4WD wont engage and NO light comes on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ElementSk8rX, Feb 14, 2021.
  1. Feb 17, 2021 at 4:12 PM
    wmgeorge
    wmgeorge Well-Known Member
    Well I would contact the former owner and asked if it worked and when was the last time he used it.
    Then purchase a digital VOM and a set of short insulated jumper wires 1 black , 1 red. Then on your truck you can clip the black jumper wire to a ground and the other end to the black lead of the meter. Practice using it until you get used to seeing 12.6345 volts or 12.6 volts when your on the DC scale. The AC is used for power in your house. Most get confused AC or DC, MA and Amps, just stay on DC Volts for now.
    I would verify power to the switch before anything else. Some car circuits may be at logic level 5 vdc if they are hooked to a computer, if the plug has Yellow it might be for the Air Bag circuit. A diagram would really help you, but power to the switch is pretty basic.
    You said when you turn the switch to H4 the red 4WD light comes on??? Is that true?
  2. Feb 17, 2021 at 4:21 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Any other dash lights on? Also since it's new to you, might as well change out the t-case and both diff fluids. Who knows when it was last done. Would also eliminate any worries of broken stuff.
  3. Feb 17, 2021 at 4:30 PM
    wmgeorge
    The PDF posted by whatstcp is what you need, excellent. For petes sake don't get involved in changing fluids ? until you get it working!!
  4. Feb 17, 2021 at 5:50 PM
    Slashaar
    Josh
    Kansas City, MO
    I've seen weirder things. Some systems (not saying this does) wont turn on without fluid in it. I just know from experience that checking your fluids is #1 when buying a new vehicle, especially sight unseen.
    Just my 2 cents. I watched someone throw 2 cylinders because he didn't check fluids after buying a used truck. :notsure:
  5. Feb 17, 2021 at 6:05 PM
    Yukon DoIt
    Yukon DoIt Opinionated Northerner
    Paul
    Yukon, Canada
    2006 White Tacoma DCLB 4wd Auto, 1988 Blue 4Runner 4wd Manual
    Stock-y
    Check them, sure. But if there's fluid it's ok not to change them yet.
    I would open up your stereo again and really inspect it fiercely. There may even be another fuse associated with actuating the 4WD, so get out your manual or find on the forum a list of what all the fuses do.
    Slashaar[QUOTED] likes this.
  6. Feb 17, 2021 at 8:22 PM
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
  7. Feb 17, 2021 at 8:56 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    there is only one, and if it’s blown, it will cause the lights to continuously blink (4x4, 4lo)
    Yukon DoIt[QUOTED] likes this.
  8. Feb 18, 2021 at 7:44 PM
    Slashaar
    Josh
    Kansas City, MO
    I almost thought this happened to me last night, light was flashing constantly and wouldn't engage. Finally it went in. Y'all are scaring me.
  9. Feb 18, 2021 at 7:53 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Shhhhh. Don’t talk about it. :rofl:
    Slashaar[QUOTED] and Yukon DoIt like this.
  10. Feb 18, 2021 at 8:02 PM
    SargeBSA
    SargeBSA With self-discipline most anything is possible.
    Cascade Mountains
    2021 SR5 Tundra 4x4
    TRD Offroad Wheels 265/75 18 General Grabber ATX's,
    fatfurious2, Slashaar and TnShooter like this.
  11. Oct 8, 2024 at 1:11 AM
    08taquito12
    08taquito12 Member
    2008 red Tacoma
    And I have a different problem 4x4 engages but no light
  12. Oct 10, 2024 at 5:25 AM
    Slashaar
    Josh
    Kansas City, MO
    That sounds like the bulb in your dash went out. Replace the bulb and check back.
  13. Feb 5, 2025 at 5:40 PM
    Ave109
    Ave109 New Member
    Aaron
    06 tacoma
    Lift, stereo, long tube headers, cold air intake, bumpers, rock sliders
    Did ya ever get it working? I'm having same issue, no light, no 4x4, no actuator noise.. also seems to.be no power to switch.
  14. Feb 5, 2025 at 6:08 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Have you checked your 4WD Fuse (20A) in the interior fuse box left of the steering column?
    If that's good check for power and ground at the 4wd ECU with the key on.
    https://www.tacomaworld.com/threads/4wd-system-operation-help-thread.742420/
