Adding tow Towing Receiver Hitch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dre22, Mar 23, 2009.
  1. Mar 23, 2009 at 11:51 AM
    dre22
    dre22 [OP] Member
    White Plains NY
    ARB Bumper Supertop Bestop AUX. Lights
    I'm adding the hitch and wiring harness on my 09 taco double cab v6 4x4. I saw that the trucks that came with the tow package have an alternator of 130amp. All the parts I got are from Toyota.
    I got the 7-pin to 4-pin and 2" ball with mount
    Is that all the parts, that I need to install on the truck?
    :burnrubber:
  2. Mar 23, 2009 at 12:04 PM
    Brunes
    Brunes abides.
    Rotorhead
    There is an oil cooler, trans cooler,heavy duty battery, and the heavy duty alternator that go with the towing package. I'm not sure if there are any differences between the suspension hardware...but that oughta cover it.
    I wouldn't expect to be covered by Toyota if you try to tow in excess of your rated weight from when you purchased the truck...
  3. Mar 23, 2009 at 12:27 PM
    dre22
    dre22 [OP] Member
    White Plains NY
    Thanks, 4 the INFO.
    I'm not planning to tow any thing heavily, one ATV. It should be all good
  4. Mar 23, 2009 at 2:13 PM
    JONNY TACO
    JONNY TACO Well-Known Member
    PA.
    DARK METALLIC GRAY -DOUBLE CAB SHORT BED
    ADVANTAGE TONNEAU COVER,TOYOTA BED LINER, POP&LOCK TAILGATE LOCK, SIDE TUBES, WIFE IN PASSENGER SEAT
    Depending on what you are towing- you may NOT need any of the above. I towed a 16 ft boat with a Dodge Caravan and had no issues. My Tacoma is more than up for the task. Add the above only if your towing really heavy.
  5. Mar 23, 2009 at 3:16 PM
    Hardcorehehaw
    Hardcorehehaw 1 man wolf pack
    Evan
    09 Magnetic Gray PreRunner
    Debadged, 20" Liquid Metal Magmas, Yokohama Parada Spec x 285/50/20, Llumar clear bra, Fold-A-Cover G4, Weathertech liners, Wet Okole seat covers, JBS technologies keyless entry keypad.
    Are you adding a hitch or just a bumper ball?
    I know you said hitch but then you said 2" ball with mount. I guess you mean the receiver?
    Is so, how much was the hitch, I want to get one too. I know they're like $140 on ebay without the wiring harness.
  6. Mar 23, 2009 at 3:48 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    There isn't a need for trailer brakes. They are nice to have, but not necessary. I tow a 4000 pound bass boat without trailer brakes & never have any problems.
    Downshifting the automatic to 4 then 3 helps for sudden stops.
  7. Mar 23, 2009 at 5:44 PM
    dre22
    dre22 [OP] Member
    White Plains NY
    hitch
    could I put a tranny cooler on a 6 speed?
    I'm try to make it look stock
  8. Mar 23, 2009 at 5:52 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    You dont need a transmission cooler on a manual :)
  9. Mar 23, 2009 at 5:55 PM
    JONNY TACO
    PA.
    Check out JC Whitney for hitch prices- their shipping was cheap.
  10. Mar 23, 2009 at 6:48 PM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    I believe the fan clutch is also different.
    Marc M
