ajohnson's horunner
Discussion in '4Runner Builds' started by ajohnson, Jun 9, 2012.
  1. Apr 18, 2013 at 11:37 AM
    #761
    ajohnson
    ajohnson [OP] Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    There is plenty of clearance in the tunnel now. I used a strap to pull the tunnel open. I watched the stick shake and vibrate out of gear when I let off the gas. I pulled the boot off and no more vibrating out of gear, so I need to mess with the detent spring. It shifts out of gear too easily.
  2. Apr 18, 2013 at 2:25 PM
    #762
    Boomtacoma01
    Boomtacoma01 Well-Known Member
    Houston
    Definately check that detent ball and spring. If they are the stock springs you should change them out with a set from TG or Marlin.
  3. Apr 18, 2013 at 4:12 PM
    #763
    jandrews
    '09 FourDubDee TRD OR
    Injected the driveshaft, shackle bolts, UCA bushings with some grease this afternoon. Lubed the UCA and trac bar uniballs. Complemented the electrical repair kit with a full set of spare fuses. Giving the air filter a wash now. Spare parts and tools are onboard.
    Ready for a little fun?
  4. Apr 18, 2013 at 4:14 PM
    #764
    ajohnson
    Andy
    Charlotte, NC
    Thanks for the advice fellas. I spoke with Dave and he does not feel a HD spring is needed and will only make shifting harder. Well I don't understand this because my shifter is popping out more than Slimwood's pecker. I am pretty certain I need the HD spring.
    I have to drop the drivetrain to reach the spring :(. 10 hour work days and long nights working on this truck have taken its toll, I am just too damn tired to fuck with it right now.
  5. Apr 18, 2013 at 4:15 PM
    #765
    ajohnson
    Andy
    Charlotte, NC
    I have been ready but my truck just does not want to work right.
  6. Apr 18, 2013 at 4:20 PM
    #766
    jandrews
    Fuck it. Just hold the shifter in place while you drive.
    You need to do something in there to keep your hands off your dick anyway :laugh:
    (Dave may be forgetting that your detent spring is fighting two cases worth of shift forks)
  7. Apr 18, 2013 at 4:25 PM
    #767
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    u cant get to it at all while its still installed? with how much u cut out the tunnel, u might be able to get to it from teh top. but def, get to it under neat. i think from lookin at the pics of it out of the 4runner, it looks like the screw right behind the shift linkage on the pass side. thats basically where it is on the fj case just on the other side. i would try to get to it with everything installed before dropping it all
  8. Apr 18, 2013 at 4:36 PM
    #768
    jandrews
    Ah shit, you're right. I went back and looked at the pics. I thought twins were linked to both.
    Perhaps the extra linkage is providing extra resistance? God knows those upgraded springs are out there for a reason. Something's pushing his stick around, and...well, it's not his hand/girlfriend.
  9. Apr 18, 2013 at 4:50 PM
    #769
    wrmathis
    Bonaire, GA
    parts and stuff
    like i said in the earlier post, he might be able to get to it from the top with how much he cut out the tunnel
  10. Apr 18, 2013 at 7:31 PM
    #770
    ajohnson
    Andy
    Charlotte, NC
    Well I went out and messed with it anyway, I got the spring out with less trouble than I planned. I stretched and reinstalled the spring, the 2wd/4wd shifter moved nice and solid, the hi/low shifter didn't move at all, and now neither will move. I can shift the 2wd/4wd rail with a screwdriver with the shifters removed but the hi/low rail won't move. :censored::frusty: I don't know what is wrong. I should have just became a coin collector.
  11. Apr 18, 2013 at 7:35 PM
    #771
    jandrews
    ...This sounds like something is fucked/broken internally. You sure those things arrived in proper condition?
  12. Apr 18, 2013 at 7:48 PM
    #772
    ajohnson
    Andy
    Charlotte, NC
    Okay I am a fucking idiot. I released the e-brake and took it out of gear. I had to slap myself for that one.
  13. Apr 18, 2013 at 7:51 PM
    #773
    jandrews
    I am not exaggerating when I say this is my favorite build thread to follow on this site.
  14. Apr 18, 2013 at 8:03 PM
    #774
    ajohnson
    Andy
    Charlotte, NC
    Haha. I told you I was exhausted. I'm going to sleep before I do any more stupid.
  15. Apr 18, 2013 at 8:11 PM
    #775
    jandrews
    :X
  16. Apr 19, 2013 at 2:50 AM
    #776
    ajohnson
    Andy
    Charlotte, NC
  17. Apr 19, 2013 at 9:42 AM
    #777
    ajohnson
    Andy
    Charlotte, NC
    It is still popping out of gear but hopefully I can bear it through the weekend.
    HD detent spring ordered.
  18. Apr 19, 2013 at 9:49 AM
    #778
    ajohnson
    Andy
    Charlotte, NC
    I couldn't tell if there are 2 springs in there :notsure:. I pulled one out with a magnet and stretched it but it still pops out of gear :(. It doesn't seem as bad though. I ordered 2 Marlin springs.
  19. Apr 19, 2013 at 10:57 AM
    #779
    wrmathis
    Bonaire, GA
    parts and stuff
    on ours the hd spring we get actually fits inside the stock spring. more than likely u only had one spring anyways. im not sure if the gear driven cases use the same hd spring as the tacoma/fj chain cases do. there are 2 different springs on marlin's website for you to buy so i would say they are different
  20. Apr 19, 2013 at 12:26 PM
    #780
    ajohnson
    Andy
    Charlotte, NC
    Ok thanks. I'll do some searching and make sure I do it right.
