4WD and rear diff lock issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03TurtleTaco, Sep 26, 2016.
  1. Sep 26, 2016 at 9:54 AM
    03TurtleTaco
    03TurtleTaco [OP] Well-Known Member
    Kody
    03 Tacoma off road build on a budget
    3 inch lift (eibach coils with bilstein 5100s in the front and rear with an aal). 17" Toyota trail team wheels (7 spoke) with Nitto Terra Grapples (285/70/17).
    Hey guys, I need some help on figureing out some things going on with my truck. When I go to put it in any kind of 4wd, It grinds until i Just "shove it in" :p (giggity)
    Also, no matter what i am in, my rear diff lock light flashes but will not become solid to symbolize that it locked...
    Another question that may be dumb, what does the 4wd button on the side of the 4wd knob do?
  2. Sep 26, 2016 at 10:04 AM
    surfernv
    surfernv Member
    Nick
    2001 Tacoma Xtra cab 4WD
    OME 881 front coils. Dakar rear leafs. Nitrocharger Sport shocks all around. Snugtop topper with Yakima racks.
    The button on the 4wd shifter activates the actuator that engages the 4wd system. That is, the front drive shaft is normally spinning passively when you are moving in 2wd. When you push the 4wd button an electronic actuator links the front drive shaft to the power coming from the transfer case.
    Quick question, are you shifting into 4wd, without pushing that 4wd button in first? Because in order to engage 4wd, that button must be pushed in and you'll see the little green light showing 4 wheels and the axels iilluminate (bottom right of dash). The shift lever is only for moving from 4Hi to 4Lo.
    As for flashing rear diff light it is likely trying to lock the rear diff, but failing. I believe this is also electronically actuated. Check out this thread for more info https://www.tacomaworld.com/threads/rear-e-lock-diff-light-indicator.194310/
    Also, I believe you must be in 4Lo for the rear diff to lock, without having performed the "gray wire mod" https://www.tacomaworld.com/threads/grey-wire-mod.4405/
  3. Sep 26, 2016 at 10:09 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    If you have the same shifter as I have on my 4runner:
    1. Keep the shifter in 4H at all times.
    2. When engaging 4H, you can do it by simply pressing the 4WD button on the side.
    3. To move down to 4L, make sure you have the vehicle in stopped and your transmission shifter in Neutral.
    4. Shift down to 4L
    If you don't do 3 and 4 when switching to 4L, it will grind.
  4. Sep 26, 2016 at 10:21 AM
    03TurtleTaco
    Kody
    i played with it a little more just now and the rear locker light finally stayed on and i heard it engage it just took a little longer after moving to engage than i had thought. I noticed that if i put the transmission shifter into park then it doesnt grind changing into any 4wd but it does when in nuetral.
    The 4wd button is exactly what i thought lol... it was a dumb question! A friend of mine acted like i need to keep the 4wd lever in N all the time and switch dowt to High and up to low for 4wd... and thats not how any of my other 5 tacomas have been. As i thought the N on the 4wd lever keeps the trans and diff in nuetral no matter what gear the tranny knob is in...
    so i guess everything is as it should be after all lol
    ramonortiz55 likes this.
  5. Sep 26, 2016 at 10:30 AM
    eon_blue
    Azusa, CA
    Sounds like you got it figured out but it never hurts to reiterate the basics...
    The 4wd button on the side of the 4x4 shifter activates 4hi. If you try moving the shifter into 4lo without pressing the 4wd button first (to engage 4hi) then it will just grind. Never engage 4wd on pavement, always be on loose dirt or gravel, snow or ice, etc. You can engage 4hi while moving at speeds up to 50 - 55 mph, and always try to do so while pointed straight.
    After you've engaged 4hi, you are now in 4wd. To go into 4lo, you need to be at a complete stop with your truck in neutral (or the clutch pushed in if you have a manual trans). It is especially important that you do not engage 4lo on pavement.
    The rear diff locker will only engage when your truck is in 4lo and only at speeds under 15 mph, otherwise it will just blink at you.
  6. Sep 26, 2016 at 10:33 AM
    03TurtleTaco
    Kody
    i have heard of a mod that makes it so you can engage the read diff lock without having to be in 4lo... any idea on how to do that mod?
  7. Sep 26, 2016 at 10:34 AM
    eon_blue
    Azusa, CA
    Its called the 'grey wire mod', supposed to be pretty simple to do but I haven't done it myself. If you search for it using the search feature up top it will come up. I think it's also a stickied thread in the first gen section at the top of the forum.
  8. Sep 26, 2016 at 10:35 AM
    03TurtleTaco
    Kody
    awesome! I wonder how well it works..?
  9. Sep 26, 2016 at 10:39 AM
    eon_blue
    Azusa, CA
    I know a few guys that have done it, it works great. Makes your truck much more capable in 2wd.
  10. Sep 26, 2016 at 10:39 AM
    surfernv
    surfernv Member
    Nick
    I included a link to a thread showing the mod in my first reply up top. I don't know how well it works. It is possible the e-locker is not extremely strong and too much force may be bad. I don't know, I think my manual says do not exceed 5 or 15 mph, and it's only for use when you're stuck. Check out ARB's air-lockers if you wanna get crazy and spend some $$ :D
    eon_blue likes this.
  11. Sep 26, 2016 at 10:44 AM
    03TurtleTaco
    Kody
    Yea im sure its not the easiest on the locker system lol
    I really want to get the ARB lockers for front and back but unfortunately i will have to rob a bank first! haha
  12. Sep 26, 2016 at 10:52 AM
    eon_blue
    Azusa, CA
    It'd be silly to ditch the factory e-locker for an ARB one, IMO. Waste of money, the e-locker is strong enough. Toyota puts it on the 2wd TRD Prerunners without any restrictions (might be a speed restriction, not sure). You don't want a locked rear end for going fast anyway, you'd want an limited slip diff for that.
  13. Sep 26, 2016 at 11:23 AM
    03TurtleTaco
    Kody
    right... i just figured a matching air lokcing system fron and back would be better. Idk im new to building a trail rig lol
    so keep the elocker in the rear with an air locker in the front?
  14. Sep 26, 2016 at 11:24 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  15. Sep 26, 2016 at 1:00 PM
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    Grey wire mod is super easy, just find the correct wire and cut it, crimp a ring connector on it and ground it.
  16. Dec 7, 2016 at 8:41 PM
    calilivin91
    calilivin91 Well-Known Member
    Lars
    San Diego
    2011 Tacoma DCSB TRD-Sport 4wd
    A. 4wd button engages 4x4 HI
    B. stop, shit into neutral to shit into 4-lo
    c. the rear diff, engage the button shift into drive roll a few feeet and should engage and turn solid
  17. Dec 7, 2016 at 8:51 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Issue was resolved months ago..
