Advantage/Dis-Advantages of welding vs. bolt-on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SPORT, May 6, 2011.
Do you prefer to bolt-on or welded rock sliders? Why?
Poll closed Jun 5, 2011.
  1. Weld the damn thing on! It ain't going anywhere.
    49 vote(s)
    45.4%
  2. Bolt on for easy removal/replace
    39 vote(s)
    36.1%
  3. Glued on. huh? (Elmers)
    20 vote(s)
    18.5%
  1. May 6, 2011 at 2:50 PM
    #81
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    It's already pretty crowded in there. Hope you like company! ;)
  2. May 6, 2011 at 2:55 PM
    #82
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    I did both welded and bolted!
  3. May 6, 2011 at 2:55 PM
    #83
    mjp2
    NJ
  4. May 6, 2011 at 3:00 PM
    #84
    Hoyal
    Devin
    2013 Tundra
    Damn I should have!! :D
    No I have demello hybrid bolt ons I drilled the frame bolted then welded the plate.
  5. May 6, 2011 at 3:06 PM
    #85
    mjp2
    NJ
  6. May 6, 2011 at 3:08 PM
    #86
    mjp2
    NJ
  7. May 6, 2011 at 3:08 PM
    #87
    Hoyal
    Devin
    2013 Tundra
    Damn it! That means I have to redo it. I will and post up results ASAP!
  8. May 6, 2011 at 3:10 PM
    #88
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Ok...I read thru a little of this, and the conclusion I have come to is (correct me if Im wrong), DHK wants bolt on sliders, but using existing holes. Despite the holes not being drilled for aloowing the slider to have the propper leverage advantage. Welding on the frame turns it into a pomagranite......or the like.
    My thoughts. DHK has more mood swings than a lady going thru menopause.
    If welding on a frame is bad, about 50 million people need to be informed of this, and I should contact some friends about it. They are going to be SHOCKED to hear the shit they welded on their frames years ago, can cause the frame to crumble at any time.....
  9. May 6, 2011 at 3:16 PM
    #89
    Hoyal
    Devin
    2013 Tundra
    :goingcrazy:So your saying that I am not safe on the road because I welded to my frame? OMG
  10. May 6, 2011 at 3:18 PM
    #90
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    DHK is. Sadly, My frame is doomed as well. I welded about 4 points on it to mount my fuel tank skid....:(
  11. May 6, 2011 at 3:20 PM
    #91
    Hoyal
    Devin
    2013 Tundra
    Ill be sure to post up when my frame crumbles into pieces. Although Im sure it may out live me.
  12. May 6, 2011 at 3:21 PM
    #92
    mjp2
    NJ
    I'm doomed because of all the places my rollcage, suspension components, and engine mount gussets are welded to my frame. :pout:
  13. May 6, 2011 at 3:23 PM
    #93
    Hoyal
    Devin
    2013 Tundra
    You should bubble wrap your truck now its the only way to truly be safe!
  14. May 6, 2011 at 3:40 PM
    #94
    NewMexiTaco
    NewMexiTaco Abron Cabron
    Abraham
    Santa Fe, NM
    2007 4x4 DC LB TRD Sport
    Weathertech mats; Wet Okole seat covers; Kobalt Lowpro truck box,(sitting in the shed) Snugtop Hi-liner camper shell; AFE Pro Dry air filter, Tailgate Hoseclamp mod; 5100s all around, Light Racing UCAs, OME 885 coils, OME Dakar Leafs, CB Drop, Driveline spacer. Epoxy Satoshi; Redline Hood Struts. 4x Mil Spec. bed D rings; Brute Force Fab custom DCLB Hybrid Sliders, ARB w/ Warn M8000 wench, Diff Breather mod, Alpine Deck w/ ipod cable. Iphone ziptie to rearview mirror 4wd-cam mod!
    :laughing: not a day goes by that I don't learn something new on TW.
  15. May 6, 2011 at 3:45 PM
    #95
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    See above
  16. May 6, 2011 at 4:05 PM
    #96
    is_it_the_shoes
    is_it_the_shoes Well-Known Member
    Tallahassee
    2012 Mini Countryman S ALL4
    i think i want to make that my sig :thumbsup:
    one thing dhk got me thinking though, it would suck to get into an accident, and then have some scumbag lawyer try to link my mods as a cause to something...but i guess thats why i pay my insurance company and let their lawers worry bout it :anonymous:
  17. May 6, 2011 at 4:32 PM
    #97
    AC13JohnG
    AC13JohnG Señor Member
    Black 5 lug
    I honestly stopped reading this around page four. But race car engineering 101: the stronger/stiffer the chassis the more efficiently the suspension can function. There is no such thing as something being too structurally sound if it's held up by some sort of shock absorbing device(ie. the vehicles suspension). This thread is proof a little knowledge in the wrong hands is a dangerous thing; in this case also very annoying.:rolleyes:
  18. May 6, 2011 at 4:43 PM
    #98
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Absolutly! What ever you do...DO NOT Weld Sliders to your house!
  19. May 6, 2011 at 4:44 PM
    #99
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    There is a difference though between something like a race chassis, which was designed to be structurally stiff all the way around, and our truck chassis which were designed to flex in certain locations. If some parts of the frame were strengthened, technically the remainder of the frame is being exposed to forces that it wasn't exactly designed for. It's possible that this can cause a premature failure in the areas of the frame that weren't stiffened. But luckily, Toyota engineers (as all engineers do) use a factor of safety when designing their frames. Adding some metal to the frame by welding on sliders, will not stiffen the frame to the point where there is a serious risk of breaking the frame.
  20. May 6, 2011 at 5:20 PM
    #100
    OZ-T
    Peter North
    British Columbia
    Actually , less rigid is better seismically speaking
