AFFORDABLE KAYAK RACK
Discussion in '4 Cylinder' started by poggyg, May 6, 2012.
  1. May 6, 2012 at 10:32 AM
    poggyg
    poggyg [OP] Member
    British Columbia
    Tacoma 2010 4x2
    Other than expensive Thule, thoughts on kayak rack in truck bed witn rail system? thanks y"all.
  2. May 6, 2012 at 12:19 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    I would think that 2 inch PVC pipe and "Y" connectors would work well. You could secure the vertical uprights to the rail system. You could even spray paint the PVC the color of your truck.
  3. May 6, 2012 at 5:11 PM
    poggyg
    poggyg [OP] Member
    British Columbia
    Tacoma 2010 4x2
    thanks--the PVC seems a cheap thing to try!!
  4. May 6, 2012 at 5:11 PM
    poggyg
    poggyg [OP] Member
    British Columbia
    Tacoma 2010 4x2
    :)thanks--the PVC seems a cheap thing to try!!
  5. May 6, 2012 at 7:50 PM
    wolftree
    Rick
    Ohio
    I have thought on this a bit. I think will need some sort of tie/spreader connecting the two vertical uprights if you only connect at the bedrail. This will keep the the verticals from pivoting. This can be PVC as well.
    Dry fit the pieces to insure fit before gluing. Once glued you will not be able to take it apart and will have wasted material.
  6. May 10, 2012 at 3:47 PM
    IKMtacoma
    IKMtacoma Well-Known Member
