3rd Gen 2016 Tacoma Thud When Coming to Stop - Axle Wrap or?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 49Tacoma, Mar 7, 2016.
  1. Jan 22, 2019 at 4:06 AM
    #81
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    mine only does it when i come to a much more harder stop than normal...if i don't allow enough braking distance, but it doesn't happen all the time...have almost 37k on mine now and sometimes learn to live with it but i have a lifetime warranty in case something happens anyhow...
  2. Jan 22, 2019 at 6:26 AM
    #82
    virginiajim
    virginiajim Well-Known Member
    2016 TRD Sport Automatic
    Mine does it when cold but once you go a few miles it goes away. 57,000 miles on my 16 and the trans fluid level has been checked the correct way and is at the correct level.
  3. Feb 6, 2019 at 6:36 AM
    #83
    maybeme
    maybeme Well-Known Member
    Mine does it quite frequently - and not only when it's cold. I guess I can live with it...UNLESS of course there are long-term ill effects. Anecdotal evidence pertaining to other generations and / or other models isn't really all that convincing in my book....
  4. Feb 7, 2019 at 2:00 AM
    #84
    James_trdpro
    James_trdpro Member
    James
    2018 Black Tacoma TRD Pro
    2018 Tacoma Trd Pro. Exactly the same problem. I took it to the local dealership twice, nobody did anything, very disappointed! It’s my first Toyota.
    CAPacificSurfliner likes this.
  5. Feb 7, 2019 at 3:36 AM
    #85
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    It's the trans down shifting into first coming to a stop. When moving faster and then braking it down shifts faster causing the thud. Feels like you've been in a low speed accident where you were rear ended. Cold is worse, the whole truck shimmies and then to accelerate after there is a 1-2 second delay before it will shift. Toyota says it's normal, basically unless your truck catches on fire everything is a normal operation per Toyota. They may even say the fire, is operating as intended lol
    SandyTaco4x4 and Just1n like this.
  6. Feb 7, 2019 at 4:59 AM
    #86
    tjpratt
    tjpratt Well-Known Member
    Travis
    Aurora, Colorado
    2016 Limited 4X4 Tacoma
    3.75" Lift / OME OVTuned
  7. Feb 7, 2019 at 6:35 AM
    #87
    maybeme
    Yes, OVTune is on my list...but it's certainly not a cheap fix for something that Toyota should handle....:confused:
  8. Feb 7, 2019 at 6:37 AM
    #88
    tjpratt
    Travis
    Aurora, Colorado
    But toyota won't.
    And it "fixes" a LOT more than this thud.
    The truck drives like it should. Buttery smooth and powerful. And better mpg.
  9. Feb 7, 2019 at 6:37 AM
    #89
    4drtaco03
    4drtaco03 Well-Known Member
    BAY AREA
    2003 TRD/ 2004 / 2019 SR5 4x4… now awd sprinter
    My last 3 Tacoma’s have had it, 3rd gen has it just a little. Just get DAKARS ¯\_(ツ)_/¯
  10. Feb 7, 2019 at 6:38 AM
    #90
    tjpratt
    Travis
    Aurora, Colorado
    How do the Dakars fix it? I've had the dakars since way before the tune, and they def didn't make any change with the thud.
  11. Feb 7, 2019 at 6:45 AM
    #91
    4drtaco03
    BAY AREA
    Oh hm, I got new leafs on my older Tacoma and I thought it prevented the axel from tweaking forward when coming to a stop
  12. Feb 7, 2019 at 11:33 AM
    #92
    James_trdpro
    James_trdpro Member
    James
    Hi, thanks for replying. Are you positive this ovtune can fix the issue? I look it up, it’s not a cheap mod, but I may go for it if it saves my future possible transmission problem and has other benefits. Thanks again
    Brie likes this.
  13. Feb 7, 2019 at 3:42 PM
    #93
    tjpratt
    Travis
    Aurora, Colorado
    Yes, i'm positive.
    It fixes the thump, and SO much more.
    But don't believe just me. Go to the thread and read about it for yourself. I know it's long, but I read almost the entire thread before I purchased.
  14. Feb 7, 2019 at 4:49 PM
    #94
    Tacoesh
    Tacoesh Well-Known Member
    Generally get one thump at the first or second stop before getting up to operating temp. Would it be worth going to OVTune for this?
    SCREAMINSAL likes this.
  15. Feb 7, 2019 at 4:52 PM
    #95
    tjpratt
    Travis
    Aurora, Colorado
    I mean, just for that, IMO, not really. But it fixes a lot more than that.
  16. Feb 11, 2019 at 3:26 PM
    #96
    James_trdpro
    James_trdpro Member
    James
    Thank you for your reply. I will read through that thread.
  17. Aug 7, 2019 at 5:00 PM
    #97
    SCREAMINSAL
    SCREAMINSAL Well-Known Member
    This is exactly what happens with mine... 2017 OR 4x4
  18. May 4, 2021 at 8:23 AM
    #98
    canibe
    canibe Member
    2021 Tacoma Sport Double Cab
    2021 Tacoma Double Cab, 6000 km and I have the thud about 1 second after moderately braking to a complete stop.
  19. May 4, 2021 at 8:28 AM
    #99
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That used to be attributed to underfilled ATF. With one of the AT coolers gone the middle of the last MY, underfilling should be less of an issue.
    Still though, it would be good to check the level. The procedure has been posted around here a few times.
  20. May 4, 2021 at 9:22 AM
    #100
    canibe
    canibe Member
    Thanks for that suggestions, I will do that next chance I get. @tonered
    Just did some more testing and I can get it to clunk from coasting (aka neutral) to a dead stop.... So I am starting to think it may be the rear brake shoes. I don't see how the clunk would happen 1second after complete stop and body movement, and be the driveshaft or slip yoke making the noise. Of note, I can get it to clunk from first gear only as well.
    tonered likes this.
