Addition D Rings - Bed Side Alternative Solution
Discussion in '2nd Gen. Tacomas (2005-2015)' started by steveo27, Mar 28, 2017.
  1. Mar 28, 2017 at 9:28 PM
    steveo27
    steveo27 [OP] Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    I was looking for something the other day and came across this picture.
    I really like this idea vs drilling holes in the bed sides to add more D rings.
    Granted these arent going to be as strong as a steel plate backed D ring, but this idea would be more than sufficient for things like a cargo net and strapping down plastic totes.
    Is this a member on here or does someone recognize this mod? I was looking for some more info on this, specifically the size of the D rings used and where they were purchased?
    Cheers
    Sidney Vicious and LEXICON like this.
  2. Mar 28, 2017 at 9:38 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
  3. Mar 28, 2017 at 9:44 PM
    the dashing ham
    the dashing ham Taco n00b
    Scotty
    Los Angeles
    '12 DCLB rattle can
    yes, I have done the mods
    I've done this mod, it's super easy. Unscrew the screw, slide the d-ring back there, re-screw the screw. I got my d-rings from army surplus warehouse, but they don't seem to have a listing for them anymore. Similar ones are out there.
    But here's the monster thread you should read through:
    Installed D-Rings in the Bed Pics
    It's got a ton of different installs and sources for D-rings. The behind-the-rail rings I think first appeared here.
    TacoEspecial and IronPeak like this.
  4. Mar 29, 2017 at 6:32 AM
    steveo27
    Pittsburgh
  5. Mar 29, 2017 at 6:33 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    I have these also, great to attach the cargo net when loaded for camping :thumbsup:
  6. Mar 29, 2017 at 7:59 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Are they mounting to anything solid, or just the composite bed?
  7. Mar 29, 2017 at 9:50 AM
    steveo27
    Pittsburgh
    They're mounted into the same piece the track is mounted into I'd imagine they'd hold close to the same weight the track can.
    Would I strap a motorcycle to them? No
    Would I strap a plastic tote with camping gear to them? Yes.
  8. Mar 29, 2017 at 10:09 AM
    Naveronski
    Fort Worth
    Seems reasonable. Might have to pick some up.
    How many did you install?
  9. Mar 29, 2017 at 10:17 AM
    steveo27
    Pittsburgh
    I plan on installing 1 at every bolt on the track, not sure how many that is yet as I need to count em to see.
  10. Mar 29, 2017 at 10:24 AM
    IronPeak
    AuggieX
    Back to Back
    They rattle a little FYI there may be a zip tie solution somewhere in the thread noted above. I shot mine with a little extra black paint to make them "sticky" when they swivel.
  11. Mar 29, 2017 at 10:36 AM
    steveo27
    Pittsburgh
    I did see his while searching
    I'd do something similar, but probably with some sort of rubber or vinyl tubing
  12. Mar 29, 2017 at 10:38 AM
    IronPeak
    AuggieX
    Back to Back
    Be aware that if you choose to add these to the bed bolts it is a little more involved, and there is a dodge d ring that eliminates these issues.
  13. Mar 29, 2017 at 11:48 AM
    steveo27
    Pittsburgh
    Just doing it along the rails.
    IronPeak likes this.
  14. Sep 30, 2017 at 9:06 AM
    LIazard
    LIazard Well-Known Member
    Tacoma don't own one yet
    Any ideas or a link for where the Dodge d-rings can be found to install d-rings in the Tacoma bed bolts (the unpainted star drive bolts) without grinding away at the washers?
  15. Sep 30, 2017 at 9:06 AM
    DrFunker
    DrFunker Well-Known Member
    Bought mine through Mopar, I believe.
  16. Sep 30, 2017 at 9:11 AM
    DrFunker
