AAL INSTALL HELP!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gov875, Oct 28, 2011.
  1. Oct 28, 2011 at 2:11 PM
    gov875
    gov875 [OP] WahooTaco
    Pacific Beach, CA
    TRD Sport DCLB
    Wet Okole's (front & rear), Weathertech Floormats (front & rear), cheap tailgate theft mod, extra d-rings, low profile toolbox (flat black), Thule Roof Rack (58" load bars), Thule Ski/Snowboard Roof Rack, Blacked Out Badges, Fishing Bobber Trailer Ball Cover, AVIC-X930BT w/ XM & steering controls, 5100s All Around (front set at .85), Eibach Coils, Rear TSB, rear AAL, LR UCAs, Toytec Diff. Drop, Mudflap Delete, Tailgate Reinforcement, Spidertrax (all 4), 285 Nittos, Rear Diff Breather Extension, TRD Exhaust, Powered Rear Sliding Window, DeeZee Bedmat, rear-view anytime mod, trailer bracket relocate, fog light anytime mod, redline hood struts, Satoshi with Homertaco Custom TRD Mesh, Hella 500s behind the grill, Brighter Reverse Lights
    I am midway through putting in 5100s on the rear and an AAL but i can't get the leaf holes to line up for the centering pin. I've been stuck on it for about an hour now so any pointers would be useful. I can get the overload, the new AAL, and the next leaf lined up but the next two are about a centemeter or two off each from one another so it staggers as it goes up. Can't get it to line up with any sort of clamps or jacking...
    Anyone got any help!?
  2. Oct 28, 2011 at 2:14 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    I had the same problem....put both your feet on the leaf pack, push and move the axle with your hands, should instalntly go in.
  3. Oct 28, 2011 at 2:16 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    put a screwdriver through all the leaves. Then using a c-clamp, clamp everything together. Remove screwdriver, insert pin.
  4. Oct 28, 2011 at 2:16 PM
    kinkrider101
    santa barbara
    wheels and tires
    Whoops, wrongpart, you will need to know that also though, just slide th leafs until they are lined up, jack up the axle till there is some tension and slid the pin in
  5. Oct 28, 2011 at 2:16 PM
    gov875
    Pacific Beach, CA
    TRD Sport DCLB
    here's a pic of it
  6. Oct 28, 2011 at 2:17 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    clamp everything including aal together with a long screw driver through the hole to keep it lined up.
  7. Oct 28, 2011 at 2:20 PM
    gov875
    Pacific Beach, CA
    TRD Sport DCLB
    attempting this now... i think i need a beefier screwdriver.
  8. Oct 28, 2011 at 2:20 PM
    kinkrider101
    santa barbara
    wheels and tires
    Clamp it all together at once, then after that the leaf centering pin will most likely not line up with the hole in the axle, but it will work if you force it.
  9. Oct 28, 2011 at 2:21 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
  10. Oct 28, 2011 at 2:29 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Had similar problems--align w/screwdriver--MUSCLE IT IN.
    Thought I was going to break something--NO--It needs perswasion.
  11. Oct 28, 2011 at 2:39 PM
    gov875
    Pacific Beach, CA
    TRD Sport DCLB
    just got the top two aligned but the add a leaf overload and bottom of the original pack are still misaligned:
  12. Oct 28, 2011 at 2:43 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Hopefully you have your jack stands on the frame. All ya need to do is push the axle housing a lil to line it up.
  13. Oct 28, 2011 at 2:47 PM
    kinkrider101
    santa barbara
    wheels and tires
    Pick up the overload and slide it to the right and clamp the pack together...worry about mounting it in the axle hole later
  14. Oct 28, 2011 at 2:47 PM
    gov875
    Pacific Beach, CA
    TRD Sport DCLB
    hmm i'm moving it around in all directions and nothing is lining those top two up...
  15. Oct 28, 2011 at 2:50 PM
    gov875
    Pacific Beach, CA
    TRD Sport DCLB
    if i move the overload then the middle leaf still wont line up and it's out of reach with my screwdriver, keeps bending. can i hammer the leaf back some from the front?
  16. Oct 28, 2011 at 2:50 PM
    kinkrider101
    santa barbara
    wheels and tires
    I used a hammer and hit the c clamp on the sides to slide the middle leaf
  17. Oct 28, 2011 at 2:52 PM
    gov875
    Pacific Beach, CA
    TRD Sport DCLB
    also on the add a lead should the longer side of the centering hole go forwards or backwards?
  18. Oct 28, 2011 at 2:52 PM
    gov875
    Pacific Beach, CA
    TRD Sport DCLB
    hammering lined it up!! now just about the front vs back sides...
  19. Oct 28, 2011 at 2:54 PM
    kinkrider101
    santa barbara
    wheels and tires
    I've had It both ways, makes no difference, but toytec says long end facing back, I had it the other way to prevent axle wrap
  20. Oct 28, 2011 at 2:56 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    ^This. Your making it hard on yourself, especially with that clamp. C clamps are best for this job. Get the axle out of the way, clamp the whole pack together while centering with a screwdriver or 1/4" socket extension, bolt it and put the axle back in position.
