Adding blindspot monitor?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by digidan2017, Aug 13, 2017.
  1. Aug 25, 2017 at 11:06 AM
    #41
    1993t100
    1993t100 I’m good looking and I drive a Jeep.
    Big Sexy
    Nebraska
    Jeep Wrangler Rubicon
    Never had a problem with my little $2 stick on mirrors :confused:
  2. Aug 25, 2017 at 11:25 AM
    #42
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    Get aspherical mirrors from @SMKYTXN, they're great.
  3. Aug 25, 2017 at 3:02 PM
    #43
    rjacobs
    rjacobs Well-Known Member
    I just ordered both of these mirrors for my double cab. Should get them early next week and installed. I actually dont have a huge issue with the driver side as a quick head turn gives me a good view, but my passenger side I have always felt has been an issue. I will install both and see how I feel. I may swap back to the normal drivers side... who knows.
  4. Aug 25, 2017 at 7:20 PM
    #44
    digidan2017
    digidan2017 [OP] My New 2020
    Mequon, Wisconsin
    2020 Black Tacoma 4x4 TRD Sport - Access Cab - Manual
    I first had tried the little $2 mirrors and was not happy with them. Actually I tried two different kinds of them from different manufacturers. The fisheye distortion, and double image between the original mirror and the fisheye, were too distracting for me. Too much to try and look at from afar (especially passenger side), seemed like I was trying to decipher too many dimensions at once (in a split second), especially at night they were awful. The little fisheye was nothing but lights and movement at night.
    So I did try the little mirrors, aiming the sideviews as is, to see the blind spot and did test drive a vehicle with the RAV4 mirror. For me there was no comparison. The RAV4 mirrors gave me a perfect and clear view of everything. Mission acomplished! Been an interesting discussion though, seeing the different solutions.
  5. Aug 25, 2017 at 7:23 PM
    #45
    TacoTruck808
    TacoTruck808 Well-Known Member
    Oahu in the Aloha State!
    2016 Tacoma TRD Sport DCSB, Prem & Tech Pkg, MGM
    Glad you found a workable solution. I definately would get those rav4 mirrors if i didnt have the BSM. I would even get them if they had those same rav4 mirrors with the BSM light.
  6. Aug 30, 2021 at 11:54 AM
    #46
    ShellyStC
    ShellyStC Active Member
    Michelle
    Oakland, CA
    2017 Toyota Tacoma SR5 Access Cab
    Hi all, reigniting this thread to see what the best solution is here several years later. I have a 2017 Tacoma with access cab and want a blind spot solution. Ideally with the BSW lights but that doesn't seem like an option. Is replacing the mirrors with these still the best option? https://www.amazon.com/Genuine-4Runner-Conversion-87961-42D20-87931-42D50/dp/B086XK3SGX
    Just checking in before I purchase in case there has been an advancement since this thread died.
  7. Aug 30, 2021 at 12:35 PM
    #47
    I.eat.tacos
    I.eat.tacos Well-Known Member
    Steve Rogers
    '18 TRD 4x4 Sport
  8. Aug 30, 2021 at 1:06 PM
    #48
    ShellyStC
    Michelle
    Oakland, CA
  9. Aug 30, 2021 at 2:08 PM
    #49
    I.eat.tacos
    Steve Rogers
    '18 TRD 4x4 Sport
    I think there’s nothing new on the market for what you’re seeking.
    Your welcome.
    ShellyStC[QUOTED] likes this.
  10. Aug 30, 2021 at 3:16 PM
    #50
    tacobelletx
    tacobelletx Well-Known Member
    TX
    '18 Sport ACLB
    I've seen people mention the spotter mirrors. I do not have any personal experience with them though, just figured I'd mention them for you to look into (currently out of stock, but says restock Sept. 2021).
    https://spottermirror.com/p/toyota/spotter-mirror-for-2016-2020-toyota-tacoma-w-bsm/
  11. Aug 30, 2021 at 3:22 PM
    #51
    mattsolnitzky
    mattsolnitzky Well-Known Member
    2021 TRD Sport
    Used to have a CR-V that had this (camera), but only on the right side. They also subsequently got rid of the feature on later models. It was actually a really nice and very useful feature.
  12. Aug 30, 2021 at 3:30 PM
    #52
    ShellyStC
    Michelle
    Oakland, CA
  13. Aug 30, 2021 at 8:42 PM
    #53
    rick carpenter
    rick carpenter Well-Known Member
    Rick
    Huntsville, East Texas
    2019 SR5 2wd v6 DCLB for the win!
    I've got Spotter mirrors on my SR5. They're not the answer to all problems but I'd rather have them than not. About $160 (without the BSM) well spent.
    The cons are they're convex so everything you see in them is way smaller. Basically, without having to decipher what you see in them, if they're adjusted correctly and something is larger than a peanut then that something is closer than you think. Also, if after a while you ignore them when looking in the 'stock' part, an approaching vehicle can disappear. The pros are, though, after a while you're able to ignore them when looking in the 'stock' part. You only see them when you force yourself to look into them.
    But... I always shoulder check too unless I know any vehicles on either side of me are well in the distance.
  14. Aug 31, 2021 at 1:34 AM
    #54
    tacobelletx
    TX
    '18 Sport ACLB
    Well darn, I didn't even pay attention to the model compatibility. But from the review above it doesn't sound like they are any better than other cheaper options out there... just no bsm compatibility.
  15. Aug 31, 2021 at 7:23 AM
    #55
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    I put the stick on blindspot mirrors on about every vehicle Ive owned except for my current 2019 tacoma because it has the BSM. Took some time to trust and get used to and there is always the possibility of thinking its on when it accidently got turned off.
    The last set of mirrors I used I got from Amazon. They were nicer than the typical cheap ones auto parts stores sell. And they are thinner and look better almost like factory.
    Something along the lines of these;
    https://www.amazon.com/GotoShop-Puz...ords=blindspot+mirrors&qid=1630419401&sr=8-14
    ShellyStC likes this.
  16. Aug 31, 2021 at 7:58 AM
    #56
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Get wide angle mirrors and adjust them properly. Also adjust your seating position.
  17. Aug 31, 2021 at 8:20 AM
    #57
    Steve Armstrong
    Steve Armstrong Well-Known Member
    SoCal
    2021 TRD Sport DCSB
    DAS Taco and ShellyStC like this.
