3rd Gen - AC Outlet in Cab and 400w Anytime
Discussion in '3rd Gen. Tacomas (2016-2023)' started by djembefola, Aug 12, 2017.
  1. Apr 15, 2019 at 6:17 AM
    #121
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    Ditto.
  2. Apr 15, 2019 at 7:06 AM
    #122
    JeffB
    JeffB Well-Known Member
    Jeff
    N.E. CT
    2017 TRD Sport
    I'd buy one!
  3. Apr 15, 2019 at 7:20 AM
    #123
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
  4. May 7, 2019 at 3:56 PM
    #124
    Black1Tacoma
    Black1Tacoma #TRUKTOY
    Carlsbad
    2017 Black Tacoma TRD OffRoad 4x4
    Thanks for the great write up! Do you know if there is a way to remove the truck bed outlet from the main battery to an auxiliary battery while making it 400w anytime?
    At that point can I tap into in the bed of the truck and add a 12v and USB?
    Thanks for any insight?
  5. May 7, 2019 at 4:02 PM
    #125
    BigBeej
    BigBeej Well-Known Member
    Bryan
    Vista, Ca
    Another buyer here!
  6. May 7, 2019 at 6:35 PM
    #126
    djembefola
    djembefola [OP] Well-Known Member
    2017 Black TRD OR DCSB
    Backflip MX4 Tonneau Tube Steps Pro Grill Front/Rear camera anytime 110v in Cab 400 W anytime Interior LED Hondo radio knobs Kicker Tweeters JL Audio Stealthbox JL Audio Amp Partially debadged
    Thanks for the kind words, glad you liked it.
    The inverter that runs the factory bed outlet is powered by the main car battery via the factory wiring up under the dash. The wires are tiny and honestly I'm surprised they are able to run even 400w. So what you're talking about would be very difficult and complicated, and I would even be wary about powering the factory inverter with an auxiliary battery. What I would do is buy a better inverter (you could even go higher than 400w if you wanted), and run that off an auxiliary battery to the bed outlet. Then you can also separately run 12v, usb, etc.
    Hope that helps.
    porterx likes this.
  7. May 7, 2019 at 6:47 PM
    #127
    caribe makaira
    Caribbean, Puerto Rico
    400W @ 120v AC = 3.333 amps.
    The wire from the battery to the inverter is 10ish awg
    The inverter fuse is bolted to the box, you'd have to separate the fuse box and unbolt the fuse, then get a fuse holder and run a wire to the fuse box location from the aux battery source.
    It would be somewhat easy, but as stated before, you're better off getting a more powerful inverter...
  8. May 7, 2019 at 7:39 PM
    #128
    Black1Tacoma
    Carlsbad
    Great idea! Thanks
  9. May 7, 2019 at 9:50 PM
    #129
    garner2002
    garner2002 Well-Known Member
    DFW TX
    2018 TRD Pro Cavalry Blue
  10. May 7, 2019 at 11:58 PM
    #130
    Black1Tacoma
    Carlsbad
    Thanks for the info! Just out of curiosity where is the inverter currently installed on the truck?
  11. May 8, 2019 at 12:06 AM
    #131
    caribe makaira
    Underneath the center console...if you shine a light on the vents from the back seats you could see some of it.
  12. May 28, 2019 at 7:27 AM
    #132
    keithd
    keithd New Member
    Keith
    Bailey, CO
    2017 Tacoma Off-Road DCLB
    I’m in for one too if not too late.
  13. May 29, 2019 at 3:21 PM
    #133
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    Does this always stay on at 400 whenever truck is on, or can you press the switch and turn it off when rear outlet not in use?
  14. May 29, 2019 at 3:38 PM
    #134
    caribe makaira
    Switched OFF=OFF... When switched ON, 400 Watts always. Without this mod you get (OEM) 400 Watts initially, then once transmission shifted to drive you get 100 Watts.
    STrooper and ratcityrain[QUOTED] like this.
  15. May 31, 2019 at 8:01 PM
    #135
    Bill Bixby
    Bill Bixby Well-Known Member
    Northern California
    TRD Sport 4x4 DCLB
    Forgive me for my ignorance.... But wouldn't a 400 watt anytime mod be "anytime"? As in we shouldn't have to turn the truck on to run the inverter? Is that even possible? Or would it just drain the battery too quick?
  16. May 31, 2019 at 8:57 PM
    #136
    caribe makaira
    Add- anytime the engine is ON and the switch to the inverter is in the ON position...
    STrooper likes this.
  17. Jun 1, 2019 at 3:29 AM
    #137
    Pyrotech
    Pyrotech Well-Known Member
    That is a not a good idea, due to parasitic loss. It takes electricity to run the inverter even with nothing plugged in.
    Bill Bixby[QUOTED] and tonered like this.
  18. Jun 4, 2019 at 5:25 AM
    #138
    AllGen
    AllGen Active Member
    Shawn
    Texas
    2016 Blue Tacoma Limited 4x4
    Hidden front bumper 32" LED light bar HID headlights Morimoto XB fog lights Pop and Lock for tailgate Metal oil filter housing Bed extender OE bed mat OE bed front rail for sliding hold downs Toyota first aid kit Bed cubby hole block offs Door seal protectors with aluminum inserts OE LED bed light pods and Matt Gecko LED strips OE TRD Pro grill Ceramic tint MESO gasshole and coin holder 1/2" Toytec front shock/strut spacer (leveling kit) 1/2" Toytec rear leaf spring shims with 7.5" u-bolts (leveling kit-IMO) Anytime front and rear camera Shapeway's drivers side cubby switch insert (anytime camera switch location)
    What size hole saw did you use?
  19. Jun 4, 2019 at 5:56 AM
    #139
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    3 1/8” but it has to be specific to the round outlet that you buy
    AllGen[QUOTED] and deebs17 like this.
  20. Jun 4, 2019 at 8:01 AM
    #140
    deebs17
    deebs17 Well-Known Member
    2018 White Tacoma TRD Sport DCLB
    I used a 3” like the instructions said and it was slightly too small and I had to use my Dremel to get it to fit. Also I put it about 1/8-1/4” too high and there was a plastic ridge on the back just under the cup holder that I ended up trimming. I used this grommet:
    Power Grommet with USB,Desktop... https://www.amazon.com/dp/B07F16LH8X?ref=ppx_pop_mob_ap_share
    This thread was great for info. Thanks to everyone who posted and made this possible for a noob!
    Ngneer, se_matt, mtip and 4 others like this.
