A Girl's Bed liner woes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlackGeisha, Jun 29, 2014.
  1. Jun 29, 2014 at 1:30 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Holy crap the previous owner beat the bed to shit, and either took the bed cubbies out (where the giant square holes are) or they eventually fell out and were tossed away...who knows.
    As I posted on PAGE 1, I haven't see anyone successfully purchase a replacement set of factory bed rails, and the people that have talked about it elsewhere on this forum have dissapeared or never posted if they were successful or not. You will either need to go to the junkyard or see if a dealer can hook you up. Those rails are not listed for sale on any dealer sites and don't show up in any parts catalogue either as far as I know.
    You could do as I advised before and install some aftermarket rails of choice, such as L track/Airline track, or Utili-trac or Unistrut (what Nissan uses in the Frontier bed). Not sure on how easy it is to get up in the bedsides to install that stuff. Rivnuts could work for you, not sure on cost of doing that. Or you could install track in the bottom of the bed as opposed to the rails.
    Just a few suggestions...hopefully others will chime in.
    And again, previous owner/whoever, beat the shit out of that bed. Big ass holes and crap everywhere.
    EDIT: you can add floor D-rings for the time being as you source a used set of rails or a new bed lol. Read through this thread. People towards the last pages started to use Dodge Van D-rings as they were cheaper or something and don't require drilling out the D-ring hole to fit/something along those lines....so there is potentially 6 new tie down points added right there based on 6 bed bolts.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/28533-installed-d-rings-bed-pics.html
    SOME MORE THREADS TO LOOK THROUGH WHERE PEOPLE INSTALLED UNISTRUT:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/80370-nissan-utili-track-cargo-channel-system.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/172754-unistrut-titan-rack-mod.html
  2. Jun 29, 2014 at 1:37 PM
    BlackGeisha
    BlackGeisha [OP] Member
    '08 Prerunner sr5
    Thank you! The interior, however, is immaculate and it had pretty low miles for an '08. Would you recommend me taking it to a professional accessories shop?
  3. Jun 29, 2014 at 1:40 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    holy shit That is the worst bed I have seen. Better off trying to order a whole new bed with all those holes in it.
  4. Jun 29, 2014 at 1:45 PM
    JdevTac
    Josh
    MD/GA
    2nd gen
    Not sure how much of a DIYer you are, but you could just remove the bedsides and add rails on either side of the bed yourself....or replace the bed entirely because of all the holes/looks like swiss cheese. Probably a bit harder to do portion of the bed near the cab without removing the bed entirely....doesn't seem "too" hard, just time consuming. Link below showing bedsides removed and how someone did it.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/208443-how-remove-pickup-bed.html
  5. Jun 29, 2014 at 1:48 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    it looks like your bed rail(s) are missing, your cubby's are missing and holes have somehow been punched into the side of your truck bed
  6. Jun 29, 2014 at 1:49 PM
    StealthTaco
    StealthTaco www.ecgfabrication.com
    Alec
    NC
    05 Black Tacoma TRD Sport 6-speed
    Damn thats some intense damage to the bed...never seen that before. I'd try to go to a junkyard to see if you can get lucky and find some bed rails, they're difficult to come across for some reason.
    I think that giant square hole is where a storage cubby should be if I'm not mistaken...I'd try to find that in the junkyard too.
  7. Jun 29, 2014 at 1:53 PM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    where are you located... I had holes in my bed and fixed them.. however the missing parts you will have to purchase.. can't fix that..
  8. Jun 29, 2014 at 1:54 PM
    Hairy Taco
    North of Hell
    08 TRD
    I agree with the above. Go junking and get your bed some factory rails and cubbies.
  9. Jun 29, 2014 at 1:55 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Depending on the height of your load, a full-bed cargo net might be an option.
  10. Jun 29, 2014 at 1:55 PM
    StealthTaco
    Alec
    NC
    Curious as to what was done to fix them?
  11. Jun 29, 2014 at 1:55 PM
    BlackGeisha
    '08 Prerunner sr5
    I'm absolutely willing to invest money into fixing it. I don't what is a good brand or style or where I need to take it. I'm interested in a bed extender but how do they work?
  12. Jun 29, 2014 at 1:59 PM
    Jeffvt0508
    Jeff
    Anderson, SC
    I actually went to my local west marine.. since this is a composite bed.. I used G-flex puddy ( its to fix holes in kayaks and small side wall repair in boats. they make a fiberglass type but its a huge mess and more than what I was willing to do for my holes.. anyway.. the puddy is a 2 piece composite break small amounts off and mix it with your fingers then place a spoon or something on the back of the hole ( figuring out that is the hardest) then fill the hole.. once dried and hardened its sandable as well as drillable but in her case just sand it down smooth.. then by some black trim paint and done.. finished 6 holes in my bed in 2 days ( mostly waiting for it to cure.. )
  13. Jun 29, 2014 at 2:00 PM
    BlackGeisha
    '08 Prerunner sr5
    Oh and I have the pieces that came out. They popped out, rolled around and scared the shit out of me on the freeway one night!
  14. Jun 29, 2014 at 2:04 PM
    Jeffvt0508
    Jeff
    Anderson, SC
    where are you located blackgeisha???
  15. Jun 29, 2014 at 2:05 PM
    #35
    Jeffvt0508
    Jeff
    Anderson, SC
  16. Jun 29, 2014 at 2:06 PM
    #36
    JdevTac
    Josh
    MD/GA
    2nd gen
    I'm assuming you mean the little bed cubbies/boxes. Well that is definitely an easy fix with some good 3M mounting tape. And with what was posted above you have patching the holes covered. So tie down rails is all you have to worry about.
  17. Jun 29, 2014 at 2:07 PM
    #37
    hitmans.army
    hitmans.army Just a guy.
    Myrtle Creek, OR
    '07 PreRunner & '40 Chrysler Coupe
    Bilstein 5100s up front with OME 885s, rear Add-A-Leaf, LED lights (tails, dome, map, plate lights), Kicker 8" in custom fiberglass enclosure under back seat, Kicker speakers throughout and Kicker amp for sub, Pioneer DVD Player, Satoshi Grille with Devil Horns, Leer 100XQ.
    If you have any good junk yards around, you may get lucky and find the rails. I haven't scanned through the FS section, but you might be able to find some there. As for the bed, best bet would probably be finding a truck that got totaled due to front end damage if you can find one before the bed gets snagged. You can install D rings to the bed bolts for smaller loads, but it won't do much good with a load of hay.
  18. Jun 29, 2014 at 2:17 PM
    #38
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Why would anyone buy a truck with that much damage to the bed?
    Good luck finding a good junkyard replacement, these trucks are not like the thousands of S-10's sitting in junkyards everywhere.
    I'm guessing this truck has more problems than what is obvious.
  19. Jun 29, 2014 at 2:19 PM
    #39
    JdevTac
    Josh
    MD/GA
    2nd gen
    She said she has the bed cubbies, they fell out into the bed when she was driving the truck from the lot or whatever.
    Do some of you guys even read any fucking new post in this thread. What about this says troll?
    On a side note does anyone know if you can buy new bed rails? Every thread (like 2 or 3 exist lol) where they mention finding replacement rails...people say that dealers don't sell them by themselves or they never leave a response on if they sourced any or not. It's my impression that it comes as a whole bed assembly only ($1000+ brand new from dealer). Leaving junkyard as only reasonable option.
  20. Jun 29, 2014 at 2:27 PM
    #40
    JdevTac
    Josh
    MD/GA
    2nd gen
    No, just saying lets progress the thread instead of posting same stuff 10x over.
