Accelerating issue/ vibrations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RubberTank, Jun 19, 2012.
  1. Jun 19, 2012 at 6:12 PM
    RubberTank
    RubberTank [OP] Well-Known Member
    Thousand oaks, CA
    so recently I have noticed an issue with my truck thats now getting to the point where its unbareable. For some reason when I accelerate my whole truck shakes and vibrates, but its only when I give it some gas, if I press the accelerator lightly it doesn't do it and as soon as I let off the pedal it goes away completely. I was recently hit me on my front bumper, the person only hit me doing 5mph so I dont think it has to do with that, tho it seems worse since the accident.
    I only have a 1.5" lift in the front and have 265/70/17. I had my tires rotated, balanced, and an alignment about 2 months ago also.
    Im a 2007 DCSB Prerunner.
    Any ideas on where I should start troubleshooting or what the problem could be?
  2. Jun 19, 2012 at 9:06 PM
    RubberTank
    Thousand oaks, CA
    bump.... Need some advice.
  3. Jun 19, 2012 at 9:18 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Check the u-joints. Once the bearings go bad it will make it vibrate like no other. How many miles does your truck have?
  4. Jun 21, 2012 at 10:16 AM
    John D
    John D Active Member
    Johnny D.
    Lawrenceburg Tn.
    2012 PreRunner
    Fog lights on anytime.
    Mine has done this from day one! If I start off fast it will viberate, If I start off easy it does not!
    I have asked dealer about this and they say it is normal, all of them do this.
    So far no one knows much about this problem! I only have 1700 Miles on it. I have the 6 clinder. John D.
  5. Jun 21, 2012 at 10:31 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    On the 2007 Prerunner I'd have a good mechanic look it over real good especially the motor and transmission mounts. Look at the engine and have someone race it up it several time. Engines will move under hard acceleration and maybe it's touching something, like the fan blade just touching something which you feel as a vibration. While 5 mph may seem slow it can do damage especially on newer vehicles designed to crumple.
    John D maybe ask the dealer to let you drive another for comparison.
  6. Jun 21, 2012 at 5:37 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Sorry, not one of the experts about this, but this will bump it to the top, so maybe one of them will chime in.
    Meantime, I'll contribute some I've picked up from reading some threads here.
    Front Lift is a less common cause of Vibration than Rear Lift, I believe
    Read up on "Axle Wrap". Torque causes your axle to rotate.
    The only thing holding your axle from rotating (besides being attached to your drive shaft) is your rear leaf spring "U-bolts".
    I recently read a thread about under-torqued Ubolts, HERE.
    Also a Video of Axle Wrap, HERE
    There's probably more if you search
    Check your U-Bolts.
    Also, if your running a stock 3 leaf spring pack and they're old, they may flex more, allowing the axle to rotate more.
    Just a couple of thoughts
    Remember, the "Search Function" is your friend.
    Search and read up on vibrations
    I hope I haven't misled you with any misinformation.
    But if I have it'll be a :crapstorm:
    The experts will be sure to let me know
    Good Luck
    CC
  7. Jun 21, 2012 at 5:38 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
  8. Jun 23, 2012 at 4:38 PM
    Asgard
    ^^I was actually referring to the OP's post. You have a brand new truck so your u-joints are good.
  9. Oct 27, 2012 at 11:30 AM
    mibpf
    mibpf Active Member
    Texas
    12 Tacoma 4x4 4 TRD
    I took my 2 month old Tacoma in today to have the vibration issue analyzed. I get vibration upon acceleration until the speed reaches 20 mph. You can feel it in the steering wheel, floorboard and drivers seat. The dealer did confirm their is vibration but they had to open up a special case with Toyota Engineers so they can receive guidance from them to determine a path forward. I was told I will be contacted Monday after the dealer talks too Toyota. I am concerned since the dealer did no have a fix. I am keeping my fingers crossed.
