4.10 gears and 33's
Discussion in 'Performance and Tuning' started by Volcom21, Feb 17, 2012.
  1. Feb 18, 2012 at 4:05 PM
    #61
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    How much did that set you back?
  2. Feb 18, 2012 at 5:34 PM
    #62
    commando
    commando Well-Known Member
    Brandon
    Oregon
    2006 SR5 Double Cab 4X4
    3" spacer lift
    $1350.00. Parts and Labor. Check out the link in post #7. It's all there.
  3. Feb 18, 2012 at 6:20 PM
    #63
    DevL
    DevL Well-Known Member
    I ran 35s on a CJ7 with 3.73 gears. It had a stick with no OD. I got 10 mpg city or highway. The engine was so under powered I had to floor it off the line to get moving... then with no OD and 15.5" wide super swampers and aerodynamics like a brick I got 10 mpg highway. A friend with a CJ7 with different 35" mud tires and 4.56 gears got better mileage by 3 mpg. Regearing is your friend. You may not see much improvement on the highway but your overall mileage WILL improve going to 4.11 if you run 33" or larger tires.
  4. Feb 19, 2012 at 7:30 AM
    #64
    Sprink669
    Sprink669 Well-Known Member
    I have 33's with stock gears and tow a 12ft aluminum trailer with 2 snowmobiles and would love to get some more power back when towing. I had a XJ with 33's and 4.56 gears ARB's and it was a tad over geared but off road it was great. I am going to scour the pull a parts for a 4cyl 4x4
  5. Feb 29, 2012 at 9:28 AM
    #65
    commando
    Brandon
    Oregon
    3" spacer lift
    Update: I got my true mileage figured out!
    For every 10 miles actually traveled my odometer registers 9.2 miles. This was figured by driving on the interstate and checking my miles against the milepost markers.
    So, I have a correction factor of about 8.6682%
    On my last fill up, I got 16.25 MPG. This was mostly highway miles, but included a little bit of 4X4-ing around in the snow.
    On my last woods run, I got 13.5mpg. This was almost all cruising slow in the woods, with a LOT of 4X4 use in the snow, and a little bit of highway time.
    At 65mph my rpm's are right around 2100-2150 rpm's.
    Hope this helps.
  6. Apr 15, 2012 at 12:19 PM
    #66
    Blkturbo!
    Blkturbo! Well-Known Member
    Sean
    Henderson, NV
    08 Tacoma; 05 Seadoo RXP; 94 Turbo Supra
    Icon Coilovers, Downsouth UCAs, rear Icon "2.5" shocks and Toytec single AAL. Still gotta do exhaust, dark headlights and re-gear the rear diff.
    So, if I'm reading this thread correctly, and not missing something, the only places to get 4:10s for my '08 Sport/2WD/Auto is either from the dealership or used from someone's 4cyl truck??? I want to reagear this thing once and for all!
  7. Apr 15, 2012 at 1:02 PM
    #67
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    I don't know much about this topic, but I do know this:
    http://eastcoastgearsupply.com/
  8. Apr 15, 2012 at 5:46 PM
    #68
    Blkturbo!
    Sean
    Henderson, NV
    ^BUMP^ for anyone who KNOWS this answer.
    Im not finding JUST a 4:10 ring and pinion set online
  9. Apr 16, 2012 at 12:32 AM
    #69
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    It's a Toyota specific gear for our trucks...beyond that your choice is a 4.11
  10. Apr 20, 2012 at 3:32 PM
    #70
    Relik
    Relik Well-Known Member
    Eddy
    Thousand Oaks, CA
    '11 TRD Sport PreRunner-Auto-Magnetic Gray
    Bilstein 5100s (Front & ext. Rear), Eibach coils @ 0, MaxTrac 4" Spindles, Light Racing UCAs, 1/4" lean spacer, All-Pro 3" Standard leafs, u-bolt flip kit, SpiderTrax 1.25" wheel spacers, 33" (285/70/17) TreadWright Warden A/T tires, extended lines
    I'm interested in 4.10 gears too....where can you find 4.11? That is like nothing of a difference...lol
  11. Apr 22, 2012 at 1:16 PM
    #71
    Coastie
    Coastie New Member
    Mitchell
    Nantucket, MA
    Ok so this is sorta random but I am curious if anyone knows will you be at lower RPM's in 6th gear in a standard instead of in 5th in a automatic for the 2nd gens?
  12. Apr 22, 2012 at 1:25 PM
    #72
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    The opposite 6th is .85 in stick and 5th is .72 in auto. 15% higher rpm with the stick.
    That's why 6speed gets worse mpg.
  13. Apr 23, 2012 at 3:29 AM
    #73
    Coastie
    Coastie New Member
    Mitchell
    Nantucket, MA
    Oh, well shoot, i guess it cost more to have fun. Thanks for the info!
  14. Apr 26, 2012 at 5:49 PM
    #74
    abu10
    abu10 New Member
    Texas
    1998 Toyota Tacoma 4x4 v6
    stock but not for long
    Question, if you regear do you do the front and back? and also what brand of gears?
  15. Apr 26, 2012 at 6:10 PM
    #75
    Redgrom
    Redgrom http://www.tacomaworld.com/forum/2nd-gen-builds/29
    Brent
    san clemente
    4x4 taco and 96 ford bronco
    ATO front skid (need more but icon's might fail if I hang anything else from my truck) All-Pro front bumper thanks to a good deal here and a pesky encounter with a rock or 20, total chaos uppers.
    Sub and yep, you have to do front and back at the same time if you plan to use 4x4 ever.
  16. Apr 26, 2012 at 6:16 PM
    #76
    abu10
    abu10 New Member
    Texas
    Thank you
  17. Apr 26, 2012 at 8:10 PM
    #77
    Redgrom
    Brent
    san clemente
    East coast gear supply comes highly recomended here. I am about getting close to finally doing my truck. Here in southern California I'm getting quotes around $1500 out the door for front and rear. Just trying to decide if I can justify a locker in the rear but that's a totally different thread. Your best bet is never log back on this site! It gets really expensive.:D
  18. Apr 30, 2012 at 10:24 AM
    #78
    abu10
    abu10 New Member
    Texas
    Yeah I can tell lol oh well every hobby i have is fairly expensive anyways ;)
  19. May 1, 2012 at 6:58 AM
    #79
    Blkturbo!
    Sean
    Henderson, NV
  20. May 3, 2012 at 9:10 AM
    #80
    BradyT88
    BradyT88 Well-Known Member
    This^^^
    On the freeway a regear will hurt your mileage because you are now at a higher RPM. It is kind of like driving at freeway speeds in 4th gear when you have a 5th.
    In the city it will help your mileage because it takes less throttle to get going from every stop. What do you think would happen to your city mileage if you took off from every stop in 3rd gear instead of 1st? You have to give it more throttle to get going. Think about riding a mountain bike, it's easier to take off from a stop in 1st gear as opposed to 18th.
    Going to taller tires will always make it look like you get worse mileage if you base it off of the odometer mileage, because you are now traveling farther per rotation that stock so you actually travel more miles than your odometer says.
    Also while taller tires actually help mileage (at least in theory) in reality that is not usually the case because when people get new tires not only are they taller but they are usually wider and there for weigh more and have worse aerodynamics. Between this and the odometer being inaccurate there is a common misconception that taller tires hurt fuel mileage, but really if your tires were the same width, tread pattern, and ply rating only one was taller (which would make it a little heavier but not much) you should actually get better fuel mileage, at least on the freeway, and city probably wouldn't be affected much unless there was a huge height difference that would need more throttle to rotate the tires from stop.
