AAL Install. (second gen)
Discussion in 'Suspension' started by chris4x4, Sep 28, 2009.
  1. Dec 8, 2014 at 12:45 PM
    #381
    Jwbfx4
    Jwbfx4 Active Member
    Bama
    14' dcsb trd
    Thanks. I figured that but wanted to make sure. I'm trying to get everything lined up for when I get everything in.
  2. Dec 8, 2014 at 3:18 PM
    #382
    AWF ROWD
    AWF ROWD ...eats at the " Y " often....
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
    I guarantee they'll be some guys that can't collapse the piston by hand.....;)
  3. Jan 11, 2015 at 11:42 AM
    #383
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    Subd for install
  4. Feb 18, 2015 at 2:16 PM
    #384
    TacoJosh82
    TacoJosh82 Well-Known Member
    Josh
    Wisconsin
    12 Access Cab 2.7
    OME dakar lift, MB TKO's, bfg KO2's, tinted, blacked out everything, cap.
    Hello, this is my first post so I hope its not a silly question thats been answered a thousand times... But I have a '12 2.7 liter access cab and I need to do the aal. For my work I have to keep all of my tools in my bed pretty much permantly. Its not over the limit as far as weight goes but I have noticed the rear definetly sags lower than the front.
    Anyways can you guys recommend a good aal kit? Toyotec? Rough Country? I think it needs to go up about 1.5" to 2". And also will this void my 100,000 mi bumper to bumper warranty? (truck has 45k on it now).
    Ultimately I would love to lift the front about an inch or so and then the rear up 2" to 3" to level it. Looks like 5100's in the front but the back?
    Sorry if this is in the wrong thread. I'm not sure where to start.
    Thanks
  5. Feb 18, 2015 at 2:18 PM
    #385
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW! It wont void any warranty, and the Toytec AAL or Icon 3 leaf AAL should do you well.
  6. Feb 18, 2015 at 2:33 PM
    #386
    TacoJosh82
    Josh
    Wisconsin
    12 Access Cab 2.7
    Thanks for the fast reply! I just read though a sticky that mentions the warranty stuff. Next I have to post a reply in the clutch problem section. Mine went out at 41k, and they replaced it fully under warranty!
  7. Feb 18, 2015 at 2:35 PM
    #387
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  8. Feb 19, 2015 at 10:21 AM
    #388
    Wpg07TRD
    Wpg07TRD Canadian Member
    Neal
    Winnipeg
    '07 TRD Sport, DCLB
    5100s and 885x coils, Trail Gear Add-A-Leafs/5125s, interior light LED swap, rcbs204 illuminated 4x4 switch
    I'll be installing an AAL in the very near future and had a question about shocks. With the expectation being between 1.5 - 2" of lift, which 5100s would I go with? Limited suppliers in Canada and this is where I'm looking, http://www.bilsteincanada.com/index.php?cPath=306_3992_4035_12882
    First set listed says for 0 - 1" of lift and the other says 3 - 4" of rear lift. What about the 1.5 - 3" range?
    If there's other part numbers out there that aren't available on this site please let me know and I'll try to find them somewhere in the great white north!
  9. Feb 24, 2015 at 8:34 PM
    #389
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Progressive or single leaf?
  10. Feb 24, 2015 at 8:37 PM
    #390
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The 3 leaf.
  11. Feb 26, 2015 at 10:09 PM
    #391
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Awesome write up, subbed
  12. Feb 28, 2015 at 5:27 PM
    #392
    TacoJosh82
    Josh
    Wisconsin
    12 Access Cab 2.7
    Ok so I have decided on going up 3" in the rear. I was thinking a 2" aal kit and a 1" lift block. Any problems with going this route? Keep in mind my rig is currently a mall crawler. I just have 2-300 lbs of tools in the back. And whats the difference between the single add a leaf and the progressive 3 leaf pack?
  13. Feb 28, 2015 at 6:59 PM
    #393
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2021 TRD Pro (upgrade from my 2nd gen)
    Work in progress, but mods so far; OTT 7.0 tune, 255/85/16 Falken WildPeak M/Ts
  14. Mar 1, 2015 at 12:39 PM
    #394
    TacoJosh82
    Josh
    Wisconsin
    12 Access Cab 2.7
    Ok thanks JonnyBb! I checked it out. If I understand it correctly the progressive 3 leaf is more of a softer ride, with the single add a leaf being alot stiffer. Now for my application having a few hundred pounds of tools with me permantly would it be better to us the single stiffer aal? My theory being that having so much weight in my truck it would be less likely to sag back down cancelling the 2" of lift it would provide? I suppose if it does sag back down an inch or so I can just add 1" blocks lift blocks? Is that going to cause too much axle wrap? Keep in mind I'm still paying for my Taco so I am not beating on it off road yet..
    Thanks and sorry about asking questions that have been asked a bazillion times.
  15. Mar 4, 2015 at 6:18 AM
    #395
    Johnnyutah47
    Johnnyutah47 New Member
    Did the Icon aal last night on my 15' DC TRD OR, didn't quite end up at 1.5" of lift, but the ride is a ton better!! Thinking about putting the overload leaf back in. In theory , this raises me another 1/2" or so correct? Any issues with this?
  16. Mar 4, 2015 at 6:19 AM
    #396
    Johnnyutah47
    Forgot to mention... Bds 2.5" spacer on front.
  17. Mar 4, 2015 at 10:27 AM
    #397
    Ricks2013
    Ricks2013 Well-Known Member
    Rick
    Orlando, FL
    13' TRD Sport DCSB
    A few things
    Yes. How ever thick the leaf is is how much more lift you will get.
  18. Mar 20, 2015 at 7:58 AM
    #398
    mistermanny
    mistermanny Well-Known Member
    Jalisco, Mexico
    05 AC 4x4 2.7 5spd
    OME 883/Nitros
    You got 1.5" without the OL?
    I was hoping to get an even 1" without the OL.
    I wonder if the Wheelers Progressive AAL would be a better fit...
  19. Mar 23, 2015 at 3:33 PM
    #399
    TacoJosh82
    Josh
    Wisconsin
    12 Access Cab 2.7
    Heres a silly question.. My rear is about 1 inch lower than stock because of the weight of the tools in the back. If I put the Wheelers 2" AAL in will it go up 2" or will it be less because of the weight? I am ordering the AAL tonight and I am thinking about getting 1" spacer blocks if it doesn't get the full 2 inches. Maybe with the OL in it will get more.
  20. Mar 23, 2015 at 4:28 PM
    #400
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You should be close to 2" over where youre at now.
