After market hood
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rujack, Feb 22, 2018.
  1. Feb 22, 2018 at 12:21 PM
    Rujack
    Rujack [OP] Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Just curious. I haven’t even looked at my truck close enough to know if this work - that is, clear the engine, radiator, grille, etc. But wondering if anyone has seen an AM hood that you can actually see over. Damn near can’t see a thing coming over hills.
    They designed this thing so that when you hit someone it doesn’t injure them as badly. The trade off is you’re more likely to hit someone. Gvmt logic.
  2. Feb 22, 2018 at 2:30 PM
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    what is an "AM hood"?
    Is that the hood that you only use in the morning?
  3. Feb 22, 2018 at 2:33 PM
    SirRoytzz
    SirRoytzz Taco Enthusiast
    Get a front approach camera. Problem solved. Pretty inexpensive too.
    tonered likes this.
  4. Feb 22, 2018 at 2:36 PM
    Rujack
    That was my abbreviation for aftermarket.
    vuTron[QUOTED] likes this.
  5. Feb 22, 2018 at 2:44 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is what I did. Also, an AM hood won't help with the height of the grille or grille surround. I like the big radiator but do wish the sight could have been lower.
  6. Feb 22, 2018 at 7:05 PM
    Rujack
    Cost of camera??
  7. Feb 23, 2018 at 12:10 AM
    SirRoytzz
    Setup can be anywhere from probably 60 to 200. I got one on eBay which is pretty much plug and play (a little crimping required) for 160 which turns on by using the hang up call button for 2 seconds
  8. Feb 23, 2018 at 4:39 AM
    House Forsaken
    House Forsaken Well-Known Member
    Paul
    2015 Tacoma TRD Off Road (Traded) 2017 TRD Off-Road (Traded) 2018 TRD Off-Road
    Was it this one? https://www.ebay.com/i/152676042678?chn=ps
  9. Feb 23, 2018 at 7:10 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Rujack[OP] likes this.
  10. Feb 23, 2018 at 7:11 AM
    samwoo2go
    samwoo2go Well-Known Member
    SoCal
    2018 Taco TRDOR DCSB Cement
    Agree with front camera approach.
    tonered likes this.
  11. Feb 23, 2018 at 7:34 AM
    Rujack
    Nice, thx. What’s install time?
    tonered likes this.
  12. Feb 23, 2018 at 7:46 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The vent surround pulls off and the head unit is held in by four 10mm screws. From there, it is just a matter of plugging in and routing the leads. With the camera and such, I might have 3hrs in it? The hardest part was routing the cam harness through the firewall as the grommet is up high (tight access).
    In the end, just the harness eliminating the frustration of functions not being available while moving is more than worth it. I felt it was almost unsafe since I had to look over often to tell if I was just not hitting the right spot on the screen or it the function was being locked out.
    Rujack[QUOTED][OP] and vuTron like this.
  13. Feb 24, 2018 at 5:19 PM
    Rogues Gambit
    Rogues Gambit Well-Known Member
    Colts Neck, NJ
    '07 A4, Planning on ordering soon
    Gonna hijack this for a min
    Any vented hoods out there anyone recommends
  14. Feb 24, 2018 at 5:30 PM
    9TRDTCO
    9TRDTCO Well-Known Member
    RkSport, love it.
    Rogues Gambit[QUOTED] likes this.
  15. Feb 24, 2018 at 5:31 PM
    Rogues Gambit
    Colts Neck, NJ
    Ty!
  16. Feb 24, 2018 at 5:33 PM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    Just remove your hood. Problem solved
    Rujack[OP] and TeecoTaco like this.
  17. Feb 24, 2018 at 9:15 PM
    SirRoytzz
  18. Feb 24, 2018 at 9:56 PM
    darkoe671
    darkoe671 Active Member
    Adrian
    2017 Tacoma OR Quicksand
    Stock for now
    :drunk: If this is true do they have an all day hood? Maybe all weather?
  19. Feb 24, 2018 at 9:57 PM
    Tracoma17
    Tracoma17 Well-Known Member
    Travis
    2017 Black Tacoma Limited
    Tinted windows, Clear Bra, running boards
    Do you have a sport hood? I’m wondering why you can’t see?
  20. Feb 25, 2018 at 8:20 PM
    Rujack
    Bc the center section of the hood is so high
