9" Suspension Lift, Off-road capabilities
Discussion in 'Suspension' started by kbrebel04, May 12, 2012.
  1. May 12, 2012 at 2:07 PM
    kbrebel04
    kbrebel04 [OP] Well-Known Member
    Kyle
    Virginia Beach
    12 4x4 TRD Sport
    Can I post links from websites that sell parts? I have some things I want to post and get opinions on it
  2. May 12, 2012 at 2:08 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    OME lift with 285x75R16 then. (33" tire) You might have to cut some of the inside fender to clear them so you don't rub when you turn but no one will ever notice it unless you specifically point it out to them.
    33"s with 3" lift is good shit. I'm just getting 35" envy which is why I suggested it. :p
  3. May 12, 2012 at 2:09 PM
    Sunner
    Sunner Well-Known Member
    Oh I did not see that there. Cool. Well Which ever way you decide to go OP, make sure your commited. Dont go buy a simple OME lift then decide you want MT a few months later, big waste of money. Ive been lurking on here for months, wanted a Pro comp lift first, then the ToyTec Ultimate lift, then Long travel and now I FINALLY made my decision. Good luck buddy. :cheers:
  4. May 12, 2012 at 2:16 PM
    kbrebel04
    Kyle
    Virginia Beach
    12 4x4 TRD Sport
    Tires
    Wheels
    Before I continue on with other components, could i get some help fine tuning above?
    With the wheels, i have no idea what im doing selecting the wheels there are so many types (For example: 6x135/5.5 OS:18mm BS:5.71") I have no idea what this means and what of the above i need for my truck...and on a lesser note, what color...black or chrome on a green taco with painted grille and bumpers..
  5. May 12, 2012 at 2:21 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Get what you like for the wheels. Just remember, more wheel, means less tire. Harsher ride and more expensive tires.
    6x135/5.5 is the bolt pattern. That's correct for our truck. More specifically you just want the 6x5.5. There's a ton of back spacing on that tire and it's going to rub more than a horny dog on his masters leg.
    Additionally going with a 3" lift you're going to want to probably get new Upper Control Arms to bring the alignment into order so your truck doesn't wander all over the road.
  6. May 12, 2012 at 2:28 PM
    kbrebel04
    Kyle
    Virginia Beach
    12 4x4 TRD Sport
    Should I go with a 17"? I liked those rims, and my truck came with 18s stock, Again I like practical, but a little flare makes me happy too (hell my truck has a non-functional hood scoop lol...)
    LOL, any thing better you would suggest?
    No idea what these are yet...Or what/where to buy
  7. May 12, 2012 at 2:32 PM
    medic2230
    Murph
    Bama! Roll Tide
    That is a solid setup. I love mine. You will need the upper control arms for alignment though. I'm running mine on stock trd off road wheels and I'm only rubbing on the control arms at full lock and full droop. I'm waiting on the second set of spacers to get here before I put them on.
  8. May 12, 2012 at 2:43 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Wheels are personal. What you like you should get. I can only attest that I dislike the bro look regardless of my love of monster energy drinks. That's why I went with Konigs. Simple, no bling, matches my truck but makes it unique and stand out just a little bit.
    Can't do 15"s. Calipers will rub. 16"s are the smallest you can do.
    Again this is a personal opinion. Myself? I love 16"s cause I like more tire than wheel on trucks and the tires are cheaper the smaller the rim you throw it on. I'm not looking to sling corners, I have no antisway bar and roughly 230lbs of armour and winch up front. Fast and the Furious I am not. Ponderous and disgruntled I am.
  9. May 12, 2012 at 2:44 PM
    jandrews
    '09 FourDubDee TRD OR
    Ideal lift: Bigger tires with no suspension changes (not really possible on most vehicles, including 2gen tacomas).
    Failing that: 3 to 4" suspension lift with high quality components. Icon, King, Fox, Old Man Emu. This will result in increased maintenance needs for the truck.
  10. May 12, 2012 at 2:47 PM
    kbrebel04
    Kyle
    Virginia Beach
    12 4x4 TRD Sport
    Curious, how will a 3" lift result in increased maintenance needs?
  11. May 12, 2012 at 2:51 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    New upper control arms. Increased wear on CVs and CV boots.
    But don't worry, it's not like you'll be replacing them yearly or anything.
  12. May 12, 2012 at 2:51 PM
    jandrews
    You're going to wear out bearings faster. You're going to wear out u-joints faster. Those are the two primary culprits.
    If you stay with the stock UCAs, the ball joint in them will be at risk. CV boots wear more quickly if left unmodified.
    If you run larger tires, brake pads, rotors, and fluid will all see increased wear rates.
    Again, if staying with stock UCAs, ideal alignment will be difficult. Tire wear may suffer as a result.
    Etc.
  13. May 12, 2012 at 2:52 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Too slow Quasimodo!
  14. May 12, 2012 at 3:01 PM
    kbrebel04
    Kyle
    Virginia Beach
    12 4x4 TRD Sport
  15. May 12, 2012 at 3:08 PM
    #35
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    I am local, check out my build thread. You can come check out my truck too if you like. There are TON of us local to you. Hit us up in our local thread...Calling all Virginians (Tidwater Area) We just had a meet today and lifted like 3 trucks and did some other small things to others....
    EDIT: That is not a trail....These are our trails...
    http://www.youtube.com/watch?feature=player_embedded&v=NHxfzPq14i4
    http://www.youtube.com/watch?v=WiyI1_2utzo&feature=channel&list=UL
    http://www.youtube.com/watch?v=8iI5BmKOxyo&feature=BFa&list=UL3aMzpOIbe7c
    http://www.youtube.com/watch?v=6QkufF88OKw&feature=BFa&list=UL8iI5BmKOxyo
  16. May 12, 2012 at 3:08 PM
    #36
    jandrews
    Where's the offroad?
  17. May 12, 2012 at 3:42 PM
    #37
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    No.
    Stock UCA's, nerf bars and hi incidence of rollover.
  18. May 12, 2012 at 4:36 PM
    #38
    kbrebel04
    Kyle
    Virginia Beach
    12 4x4 TRD Sport
  19. May 12, 2012 at 4:42 PM
    #39
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Extra lift.
  20. May 12, 2012 at 4:57 PM
    #40
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    Dude, buy once cry one! Get the Icons with TC UCA, all pro expo pack and icon rear shocks....buy and be in love!!!!
