Aluminum replacement for plastic rear coolant bypass joint
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jowett, Jan 5, 2021.
  1. Jan 5, 2021 at 2:59 PM
    Jowett
    Jowett [OP] Well-Known Member
    Brian
    North Adams, MA
    Well, well, well, what do we have here? Yup, a rear coolant bypass made of the proper material for the job. Uses MLS gaskets, too. Built to take the heat!
    For the uninitiated, read following links...
    https://www.tacomaworld.com/threads/check-your-3-5l-coolant-pipe.531758/
    https://www.tacomaworld.com/threads/3-5l-rear-water-bypass-joint-leak.651341/
    The good... It bolts up. The temp sensor is correct. The not good... The coolant port for the heater core is in the wrong place. This can be dealt with fairly easily via a hose, by modifying the port outlet, or maybe both. The wire harness mounts are wrong, but look easy to deal with. There is an additional port that will need to be blocked.
    Please note, my application is a 6MT, which has no coolant hoses running to the ATF warmer/cooler. I do not know if this will be an issue on automatic equipped trucks.
    Pics, more to come.
    0xDEADBEEF, 02Duck, jdjones and 16 others like this.
  2. Jan 5, 2021 at 3:02 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Ohhh shit son! You're a parts finding, ass kickin genius
  3. Jan 5, 2021 at 3:03 PM
    Jowett
    Brian
    North Adams, MA
    I love scouring parts diagrams for upgrades!
    G8R_Taco, Junkhead and Skydvrr like this.
  4. Jan 5, 2021 at 3:04 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Is the plastic one off your truck? You're probably balls deep in your SC so it wasn't too bad to get to?
  5. Jan 5, 2021 at 3:06 PM
    Jowett
    Brian
    North Adams, MA
    Yes. The transmission is out, too, so easy access. Looks like a PITA from the top.
    Skydvrr likes this.
  6. Jan 5, 2021 at 3:14 PM
    YotaKid
    YotaKid Well-Known Member
    AZ
    2017 SR 4x4
    Shiny:eek:
    wahoobie likes this.
  7. Jan 5, 2021 at 3:16 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Oh yeah you're working on the trans too. Does the exploded view show transmission lines for AT?
  8. Jan 5, 2021 at 3:17 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Nice find!
    Junkhead likes this.
  9. Jan 5, 2021 at 4:01 PM
    Jowett
    Brian
    North Adams, MA
    Shows the parts, but not certain on exact hose path through the area. Ideally, someone needs to look.
    Traction and Skydvrr[QUOTED] like this.
  10. Jan 5, 2021 at 5:21 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Hopefully someone will chime in. If not I'll try to look
  11. Jan 5, 2021 at 5:33 PM
    GBR
    GBR Well-Known Member
    19 TRD OR
    Just curious what model this came off of?
  12. Jan 5, 2021 at 6:22 PM
    Jowett
    Brian
    North Adams, MA
    This comes from the Lexus LS and LC 500h, which are hybrids and use the 3.5L 8GR-FXS version of our engine. It has 13:1 pistons and exhaust gas recirculation... needless to say, things run a little hotter on this engine, and this aluminum part was likely installed to deal with that extra heat.
    Part #s
    16356-31080 Joint, water bypass $119.50
    16341-31030 Gasket x 2 $8.85
    Lexus may want a vin # in order to supply this part.
    Let's get it all mapped out... it isn't done until it's done.
    riggityj, 02Duck, CS_AR and 11 others like this.
  13. Jan 5, 2021 at 6:29 PM
    mysubiewasalemon
    mysubiewasalemon Well-Known Member
    What did you get the parts for
  14. Jan 5, 2021 at 6:39 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    I think he got them for his truck....
    ....I kid, I kid.
    TreeFortRichard and Junkhead like this.
  15. Jan 5, 2021 at 7:05 PM
    Jowett
    Brian
    North Adams, MA
    List prices added above.
    Junkhead and shakerhood like this.
  16. Jan 5, 2021 at 8:41 PM
    mysubiewasalemon
  17. Jan 6, 2021 at 6:55 AM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    It's the same for AT as MT, the bypass line goes to the heater core first. It's only after the heater core does the AT vary by adding the warmer before returning to the thermostat.
  18. Jan 26, 2021 at 3:01 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Any updates with this?
  19. Jan 26, 2021 at 3:29 PM
    Jowett
    Brian
    North Adams, MA
    I have several hoses ordered, so we'll see if there is something out there that will make this swap a little easier. Is your bypass in need of replacement?
  20. Feb 10, 2021 at 8:54 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    Mine is liveable right now, I'm just monitoring it as my coolant level is still in the middle but I definitely will need replacement in the future.
