45acp’s DIVORCED build!
Discussion in '1st Gen. Builds (1995-2004)' started by 45acp, Jan 15, 2012.
  1. Mar 30, 2015 at 10:03 PM
    #3221
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    give me a sec...lol. gotta find a way to get him to lay his hurrdurdiest hands on mine and make a bumper
  2. Mar 31, 2015 at 3:18 AM
    #3222
    45acp
    45acp [OP] Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    May I recommend the option of cutting out a compartment over your rear fender for hi-lift storage? Mike unfortunately declined. :luvya:
    Much unique. So hurrdurr.
  3. Mar 31, 2015 at 1:51 PM
    #3223
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
  4. Mar 31, 2015 at 1:54 PM
    #3224
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Definetly not kosher haha I'm sure they will fix it
  5. Mar 31, 2015 at 2:41 PM
    #3225
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    What is this shit... Ballistic fab???
  6. Mar 31, 2015 at 3:05 PM
    #3226
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Yup. They done did. Called me back and they're gonna swap it out.:cool:
    They'd have to really work hard and go the extra mile to be anywhere near as bad as Ballistic. haha
  7. Mar 31, 2015 at 3:54 PM
    #3227
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    When you cut tubes you have to precut them really close to what the "end" length will be. That way when the hole saw is halfway through the notch the first half of the tube falls off. If that makes sense. If you try to hole saw right in the middle of a tube its too much material, not to mention the hole saw will dull out faster because its making notches on the junk side too
    What I did is if you are notching a 45* then cut the tube within an inch or so of where the notch will end and cut it at 45*, that way the notcher is doing as little as possible
  8. Mar 31, 2015 at 4:14 PM
    #3228
    Supra TT
    Eric
    Indiana
    I love the tube notcher, Mark has one and it too is HF. It works great for almost any angle that I used it at! But, kinda need an electric drill IMO.
  9. Mar 31, 2015 at 4:22 PM
    #3229
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Oil grooves, right :notsure:?
  10. Mar 31, 2015 at 6:06 PM
    #3230
    99yodataco
    99yodataco Little Taco that could
    Chad
    New Mexico, it's just a little bit fresher.
    MGM 21 TRD OR 6sp MT
    Soon...
    That's one slightly dented lobe. Take some sand paper to it
  11. Apr 2, 2015 at 8:19 PM
    #3231
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I have no idea how bad that is or how much more I would fuck it up if I tried fixing it. :eek:
  12. Apr 2, 2015 at 8:35 PM
    #3232
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
  13. Apr 8, 2015 at 10:59 AM
    #3233
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Likely the single most expensive part of the truck. It doesn't look like $4,200, but it better act like it when the time comes. :eek:
    [​IMG]DSC00286 by wyo_taco45, on Flickr
    [​IMG]DSC00289 by wyo_taco45, on Flickr
    It's whats inside that counts, right?
    35mm cam buckets
    2mm over-sized stainless steel intake valves
    2mm over-sized Inconel exhaust valves
    HD springs (rated for 10k rpm)
    Titanium retainers
    Hardened keepers
    Viton valve seals
    Bronze valve guides and valve seats
  14. Apr 8, 2015 at 11:22 AM
    #3234
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    I wish I had $4200 to spend on something I won't use for 10 or so years.
  15. Apr 8, 2015 at 11:24 AM
    #3235
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    It's an investment!
    Wait... fuck.
  16. Apr 8, 2015 at 12:05 PM
    #3236
    Madjik_Man
    Colorado Front Range
    But for real... did they rip your wallet out through your arsehole?
  17. Apr 8, 2015 at 12:07 PM
    #3237
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    :rofl: haha that's about half as much as much truck cost :anonymous:
  18. Apr 8, 2015 at 12:08 PM
    #3238
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    :eek:
    If you get that motor to 10k, Ill drive cross country to give you a high five :p
  19. Apr 8, 2015 at 1:05 PM
    #3239
    Blackdawg
    Monte
    Wyoming/St. Louis
    You haven't finished the actual motor yet...and at this rate. It'll be more then the head haha
    Also you better store it real nice and wrapped up. Spray some wd40 on it lightly and wrap it up in plastic wrap. They put it anywhere but your garage haha
  20. Apr 8, 2015 at 2:27 PM
    #3240
    Balockay
    Balockay Well-Known Member
    Blake
    Cleburne, TX
    2017 4Runner TRD ORP
    Just look at the build thread
    Can confirm this. Lost two heads and a block due to not knowing what I was doing.
