allpro bumper questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by francis1291, Jan 3, 2012.
  1. Jan 3, 2012 at 9:26 AM
    francis1291
    francis1291 [OP] Well-Known Member
    10 4x4 SR5 super white
    3" procomp lift wit 20" rockstars on 33 toyo mt's
    Just got the bumper last night and I know I have to get different fog lights but im curious is there any way I can wire them to my original fog lights wire so I can run with just fog lights? Also I have hids and I was curious if there is any way I can use the fog light hids in another fog light? I would like to keep my hids.
  2. Jan 3, 2012 at 10:17 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    some folks have modded to fit the stock fogs very easily. there are threads out there. if the draw is similar to stock, you can wire them to the stock harness and use the stock wiring, circuit, etc. if there is too much draw from the new ones, you may blow fuses, kill relays, burn wires, etc.
  3. Jan 3, 2012 at 10:24 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    my rigid industries plug right into the factory harness...pretty cool if you ask me!!
  4. Jan 3, 2012 at 10:27 AM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    I used the PIAA's that AP recommended and they mount directly to the bumper's fog light mounts but you will need to use the supplied PIAA harness (included with the lights). Like jhodge83 said though, some folks have fabbed up some simple mounts so they can use their factory fogs.
  5. Jan 3, 2012 at 10:31 AM
    The_Hodge
    SC
    i hacked off the ends of the stock harness and wired up my PIAA 510s to those and utilized the stock everything else.
  6. Jan 3, 2012 at 11:09 AM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
  7. Jan 3, 2012 at 12:15 PM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    But you still had to use the relay though, right? I tried the same with my 510's without the relay that came with them and popped the fuse instantly.
  8. Jan 3, 2012 at 1:10 PM
    The_Hodge
    SC
    nope. wired up and that was it. running the plasma ion 510s if that makes a difference.
  9. Jan 3, 2012 at 2:01 PM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Yup, that is the difference. Good info!
  10. Jan 3, 2012 at 2:44 PM
    francis1291
  11. Jan 3, 2012 at 2:47 PM
    francis1291
    Never mind I just clicked your link. But what material do you need
  12. Jan 3, 2012 at 3:12 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    aluminum. and i just used a table vise and hammer to bend it
  13. Jan 3, 2012 at 3:33 PM
    francis1291
    Alright thank you. Do the original fog lights fit just like the PIAA or do the PIAA fit inside the bumper and the original fit towards the rear
  14. Jan 3, 2012 at 3:46 PM
    SplitDecision
    SplitDecision Phones Ringin Dude
    Haywood Jablowme
    NY
    Silver TRD OR
    Bilstein 5100x4, Truxedo lo pro QT,Hid Retro,2011 painted grill,Alpine head unit,Foglight mod,NFAB steps
    Another member made his work with a rubber coupler from home depot and a couple hose clamps.
  15. Jan 3, 2012 at 4:26 PM
    TxCavScout
    TxCavScout New Member
    Wherever Uncle Sam sets me down..
    '11 TRD SP 4x4
    Seabass, switch your wires. IIRC, white doesn't go to white and black doesn't go to black if you are using the original fog light wires and splicing in the 510's. When I installed mine, it kept popping the fuse. I switched the wires W->B and vice-versa and haven't had a problem since.
