7089 owners... TPMS?
Discussion in 'Wheels & Tires' started by motoxmann, Jun 14, 2010.
  1. Jun 14, 2010 at 6:28 PM
    motoxmann
    motoxmann [OP] Well-Known Member
    Bay Area
    2009 TRD Sport
    Fox 2.5 RR coilovers, Fox 2.0 piggyback rear, toytec aal, TC UCA's, weathertec liners, Wet Okoles, grillcraft in the mail
    I just ordered a set of Pro Comp 7089s and am wondering if the tpms from the stock sport rims will fit them. Not sure if I'm gonna use them or not but curious if they'll work.
  2. Jun 14, 2010 at 6:35 PM
    BlueXenon
    BlueXenon Well-Known Member
    Los Angeles and Newport Coast
    Magnetic gray TRD sport (SOLD)
    Pro Comp 6" Stage 2 lift, N-Fab nerf bars, tinted windows, debadged, 6000k xenon headlights, 18" ProComp 7089 Wheels in black with BFG AT KO 33's, SnugLid tonneau cover, Line X'ed TRD skid plate. SOLD! Waiting for the 3rd Gen!
    I used mine, they work fine.
  3. Jun 14, 2010 at 6:36 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    they work on my 7189's
  4. Jun 15, 2010 at 1:42 PM
    motoxmann
    Bay Area
    2009 TRD Sport
    Thanks guys. How much did you guys pay to get them mounted switched and mounted? I'm still trying to find the best place get them put on
  5. Jun 15, 2010 at 2:50 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    The TPMS off my Off-Road fit them fine.
    Couldn't tell you how much it cost. I made the dealer swap the wheels and tires off my 04 when I bought this truck. It was part of the contract when I signed.
    Turned out my 7089s didn't fit because of the calipers so they had a company that they contract work out to (Rim 1) make them clear the calipers. He did the TPMS swap as well and road force balanced the tires. He put on new lugs too.
    He (the owner who did the work) did tell me he was going to submit a $700 invoice to the dealership though.
    Heres his site... http://www.rim1.com/
    This should probably be moved tot he wheels and tires section.
  6. Jun 16, 2010 at 8:58 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    I think mine cost about $70 to do everything
  7. Jun 16, 2010 at 9:05 PM
    Devildoc
    Devildoc Well-Known Member
    Lincoln, California
    Speedway Blue off road
    Running board, K&N air filter, Nitto Terra Grapplers G2 on ProComp 7089(285/70/17), 3" front lift and 1.5" AAl rear, all with bilstein 5100's with Eibach spring, 1/2 spacer in driver side and 1/4 spacer on the passenger, Wicked Flow exhaust, Debadge, satoshi raptor grille (HomerTaco)
    I have the same wheels and it works, bought it from 4wheelparts and they swap it with no charge. Just make sure to tell them to take it easy taking them off cuz I heard they break easy.
  8. Jun 16, 2010 at 10:00 PM
    motoxmann
    Bay Area
    2009 TRD Sport
    Mgrande: that's not bad. Did you take it to a local shop, or something like a wheel works? I still need to call around and get pricing.
    Devildoc: I'm surprised they did it for free. I called the one here before I ordered the wheels and they said it'd be $180 to mount, balance and swap the sensors.
  9. Jun 16, 2010 at 10:25 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    yeah, it was a local wheel shop. Even did my spare too.
  10. Jun 17, 2010 at 6:32 AM
    Devildoc
    Lincoln, California
    Just need to wheel and deal with these salesman. If your buying a set of tires and rims they should give you some break.
  11. Jun 17, 2010 at 6:44 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    I might get a :crapstorm: for asking this question, but I really like these rims but from searching the forum I am not sure which ones to order I read all kind of stuff about these rims like they hit the brakes, can't find the right shank lug nuts, etc. All I know is that I want these in a 17in rim and want to run 265/65 tire can some one help me out. There's a rep in it for ya. :eek:
  12. Jun 17, 2010 at 9:28 AM
    whitetaco02
    whitetaco02 Well-Known Member
    Frank
    GA
    09 Tacoma 4x4
    Tinted windows, stainless steel drop hitch, rear TSB, Marathon seat covers in Realtree AP camo, low profile chrome toolbox, husky liners front and back, debadged
    I could be wrong but I think these will work for you here.
    Xtreme Alloys Series 7089 Black Finish
    • 17x8, 6 on 5.5 Bolt Pattern
    • Backspace = 4.5 in.
    • Max Load = 2200lbs
    • Finish = Flat Black
    • Hub Centric = No
    • Offset = 0mm
    Part number PXA7089-7883
    I would call Pro Comp toll free at Toll-Free: (866)232-0665
    Call them to verify but I think they will work. I hope this helps and let us know!
    Also, talk to this guy as it looks like he has the rims you want.
    http://www.tacomaworld.com/forum/2nd-gen-builds/97780-andrew-h-my-build.html
  13. Jun 17, 2010 at 10:02 AM
    motoxmann
    Bay Area
    2009 TRD Sport
    There's a ton of people that run these on this site, so they shouldn't be a problem. At least I hope. I guess I'll see when they come in this week.
  14. Jun 17, 2010 at 6:08 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    You'll need shanked lugs, but not with an extra long shank.
  15. Jun 17, 2010 at 6:14 PM
    Blktaco16
    Blktaco16 The juice was worth the squeeze!
    Heath
    Orange Park,Florida
    07 TRD Off-Road(4x4)
    Satoshi Grill w/ Hella 500's,Toytec coilovers, rear 5100's,diff drop, toytec AAL,sway bar relocated, rear axle shims,laminx fog light covers,UWS black low pro box,17x8 Procomp 7089,285/70/17 BFG KM2's,K&N short ram intake,diff breather mod,tailgate mod.
    I have these wheels on my 07 DC 4x4 and no issues what so ever..
  16. Jun 17, 2010 at 6:20 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    thats what I have... plus the TPMS work just fine... I have a 305/65/17 tire too
  17. Jun 17, 2010 at 6:33 PM
    PatHLC128
    PatHLC128 College.
    Pat
    Austin, TX
    09 TRD Off Road 4x4 AC
    OME complete 3" kit, 265/75/16 Cooper STTs, Pro Comp 7089 wheels, Shrockworks sliders, UWS Low Pro Toolbox, AFE Pro-Dry S, OEM Bedmat, Ventvisors, Husky Liners, Tint, De-badged
    i have them too, tpms works fine and no issues clearing the caliper...and mine are the 16x8s
  18. Jun 17, 2010 at 8:08 PM
    whitetaco02
    Frank
    GA
    09 Tacoma 4x4
    Solus, you make me wish I had bought red!
  19. Jun 17, 2010 at 8:35 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    thanks
  20. Jun 18, 2010 at 7:42 AM
    Devildoc
    Lincoln, California
    You will be okay with these rims. I have a 17 inch, 0 mm offset, LUG centric, with a gorilla ET style shank model # 21138ET http://www.brandsport.com/grla-21138et.html check it out. Make sure that you do not get the extra long one (21138ETXL) because it will not hold the rims tight and that is why some people had trouble with these rims.
