3rd Gen Tacoma HAI's Cable Assy. for Front/Rear Camera Anytime, Navigation Override, Smartphone Mirr
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Hoangde, Jul 18, 2017.
  1. Feb 22, 2018 at 6:29 AM
    #381
    PNWTacoma
    PNWTacoma Well-Known Member
    Paul
    PDX 3rd party OV Tuner
    2025 TRD Pro | Mudbath // 2017 Offroad DCLB OG
    PNW Adventures & PNW Tuning
    Thanks @Hoangde for the solutions. I really want to do #1. Where are you located? Will PM you for more details.
    Another question I have: is it possible to put the front camera on the rear anytime switch and toggle between front and rear? Could this be an option to keep the music (FM/XM) on at the same time?
    Thank you,
    Paul
  2. Feb 22, 2018 at 6:55 AM
    #382
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    I have been reading a number of these threads and believe that is possible. I was planning to contact OP about just such a harness as I'd like to do exactly that, by using a DPDT switch (figure I'll need custom screen print to show FRONT/REAR. I believe if it is done correctly, you can have the anytime camera (with selection) as well as normal reverse action. I have delayed my request, because I haven't decided if I really care about the anytime NAV or the extra AUX connections.
  3. Feb 22, 2018 at 7:34 AM
    #383
    PNWTacoma
    Paul
    Thanks for your input. Yeah, I also read something about tapping into pin 24 or 28 for this. I don't mind soldering into the correct wire, but need a schematic to ensure I get the correct wire. As for me, I'm with you; no need for anything else, however, I've found that the front camera is a blessing when off-roading. Cresting those hills and making tight turns are a breeze with the front camera...and this is coming from a dual cab, long bed owner...
    tonered likes this.
  4. Feb 22, 2018 at 8:00 AM
    #384
    Hoangde
    Hoangde [OP] Well-Known Member
    My schematic is posted in TW. Search for my post...Once you located that post, Option 1 in page 1 and page 4 for option 2. Have fun .
  5. Feb 22, 2018 at 2:30 PM
    #385
    Sgthawker
    Sgthawker Member
    2017 Silver Tacoma Double Cab TRD Sport 4 x 4
  6. Feb 22, 2018 at 6:40 PM
    #386
    Hoangde
  7. Feb 23, 2018 at 12:32 PM
    #387
    TRD Tyler
    TRD Tyler Straightenin the curves. Flattenin the hills
    Athens
    16 DCSB 4WD TRD OR
    Do you have any for sale now or is there a wait?
  8. Feb 23, 2018 at 12:40 PM
    #388
    Hoangde
    3 cables remaining. Do paypal then pm me your address.
    Thanks
    Eroms likes this.
  9. Feb 23, 2018 at 1:36 PM
    #389
    TRD Tyler
    Athens
    16 DCSB 4WD TRD OR
    Payment sent from dad@zonicgear.com
  10. Feb 24, 2018 at 2:13 PM
    #390
    Hoangde
    Shipped and pm. Thanks
  11. Feb 24, 2018 at 10:13 PM
    #391
    onelafan
    onelafan Well-Known Member
    L.A.
    2017 DCSB TRD Sport
    Paid & PM sent.
  12. Feb 25, 2018 at 9:16 AM
    #392
    shadowkhan
    shadowkhan Well-Known Member
    2016 Barcelona Red TRD Sport 4x4 Prem/Tech w/JBL DCSB
    Any more available?
  13. Feb 25, 2018 at 11:56 AM
    #393
    Hoangde
    Yes. Do paypal then pm me. Thanks
  14. Feb 25, 2018 at 3:59 PM
    #394
    shadowkhan
    Payment sent
  15. Feb 25, 2018 at 9:18 PM
    #395
    Frito
    Frito Well-Known Member
  16. Feb 25, 2018 at 9:38 PM
    #396
    Frito
    Ahhhh yes. I think I see why.
  17. Feb 26, 2018 at 7:02 AM
    #397
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. Without some additional mods, turning the front camera on will turn off other sources.
  18. Feb 26, 2018 at 7:26 AM
    #398
    El Latigo
    El Latigo Well-Known Member
    Anaheim CA
    2017 MGM TRD OR Double Cab Short Bed
    Question... Where are you all getting the USB power from, to power up devices? My truck only has one USB connector... Are you adding USB ports?? if so, would you please post pictures, as to how?
    Thank you, :thumbsup:
  19. Feb 26, 2018 at 7:33 AM
    #399
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is kind of off topic for this thread.
    I used one similar to this:
    https://www.amazon.com/MICTUNING-Charger-Digital-Voltmeter-Smartphone/dp/B077P7GYG6/
    The exact one that I bought doesn't seem to be available anymore. You should verify that this linked one will fit.
    The thing that I found is that the stock USB outlet only puts out 0.5A. Not useful for charging anything.
    To power my outlet, there is a ground point right behind the HVAC panel. I found a constant power connector while probing behind the drivers side kick panel. For keyed power, you can tap the back side of the power outlet. See my posts earlier in this thread for that. I used that to power my front camera. Be careful if you use the power port for USB power if you plug other stuff into it. I believe it is good for 15A total?
  20. Feb 26, 2018 at 7:40 AM
    #400
    El Latigo
    Anaheim CA
    So, you can power with 12V direct from the battery using the switch on the link (fused) but this could drain your battery as it would be constant ON. or keyed power so it is only ON when the key is the on position to save the battery. correct?
    i am looking in to the switch of the link you posted and seems like it would work.. Thanks a lot..
    tonered[QUOTED] likes this.
