5100's install for Dummies!
Discussion in 'Suspension' started by Muy Grande, Mar 9, 2009.
  1. Mar 9, 2009 at 10:05 PM
    Muy Grande
    Muy Grande [OP] Well-Known Member
    Dallas, TX; RGV, TX
    06 DC TRD
    Suspension: DHoes up front, Dakar and OME out back. Audio: Alpine w205 w/ pair of Alpine Amps, Image Dynamic 6.5 Component Speakers up front and Image Dynamic Subs in the Back. Armor: ARB Bull Bar, Rocktek rear bumper and custom rock sliders. Other: Rigid Industries LED Light Bar, Platinum DieHard Battery, BlueSea Fuse Block, rear lights, bed lights, leds inside.
    Tried searching for a picture loaded "How to install rear 5100s" on here but can't find one. Anyone care to chime in or point me in the right direction. I would like to do this myself. Thanks.
  2. Mar 10, 2009 at 1:07 AM
    m_yota
    m_yota Well-Known Member
    Paradise
    08 4x4 dbl cab
    K&N airfilter, HID conversion for headlights/fogs. Wet Okole Seat covers, Kove Aphex processor Kenwood comp 6.5" and 6.5"coaxial 5100 billy shocks 2.5", 1.5" fabtech AAL,Epicenter and MTX Sub, debadged, tinted, kenwood dnx812, black mesh grill, led ext/int.
    just lift the rear, place some jack stands on the rearend to stablize the truck. Next loosen the bottom nut and the top. Installing is a little tricky, apply the bottom first then the top last. Getting the bottom bushing in will take some elbow grease. It's alot easier for the driver side than the pass. Just don't lose you cool. Make sure you torque the bolts to specs. Hav fun:):D
  3. Mar 10, 2009 at 5:27 AM
    muliefever
    muliefever Muliefever
    Tillamook, Oregon
    14' DCSB TRD
    5100's, 887', CB, 265's, FM Deltaflow
    Easy!!! I did mine on the ground yesterday.. Put the top of the shock through the hole up top. And then muscle the shock into place, lifting it will make it easy because you don't have to compress the shock as far!
  4. Mar 10, 2009 at 5:49 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    Your motivation...
    My STEALERship wanted about $400 to install the rears ($189+tax /side) :eek:
    I have the tools (and friends) to do it myself but was hoping they could do it while adding my TSB springs - no dice!
  5. Mar 10, 2009 at 3:16 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    rears are cake..Fronts are a bit more involved
  6. Mar 10, 2009 at 5:31 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  7. Mar 10, 2009 at 5:35 PM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    I got lucky with my dealer. They performed the TSB installed all 5100s at my suuggested setting in the front. The gave me all 4 Bilsteins that came with the TSB for me to keep or sell...
  8. Mar 13, 2009 at 8:38 AM
    2009tacomav6
    2009tacomav6 Well-Known Member
    phx AZ
    2012 4x4
    TRD SC TRD Cat Back KMC 17x9 Addicts
    If you installed 5100's on the fronts, can you add a spacer on top of that?
  9. Mar 13, 2009 at 8:45 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    yea you can still use spacers, but your shocks should be at the lowest setting. So dont try and use the lift on both the shock and the spacers.
  10. Mar 13, 2009 at 9:21 AM
    jasonh
    jasonh tossed salad anyone?
    Dallas, TX.
    2007 Pre Runner SR5
    Billy 5100's
    hey dude. i did mine last weekend. it was way easy. i could come help you if you would like.
  11. Mar 13, 2009 at 10:26 AM
    2009tacomav6
    phx AZ
    2012 4x4
    The reason I was asking is that I want to get some 295/70/17s under my truck and use the 5100's if at all possible. Then I was thinking about adding an ARB bumber on it. That sucker weighs about 100 lbs and would make the front end sag about 1". If that happens I may start rubbing again. So I was thinking that If I went with 5100's I could add the spacer to help overcome that sag and not rub. I like the revtek 426 kit for 3 inches of lift but will have the same issue later with the sag. With that kit they are already adding in spacers and I did not think it was a good idea to add spacers on top of spacres... at least from what I read. It makes sense...
