ABS brakes????
Discussion in '1st Gen. Tacomas (1995-2004)' started by ETaco23, May 10, 2010.
  1. Aug 9, 2019 at 8:27 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Probably.
    G59 likes this.
  2. Aug 9, 2019 at 8:29 AM
    jbrandt
    Justin
    No. That means they are SEARCHING!!!!
    We should celebrate that.
    An old thread? Sure, but at least they searched for the answer vs. the elevendy billion "what lift do I need to fit 33's" threads.
  3. Aug 9, 2019 at 8:33 AM
    mayday
    mayday Well-Known Member
    Central Coast, CA
    99 5 speed 4x4 SR5 TRD Supercharged
    I just had my ABS light come on and thought I was about to come upon some new knowledge...
  4. Aug 10, 2019 at 8:35 AM
    02hilux
    Planet: EARTH
    Knowledge, yes.
    Remove the ABS pump, ABS bulb from cluster, LSPV, and 1 hardline from the LSPV. Install 2 new non-abs hard line from MC to front brake and adapte an adjustable portportional valve for the rear drum. Braking is so much better!
    mayday[QUOTED] likes this.
  5. Aug 11, 2019 at 3:32 PM
    Dufus
    Dufus Well-Known Member
    Located in Colorado
    99 Taco 3.4L manual 4x4 SR5 - Imperial Jade Mica
    Mods: bent frame and sun weathered roof paint.
    I brought it back up because I was looking for similar info.
    Hunt/Taco likes this.
  6. Feb 1, 2020 at 6:20 PM
    mayday
    Central Coast, CA
    How would removing the ABS Fuse impact the rest of the breaking system. My light comes on intermittently and really serves no purpose on this 5 speed. I’ve done a break flush 3 months ago and checked all the sensors. I’m waiting for the light to come back on and get a code. I tried to run a diagnostic test with a friends code reader and nothing came up. Suggestions?
  7. Feb 1, 2020 at 9:42 PM
    Dufus
    Located in Colorado
    Have you inspected your pads and rotors? Does it happen all the time or maybe more often when it's cold or raining?
  8. Feb 1, 2020 at 9:51 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Removing the fuse is fine, the brakes will work like a non-ABS system, just with longer lines and more fluid due to the extra length in lines.
    If you want to control ABS on/off without pulling a fuse, check out my thread. https://www.tacomaworld.com/threads/abs-disable-on-the-fly-no-removing-fuses.592588/
  9. Feb 1, 2020 at 11:33 PM
    Tacoma1997White4x4
    Tacoma1997White4x4 America First
    West Covina, California
    1997 white 4x4 auto 4cylinder Singlecab, 2001 auto rwd 2.4l single cab flatbed
    Km3’s 31’s,Lift,Sliders,rear ARB air locker,on board air, armor, hi shell
    Call dealer and give them your vin, some have it some dont, I dont, only tech I trust is my eyes and if those fail me then I should get the hell off the road
  10. Feb 2, 2020 at 8:10 PM
    mayday
    Central Coast, CA
    It happens once in a blue moon when there is moisture on the road or I am pulling a steep hill. I have inspected my pads and rotors and no dice. I'm thinking about trying to eliminate the problem all together.
  11. Feb 3, 2020 at 7:37 AM
    Dufus
    Located in Colorado
    I see it happen quite frequently with moisture, cold or pulling long or steep hills like you say. When the ABS light comes on, does it straight say 'ABS' or does it say abs with a circle around it inside parenthesis (just curious)?
    Also, I don't think a code will pop up for the ABS light, only the CEL.
    If it were me and I knew my brakes were operating correctly and I couldn't stand that light popping up anymore, I wouldn't pull any fuses, I'd probably just pull the light bulb like someone else said.
  12. Feb 3, 2020 at 12:49 PM
    mayday
    Central Coast, CA
    The ABS light just comes on and turns off after I shut the truck off. It’s knowing that something is turning the light indicator on is whats bothering me.
  13. Feb 3, 2020 at 2:30 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    My 2001 limited DC does not have ABS. So I don't get how some do and some don't.
  14. Feb 3, 2020 at 5:35 PM
    Dufus
    Located in Colorado
    Since you recently flushed it, I would try giving them another bleed. Maybe there's some air caught in there? Make sure to use a pressure bleeder. Other than that I really don't know that much about diagnosing the ABS light.
    mayday likes this.
  15. Feb 4, 2020 at 5:08 AM
    #35
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Here is what I did with my ABS:
    https://www.tacomaworld.com/threads/abs-delete-2001-2004-tacoma.377243/
    Stops on a dime now. Good luck.
