5100 Install link
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MachoTaco10, Apr 22, 2010.
  1. Apr 22, 2010 at 4:28 PM
    MachoTaco10
    MachoTaco10 [OP] Well-Known Member
    Nick
    New Hampshire
    2010 Tacoma TRD Sport
    Can someone post the old link that was on here on the DIY 5100 install. I remember seeing an awesome write up on it step by step.thanks
  2. Apr 22, 2010 at 4:29 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
  3. Jun 27, 2010 at 6:04 PM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    Digging up into on self-install. Quick follow-up:
    It appears that, in a fully assembled shock, the total compression power of the spring is secured by that teeny little adjustment ring. Really?
    Sure, there is something that slides on top of this adjustment ring, but still, all the power stops with that little ring.
    What am I missing?
  4. Jun 27, 2010 at 6:21 PM
    28Gauge
    28Gauge Well-Known Member
    Brian
    Grapevine, TX
    06 PreRunner SR5
    Sockmonkey Graphics, K&N Drop In Air Filter, 265/75/16 Bridgestone Dueler A/T's, Weathertech Digital Fit Floor Mats, Dee Zee Bed Mat, Map Light/Dome Light LED's, Flo-Pro Muffler w/Stainless Steel Tip, Dome Light/Map Light Mod, Mobil 1 Synthetic Motor Oil, LED Cupholder Mod, Grillcraft with TOYOTA emblem, Vision 375 Warrior Wheels, Extra Bed D Ring Mod, TRD Skidplate, Bilstein 5100's on all four corners, Front 5100's set at zero with Eibach springs, Toytec 1.5" rear TSB add-a-leaf springs, Toytec swaybar relocate kit, Katzkin Leather Seating, Front Window Tint
    I was thinking the same thing. That adjustment ring doesn't seem like it would hold all of the pressure being exerted on it. It guess it works well though.
    I'm doing my 5100's this week. I hope it all goes well since it will be a DIY project for me.
  5. Jun 27, 2010 at 6:34 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    At first I said "how could all that tension be held by something I can remove with my fingers?" Then I realized that the spring perch slides over the sides of the ring to push it inward and hold it in place. That made me feel a little better.
  6. Jun 27, 2010 at 7:00 PM
    SCFirefighter
    Stephan
    Cary, NC
    Jup, I just figured that out too just before I saw your post. I started a thread in the ToyTec forum where I dumped all my starter questions.
    I'm sitting here in the living room with some of the parts, trying to fit them together. I had the "square peg, round hole" syndrome :D
  7. Jul 6, 2010 at 8:30 AM
    Elliebarley1978
    Elliebarley1978 Well-Known Member
    canada
    weathertech floor liners, wet okole fronts, leer 100xq cap, trd exhaust
    is there a more thorough link for this install? im planning to do it too but want a little more descriptive info. thanks
  8. Jul 6, 2010 at 11:11 AM
    Devildoc
    Devildoc Well-Known Member
    Lincoln, California
    Speedway Blue off road
    Running board, K&N air filter, Nitto Terra Grapplers G2 on ProComp 7089(285/70/17), 3" front lift and 1.5" AAl rear, all with bilstein 5100's with Eibach spring, 1/2 spacer in driver side and 1/4 spacer on the passenger, Wicked Flow exhaust, Debadge, satoshi raptor grille (HomerTaco)
    I'm doing my rear, I just need to know how the nuts and bushings are set up up top.
  9. Jul 6, 2010 at 3:56 PM
    2ndtaco07
    2ndtaco07 Active Member
    Santa Monica, CA
    07 TRD PreRunner
    Rear Suspension TSB 5100 up front @ 1.75
  10. Jul 6, 2010 at 4:05 PM
    05Moose
    Jim
