5 quarts on a drain and fill no trickle?!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kwelklin, Jul 28, 2011.
  1. Jul 28, 2011 at 9:16 AM
    kwelklin
    kwelklin [OP] Well-Known Member
    Northeast Michigan
    15 TRD OFF-ROAD DC
    I have to beleive something is not right here 3 qts came out and I've put 5 in without it trickling back. What's up with that?
  2. Jul 28, 2011 at 9:18 AM
    98tacoma27
    Ben
    Not Beech Creek
    Trickling back?
  3. Jul 28, 2011 at 9:24 AM
    TexasIslandBoy
    TexasIslandBoy THE RED DRAGON!!
    Andrew
    South Texas. SPI
    07' trd offroad 4X4 (For Sale)
    pro comp 6inch lift 35'' tires moto 950's radfo coilovers magnaflow exhaust 5/16" front skidplate usa spec ipod interface tree pin strip mod dry drop in filter full size BFG KM2 spare
  4. Jul 28, 2011 at 9:26 AM
    Alby9999
    Alby9999 Well-Known Member
    Alby
    NNJ
    07 AC TRD OR Impulse Red
    TRD Cat back exhaust 3" FR lift-AAL CAI-Ram air D rings Tail gate theft mod 4x4 illumination switch mod Redline hood struts Fogs on any time mod diff breather relocation mod 886 reverse light mod Wet Okole Avid weld on sliders LR UCAs Locker mod 115 in cab outlet 400w anytime
    Not sure what you mean but I hope you didn't drain in tranny fluid by mistake.:eek:
  5. Jul 28, 2011 at 9:26 AM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    :rasta:
  6. Jul 28, 2011 at 9:30 AM
    98tacoma27
    Ben
    Not Beech Creek
    Uh-oh!
  7. Jul 28, 2011 at 9:31 AM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    This ^^^
    But I also don't know what you mean by "trickling back".
  8. Jul 28, 2011 at 9:34 AM
    kwelklin
    Northeast Michigan
    15 TRD OFF-ROAD DC
    Yeah I'm intentionally doing a drain and fill on the tranny this is the second time in 2 days. The first time I put 4 in and it didn't trickle back. So this am. I drained it again got the 4 back and put 5 in and still nothing back after bringing it up to temp.
  9. Jul 28, 2011 at 9:36 AM
    98tacoma27
    Ben
    Not Beech Creek
  10. Jul 28, 2011 at 9:37 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    What? :notsure:
    Explain what you think "trickle back" means
  11. Jul 28, 2011 at 9:45 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You know he did :D
  12. Jul 28, 2011 at 10:05 AM
    horwitzs
    Seth
    Dayton, WA
    TX Pro
    I think he is meaning to be working on the tranny... he didn't specify initially so I assumed he was talking about motor oil.
  13. Jul 28, 2011 at 10:17 AM
    kwelklin
    Northeast Michigan
    15 TRD OFF-ROAD DC
  14. Jul 28, 2011 at 10:18 AM
    kwelklin
    Northeast Michigan
    15 TRD OFF-ROAD DC
    I'm not the sharpest tack on the board but I do know the difference between a oil pan and a transmission.
  15. Jul 28, 2011 at 10:21 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    tons of people drain the tranny oil instead of the engine oil lol.
    seen a couple threads on it, and thats the people that are man enough to say they did it.
    so let me get this straight, you drained your tranny oil, put 5 qts in it, drained it again and only 4 came out, and you cant find where its leaking at?
    edit: look, found 2 threads in like 30 seconds hah
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/160334-11-quarts-oil-mistake.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/33318-halp.html
    funny:)
  16. Jul 28, 2011 at 10:25 AM
    horwitzs
    Seth
    Dayton, WA
    TX Pro
    Seems obvious but several folks have trained the tranny on accident thinking it was the oil pan.
  17. Jul 28, 2011 at 10:26 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Uh, huh huht, huh hutt...
  18. Jul 28, 2011 at 10:28 AM
    kwelklin
    Northeast Michigan
    15 TRD OFF-ROAD DC
    Here it is from above. Read slowly. There is no leakage and I did it again because the original three that came out was pretty dirty.
    "Yeah I'm intentionally doing a drain and fill on the tranny this is the second time in 2 days. The first time I put 4 in and it didn't trickle back. So this am. I drained it again got the 4 back and put 5 in and still nothing back after bringing it up to temp."
  19. Jul 28, 2011 at 10:30 AM
    kwelklin
    Northeast Michigan
    15 TRD OFF-ROAD DC
    Brilliant guy, I'm not them!
  20. Jul 28, 2011 at 10:33 AM
    kwelklin
    Northeast Michigan
    15 TRD OFF-ROAD DC
    And one more thing my engine oil dipstick is full and clear yellow Mobil 1. I can't imagine it coming from the factory that low, I park in a garage and the truck leaks nothing.
    Is the check nut on the passenger side of the transmission above the exaust heat shield?
