ABS Kill Switch mod for 05+ Offroad EASY WAY! (PICS)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crom, Aug 7, 2011.
  1. Jan 12, 2013 at 5:39 AM
    #181
    Milowilli
    Milowilli Milowilli
    Miles
    Naples FL
    05/ 07,09/11Tacoma access cab 4x4
    No I just cut the wire and extended both ends to a switch on the dash. Bare on mind that this is a 2009 TRD SPORT WITH VSC AND NO ATRAC. Not sure what year your truck is..let me know. I don't like grounding wires for obvious reasons!!! A cut wire is easier to fix than burning or damaging electronics and popping fuses.
  2. Jan 12, 2013 at 7:10 AM
    #182
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    Thanks for your reply Milowilli!!! I have been asking around in other threads, and even started my own trying to get good feedback.
    I think the ground is what the issue was. I have a 2011 Sport w/ VSC, but the wiring should be the same, as is pretty much everything else on the '9-'11 models.
  3. Jan 17, 2013 at 7:29 AM
    #183
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    *UPDATE*
    So I successfully did the ABS kill mod, and the Yellow-Wire mod.
    Thanks to Milowilli for pointing me in the right direction. Cut the Light Green wire, and connect it to a SPST On-Off switch. No grounding necessary EASY!!!
    I took some pics, and will incorporate a more detailed description in the thread I started while I was researching how to do both mods (ABS Kill / YWM).
  4. Jan 18, 2013 at 4:13 AM
    #184
    Milowilli
    Milowilli Milowilli
    Miles
    Naples FL
    Are you able to cycle it on the fly??
  5. Jan 18, 2013 at 9:10 AM
    #185
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
  6. Jan 18, 2013 at 6:36 PM
    #186
    Milowilli
    Milowilli Milowilli
    Miles
    Naples FL
    Don't Mind at all!!! At least you made it clear as day!!! It's such a simple mod. No experimenting grounding wires and blowing fuses for me!!!...and it works on the fly!!!
  7. Jan 25, 2013 at 9:04 AM
    #187
    double_b
    double_b Well-Known Member
    Red Lion, PA
    '14 DCab Tacoma TRD Off Road
    I just tried this mod. 2011 Off Road.......no luck.......I flip the switch and nothing happens. I assume I have a bad switch or connection. Not sure. No time to test as I am leaving for a trip to camp. Oh well.....have to mess with it later...shitty thing is I will hit snow.
    I soldered the wires to the switch and used the same Tap and crimp connectors the OP did. Maybe my switch is bad??
  8. Jan 27, 2013 at 3:13 PM
    #188
    claymore
    claymore Well-Known Member
    Clay
    ABQ New Mexico
    2012 Offroad
    TRD cat back exhaust, console vault(for my little friend),Pop and Lock, Bak Flip G2, Weather Tech window covers, LED inside and out, DTRL Anytime, Grillcraft Grill, BAMF Light Bar with Hella 500s and Blitzpro 15D, Eibach with 5100's all around set at .85 and top plate spacers, LR UCA's, toytec 2" add a leaf, Duratrack 285 75 16, ABS kill switch, Aux reverse lights, Blue Sea Aux fuse block, ImMrYo Bracket, LED Bedlights, Ultra Gauge,
    Just completed this on 2012 Offroad. Tested it, and it works great! Very nice and easy mod. Thanks Crom! :D
    GilbertOz likes this.
  9. Jan 27, 2013 at 8:48 PM
    #189
    mk7
    mk7 Well-Known Member
    Michael
    Austin, TX
    '11 4x4 TRD Off Road
    Great mod, I'm going to do this someday.
  10. Feb 28, 2013 at 8:27 AM
    #190
    Crom
    Crom [OP] Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    You're welcome.
    Benson, I've modified the OP in my thread to link to your writeup for NON-Off Road model trucks, to better help people and cut down on confusion.
    Thanks for helping. :thumbsup:
  11. Feb 28, 2013 at 8:31 AM
    #191
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    subbed. might do this. Although my ABS doesnt seem to act up on me.
  12. Mar 3, 2013 at 12:59 PM
    #192
    OffRoadAdam
    OffRoadAdam Whitey taco woot woot
    Adam
    New Hampshire
    2011 Tacoma TRD Off Road white
    Bull Bar on front bumper, PIAA fogs, Bed cover, custom built removable back rack, anytime fog light mod, Upgraded super white bulbs in headlights and fogs, aftermarket stereo and added subs, OEM roof racks Billy's all around, eibach coils, cooper discoverer at3 285/70/R17'S on Moto metal 957's, ABS kill switch, K&N 77 Cold Air Intake, Stubby 13' Antenna
    this only work in 4wd? i just did the mod and dont have any abs light coming on the dash when i flip the switch...hmmm
  13. Mar 3, 2013 at 3:29 PM
    #193
    OffRoadAdam
    Adam
    New Hampshire
    well the wiring is very simple (im an electrician =P) im thinking the t-splice thing i used was crap and didnt actually dig into the wire and make a connection. thanks for the info!
  14. Mar 3, 2013 at 4:30 PM
    #194
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    Crom, you da man. Awesome write up. Works perfect! You should do the Locker anytime mod and do your perfect write up for that.;)
  15. Mar 25, 2013 at 4:29 PM
    #195
    TanaTaco
    TanaTaco Well-Known Member
    James
    Montana
    05 TRD Offroad 4x4
    OME complete kit with dakars, LR UCAs, Seat covers, weathertechs, anytime foglight mod, ABS kill switch, locker anytime mod, powered sub, halos, leer topper, aux/ipod hookup.
    Well I just got finished doing this mod and the ABS, locker, and check engine light came on. My question being does anybody know why the check engine light came on? I will plug in a scanner tomorrow to see what code comes up but i was just curious if anybody else has had this same problem. Oh and I also did the anytime foglight mod today if that helps at all.
  16. Mar 25, 2013 at 6:57 PM
    #196
    TanaTaco
    James
    Montana
    05 TRD Offroad 4x4
    Nevermind just took it for a ride to test the new ABS system, light cleared and it works flawlessly! highly recommended! Lets hope this wont happen again now.
  17. Mar 26, 2013 at 5:09 PM
    #197
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    I guess I'm lucky not to have abs on my 2002 TRD 4x4.
  18. Apr 22, 2013 at 11:04 AM
    #198
    Codyj8
    Codyj8 Shit'll buff out!
    Cody
    Hardin, MT
    01 Silver Tacoma 6'' lift on 35's
    Uniden CB, 5" Firestick, Allpro tube bumper, homemade rear tube bumper, Fuse pannel, Zeus 20in lightbar, zeus led pods, 9500lb Superwinch, LED turn signals, LED tail lights, Husky toolbox with LED break lights, Rhino lined bed/bottom pannels of truck, tinted windows, Grey wire mod, Undead Offroad rock sliders, 35in Goodyear Kevlars, 15in steelies (black)
    I want to do this on my 01, can anyone steer me in the right direction?
  19. Apr 22, 2013 at 11:17 AM
    #199
    sirwillysc
    sirwillysc Well-Known Member
    Will
    Columbia SC
    13 Tacoma Dbl Cab TRD Off Road
    Debadged destickered
    this is a great mod and loos pretty simple if you can just get to the area! Just so there is no confusion.
    Rear Diff does not engage but does this mean that I cannot engage it if I want?
    and can I still turn trac off or is it already off?
    All I can think about is the times that I have just wanted to do some donuts and cant ever be spur of moment because I have to stop and turn all the crap off then when wanting to stop in mid donut the damn abs makes me almost run into crap!!!
    And does it work on 13
  20. May 10, 2013 at 2:19 PM
    #200
    musicjunky
    musicjunky Member
    NorCal
    11 Tacoma Off-Road
    I've been wanting to do this for about 6 months after getting ran off the road in some snow and almost rolling my truck into a ditch. Finally got around to doing the mod today and it works like a charm! '11 TRD-OR
    Thanks for the write-up!
