it all up...first year redesign truck.
  7. Apr 18, 2016 at 9:12 PM
    #67
    49Tacoma
    49Tacoma [OP] Well-Known Member
    2016 Tacoma Limited 4x4
    Mine still does it but not very often at this point. I've learned to really feather the gas pedal when I know I'm coming to a stop and I'm super conscious about coming to a hard stop. Regardless, I generally feel it in the morning when cold.
    Does anyone know if the TSB 4 leaf pack was standard on the 2015's? I know my '16 only has 3 leafs.
  8. Apr 19, 2016 at 3:12 AM
    #68
    mello03
    mello03 Dr. Dirty
    Greensboro, NC
    2020 F250 6.7
    Possible resolution!!! So, I had my DS replaced (which I pushed for) and thought that was the issue. It wasn't. The field rep and shop foreman have been trying to figure this out, and I think they finally did. They ended up drilling a hole in my DS just forward of the slip yoke. The hole is just behind the u-joint, and their theory is that a pocket of air gets trapped when the DS extends and contracts causing a sudden the pressure change. This change basically causes a pop or jolt that can be transferred into the cab at times or just slightly heard. This hole allows air pressure to escape and obviously equalize easily. I have not heard anything since. No thumps, bumps, nothing! Completely silent for 5 days. This was a daily/morning sound for me for 7k miles until now.
    So, I'm slightly concerned of running around with a hole in my DS exposing elements to my slip, but I'm covered if there's a failure. The hole is very small, approx 1/16 drill bit was used. I would have never thought that this could be the potential issue. Keeping fingers crossed they're finally on to a fix. I'll report back in a few days to the field rep so they can run it up the chain.
  9. Apr 19, 2016 at 7:26 AM
    #69
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Cool; kind of old fix though.
    Are you worried about grease getting out or contaminants in?
  10. Apr 19, 2016 at 9:08 AM
    #70
    eseckinger
    Eric
    2018 TRD Sport
    Need to be pressure fitting line Pcv valve.
  11. Apr 19, 2016 at 10:48 AM
    #71
    Dean724
    Dean724 Well-Known Member
    Upland, CA
    That's incorrect. This thud/axle wrap has been an ongoing Toyota issue for years and isn't just limited to Tacomas. T4Rs had it the worst a couple years back.
    Brie likes this.
  12. Apr 19, 2016 at 12:06 PM
    #72
    mello03
    mello03 Dr. Dirty
    Greensboro, NC
    2020 F250 6.7
    Kind of. I mean this is my DD so I don't wheel it. No grease has come out at all and I've driven it 500 miles since. I told them when they did it that I don't mind testing out the theory, but I'm not going to settle for a half assed fix. When they get it figured out and a TSB comes out I'll get it fixed the RIGHT way. The "fix" is in my service history, so even if I move I'm good and covered. They also overfilled my trans by a pint to see if it helped my delay from R to D. We'll see how that goes, but I'm going to push for an extended trans warranty.
    Brie and splitbolt[QUOTED] like this.
  13. Feb 17, 2017 at 11:18 AM
    #73
    Craigs4x4
    Craigs4x4 New Member
    2017 Double Cab LB 4x4
    Been reading all the comment here because I've noticed the same thing on my '17 Sr5 auto. Especially when its cold and I start out but not make it thru 3 gears in the tranny. The "THUD" seems to be coming from the back...like something is rolling around in the bed and bangs into the truck bed. If I didn't know better I'd swear it was my son and his girlfriend in the truck bed rolling around.
    Now this is interesting...try it when you shift manually in the sport mode. I don't seem to have it.
  14. Feb 17, 2017 at 12:01 PM
    #74
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Still digesting information... me thinks there's too much info sharing on this post!
    Son and girlfriend..??
    I thought it sounds more like a basketball rolling around... see a lot less personal without the creep factor...
  15. Oct 9, 2018 at 7:00 PM
    #75
    soggyBottom
    soggyBottom Well-Known Member
    2018 trd pro. Getting the same thing
  16. Dec 12, 2018 at 5:13 PM
    #76
    HolyReptar
    HolyReptar Well-Known Member
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Some Bolt ones here and there
    I’ve had it since I bought my truck. Haven’t been able to repeat it at dealer or with fireman. At 11k now. Just annoying me and still keep taking it in since I live up the street from my dealer. They prob hate me
  17. Jan 21, 2019 at 8:41 PM
    #77
    11Bravo4x4
    11Bravo4x4 Well-Known Member
    Mitchell
    2018 Tacoma off road 4x4 quicksand
    Hello everyone. Just reporting that I also have the thud when coming to a stop usually on random cold mornings. ORDCSB 18 4x4. it really drains my confidence has anybody found a fix?
  18. Jan 22, 2019 at 2:01 AM
    #78
    CAPacificSurfliner
    CAPacificSurfliner Active Member
    William
    Pacific Coast (NorCal & SoCal)
    2017 Cement Tacoma TRD Pro
    Have this too. 2017 Tacoma TRD Pro. Annoying as hell.
  19. Jan 22, 2019 at 2:24 AM
    #79
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    My old tComa had it. My old fj had it. My current tacoma has it. Sporadic thought. It's the nature of the beast
  20. Jan 22, 2019 at 2:59 AM
    #80
    tjpratt
    tjpratt Well-Known Member
    Travis
    Aurora, Colorado
    2016 Limited 4X4 Tacoma
    3.75" Lift / OME OVTuned
