3rd Gen. Tacoma Front, Rear Camera, Navigation Bypass, Homelink, Smartphone Mirroring Mod.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hoangde, Jan 31, 2017.
  1. Feb 26, 2017 at 3:58 PM
    memoag12
    memoag12 New Member
    2017 Tacoma TRD sport
    Do I need diodes for the mod to work? Hoangde doesnt mention any diodes.
    Also if I do this what happen when I switch to reverse and the toogle switch is in the front camera position will it display the front instead the rear camera?
  2. Feb 26, 2017 at 4:32 PM
    Abec23
    Abec23 Well-Known Member
    East Los Angeles
    2016 black Tacoma TRD Sport 4X4
    With this method you need diodes. When you switch to reverse with the front camera on nothing happen you still gone see the front camera til you switch back to off. With this method only one switch needed. Thats why I like it.
  3. Mar 8, 2017 at 5:00 AM
    TditoTRDOR?
    TditoTRDOR? Well-Known Member
    Is there a 24pin jumper wiring harness available? I'd rather not tap into the stock wiring- I already purchased a 28 pin jumper, but don't know if there is a 24 pin jumper being sold...
  4. Mar 8, 2017 at 8:57 AM
    Hoangde
    Hoangde [OP] Well-Known Member
    You can order directly from China for 24 pin adapter cable (custom build) but the company required a minimum of 100 pieces.
    A total cost (included s/h) breakout to be ~$4.00/piece.
    Then from there you can resale in eBay and Amazon to recoup your cost and get a good profit.
  5. Mar 8, 2017 at 8:59 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Sounds like a job for @jshsltr methinks... :)
    jshsltr likes this.
  6. Mar 8, 2017 at 10:22 AM
    Hoangde
    jshsltr likes this.
  7. Mar 14, 2017 at 1:30 PM
    Arkie-Marty
    Arkie-Marty I'm not a real DIY expert, I just play one on TW.
    Marty
    Searcy, Arkansas
    2017 4x4 Sport DCSB, Magnetic Gray
    MODS COMPLETED IN MY TACOMA CAREER (2015 & 2017): WeatherTech Floor Mats, Chrome Nerf Bars, Under Hood LED Lights, Glove Box LED Lights, Cup Holder LED Lights, Center Console LED Lights, LED Bed Lights, Dual USB Port Console Install, 12v Power Outlet in Bed, 12v Power Outlet Under Hood, Gentex 177 Rearview Mirror w/Temp & Compass, @ImMrYo's Rearview Mirror Relocation Bracket Mod, Disable Lock/Unlock Beeps Mod, Under Door Projector/Puddle Lights, Behind Rear Seat Storage LED Lights.
    So, is the "near future" here yet? :D I've been trying to figure out what you're referring to....but I give up! :confused:
  8. Mar 14, 2017 at 1:38 PM
    Logan.spencer
    Logan.spencer Well-Known Member
    Logan
    Southern VT
    '18 TRD OR DCSB Cement Manual
    2018 TRD OR DCSB 6 Speed MT Magnaflow Catback CBI T3 Front bumper RCI Skids (front, trans, t-case) RCI Rear Bumper (custom swivel recovery points) Rocky Road SuperSliders ARE Overland cap with area lighting Rigid SRQ backup lights Rigid DSS ditch lights Baja Designes 20" single row Baja Designs squadron sport fogs Icon Stage 9 SwitchPros power system ...i may be forgetting something...
  9. Mar 18, 2017 at 11:03 AM
    Arkie-Marty
    Marty
    Searcy, Arkansas
    I need clarification on this part of the schematic. Define VCC please, would this be power coming from an accessory fuse in the interior fuse panel?
    Also I'm not sure about 1 S1 2, what is that symbol. I googled but couldn't find it.
  10. Mar 18, 2017 at 11:36 AM
    Korndog1284
    Korndog1284 Well-Known Member
    J03l
    Washington
    2016 Off Road DCLB MGM
    All-Pro Raack Pack, Tepui Tent and Awning, ARB BP-51, K02 275/65/17, 4Runner Pro Wheels
  11. Mar 18, 2017 at 11:51 AM
    gorram
    gorram Well-Known Member
    2016 Limited
    VCC on a schematic is referring to V for Voltage, the next letters such as CC refer to collector off of a transistor for example. There are other letters such as EE, DD, SS etc you may see in more complex schematics like a motherboard.
    S1 is just telling you that is switch one of the diagram or cirucuit. If there were other switches they would be s2, s3...
    Arkie-Marty[QUOTED] likes this.
  12. Mar 18, 2017 at 11:51 AM
    ExplorHer
    ExplorHer Question Authority
    Near Pittsburgh
    2016 4cyl, 5MT, 4x4, 2 seats, dents, & rust
    Looks to me like VCC is the wire that indicates the vehicles speed.
    And S1 looks to be a normally open switch. You would have to push the switch to close it.
    Late as usual...
  13. Mar 18, 2017 at 11:59 AM
    Arkie-Marty
    Marty
    Searcy, Arkansas
    I think I figured it out: The symbol is a push button switch, in my case it'll be the OEM looking "CAMERA" switch that'll be mounted in the dash, left of steering wheel. @Hoangde please correct me if I'm wrong.
  14. Mar 20, 2017 at 9:35 AM
    Hoangde
    upload_2017-3-20_9-31-45.jpgHere is the detail of S1 switch.
    1./ Green wire (1) is connect to 12 vdc Accessory power.
    2./ Red1 wire (2) is connect to relay (Pin 85 and 87) and Front Camera (+12 vdc) per schematic.
    Arkie-Marty likes this.
  15. Mar 21, 2017 at 5:15 PM
    #35
    Arkie-Marty
    Marty
    Searcy, Arkansas
    Ok @Hoangde one more question: Where did you mount your relay?
  16. Mar 24, 2017 at 9:47 PM
    #36
    Hoangde
    Zip tie behind steering wheel.
  17. Mar 24, 2017 at 11:07 PM
    #37
    Arkie-Marty
    Marty
    Searcy, Arkansas
    Ok, one more question again......:boink:
    In your schematic below I have highlighted a line in red. Is this an actual power wire running from the switch (85 wire) to the 87 wire?
  18. Mar 24, 2017 at 11:24 PM
    #38
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    Front camera? Why? I have a wife.
    Beerpayzdabillz likes this.
  19. Mar 24, 2017 at 11:39 PM
    #39
    Dudeman86
    Dudeman86 Well-Known Member
    Scottsdale, AZ
    2016 Black DCLB OR
    I saw @Hoangde setup in person. Very nice and awesome to see the creativity of the TW community.
  20. Mar 25, 2017 at 8:26 AM
    #40
    Arkie-Marty
    Marty
    Searcy, Arkansas
    Still need help with this. I've got everything hooked up except this one thing and my front camera isn't coming on. I'm at a standstill and don't want to reinstall the radio and dash panels until this is finished.
