Advice on 3" Lift
Discussion in 'Suspension' started by striker1021, Nov 5, 2009.
  1. Nov 5, 2009 at 3:16 PM
    striker1021
    striker1021 [OP] Active Member
    Phoenix, AZ
    '09 V6 Tacoma 4x4
    RevTek 3" Lift Leer 100XR Cap
    Hey TW, I was wondering if some people could help me out with a 3" I am wanting to get for my tacoma. First off, I have an 09 Tacoma Base Package 4x4 that is fairly new. I want to put a 3" lift on it and was looking at a toytec kit. I have a couple questions with it. First, is this all I need to get in order to get the successful lift for the tacoma? I heard I have to buy some other things (bolts) for the wheels so they aren't tilted in as well as some other items to get the lift I want (3"). The kit I am looking with comes with:
    FRONT: (2) OME 884 standard/light load front lift coil spring
    Also includes ToyTec Top plate spacers for a full 3" front lift & (6) top plate studs
    REAR: (2) 2" lift ToyTec Add-a-leafs by Alcan spring (a long add-a-leaf for the best ride), w/OEM style anti-friction Pads, & new leaf spring center pins
    Is this all I need to get, or do I need to get something else, or should I go with another package? Would I need to get new shocks for this? I am pretty new at all of this so any advice would be great! Thanks TW!
  2. Nov 5, 2009 at 3:17 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    That's a great low cost package, and it would be just fine... ;)
    EDIT: Get the 885 springs for the extra weight of the Double Cab.
  3. Nov 5, 2009 at 3:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Correct. And get new shocks. Either OME N140S, or Bilstien 5100's. The OEM shocks are not up to the dampening demands of the OME springs.
  4. Nov 5, 2009 at 3:40 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    You would need to buy new hub centric rings if you are going to use After Market wheels, other than that what chris4x4 said you will be fine.
  5. Nov 5, 2009 at 3:47 PM
    striker1021
    Phoenix, AZ
    '09 V6 Tacoma 4x4
    Hey, thanks for the quick responses! So if I went with the 885 coils, I would just need to buy the OME N140S shocks for the front (only 2) right? And could I go with the front adj bilstein shocks instead of the OME shocks ($100 difference) or would it matter a lot? Also, with getting the new shocks can I still use coils or would I need to get Coil Over instead? And I think I will be keeping my stock wheels and just painting them black and buy new tires
  6. Nov 5, 2009 at 3:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The OME shocks will give the best ride. Also, you should get 1 "trim packer" for the driver side, to help with the extra weight from the battery, fuel tank, etc. Also, being as your lifting the rear, consider getting new shocks for the back. The OME N182's ride a little softer than the Bilstien 5100's, but they are both a quality shock.
  7. Nov 6, 2009 at 9:04 AM
    striker1021
    Phoenix, AZ
    '09 V6 Tacoma 4x4
    Hey, again thank you for the information. I am thinking about going with this kit now: I would get the 885 coils and the spacers for the front to get the complete 3". Will I need to buy ANYTHING else to make sure the lift works (like other parts for the truck because some parts arent long enough) or will this do it for the lift? Is this a hard kit to self install?
  8. Nov 6, 2009 at 9:53 AM
    NicksRig
    NicksRig Well-Known Member
    Kenora, Ontario
    07 Tacoma DC TRD Sport
    Blacked out Skid plate, block heater, bug deflector, blacked out headlights, tinted fronts, OME 3" lift, Toytec AAL, Revenge-Fab Sliders, K&N Air Filter
    You might want to get some new u-bolts for when you install your AAL.
  9. Nov 6, 2009 at 10:10 AM
    geolink
    geolink Well-Known Member
    SILVER STATE
    09 DCLB MagGray TRD SPORT
    Weathertech mats and hood protector, RuffTuff seat covers, padded console, Redline Hood Struts, Snugtop canopy w/Thule Rack, TSB rear springs plus AAL, 5100's all around OME 885 front coils, LR UCA, Avid Step Bars, LT265/70R17 BFG AT on stock Sport Rims
    You got some good advice from the folks here.
    I am going to add my 2 cents....
    What I do not see mentioned in the thread are after market Upper Control Arms to obtain alignment specs after the lift is installed. Read up on UCA's.
    I have OME 885 Springs seated on the zero setting of the 5100's. My Tires are BFG 265/70 R17. The front fenders sit at 37" above ground.
    The alignment I wanted was 0 Toe, 0 Camber and +2.3 deg Caster. Read up on alinment. You will need one after the lift is installed
    The stock UCA's did not allow the Camber/Caster settings. The truck traveled OK on Highway but I was concerned about tire wear issues.
    I installed Light Racing UCA's and got the alignment right on.
    Some folks say they can adequately meet the alignment specs using the stock UCA's on a 3" lift. You may want to try the lift with the Stock UCA's and see how it goes. Just be aware that UCA's may be required depending on how fine tuned you want your alignment.
    As far as self install, there are threads that step through that process also.
    Pesonally, I had it all done at a tire/suspension shop
    Keep up the good work!
    from the outback....
  10. Nov 6, 2009 at 10:40 AM
    NicksRig
    Kenora, Ontario
    X2 on the UCA's. I also purchased the LR UCAs when I got my OME lift from toytec.
  11. Nov 6, 2009 at 1:52 PM
    striker1021
    Phoenix, AZ
    '09 V6 Tacoma 4x4
    Thanks Nick and Geo! I don't have the money for the ucas but don't want to screw up the lift. Would the ome suspension lift kit with the 885 coils and shocks be enough to get the 3 inch lift and be okay?
  12. Nov 6, 2009 at 2:25 PM
    NicksRig
    Kenora, Ontario
    Yes it would. Thats the set-up I am running.
  13. Nov 6, 2009 at 2:27 PM
    geolink
    SILVER STATE
    Okay is a relative term....
    I do not have that specific lift.
    Suggest you search for threads that discuss that specific kit.
    http://www.tacomaworld.com/forum/new-members/38575-how-use-search-function.html
    Call ToyTec, tell them any concerns you have and get their input.
    There is also a ToyTec Group Buy going on right now. Read through that.
    http://www.tacomaworld.com/forum/to...n-5100-lift-kits-lr-ucas-ends-11-17-09-a.html
    Take you time, read up, get educated, make your decision.
  14. Nov 6, 2009 at 2:29 PM
    geolink
    SILVER STATE
    Guess Nick has your answer!
  15. Nov 6, 2009 at 2:36 PM
    NicksRig
    Kenora, Ontario
    But remember you have to get the spacer with the OME set-up to get a full 3".
