Aluminum Sliders?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by g34rh34d, Feb 4, 2012.
  1. May 7, 2015 at 10:49 AM
    #61
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    This.
  2. May 7, 2015 at 10:50 AM
    #62
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    You're right. The original posting date is in a new spot on the new forum layout and my eye isn't used to looking for it yet.
  3. May 7, 2015 at 11:00 AM
    #63
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    You are correct, aluminum bumpers are made of thicker material, usually 1/4" plate vs 3/16" for steel but this does not make them as strong as a steel bumper. You can still use them as recovery points and winch with them but they will not take the same abuse a steel bumper will. Keep in mind when I say take the same abuse though I'm talking about things like driving straight into boulders and walls, the aluminum bumpers are still durable but steel is even stronger despite the thicker plate on aluminum.
    HDPE Sliders? Got any pics?
    EDIT: Just realized HDPE was probably a joke... you got me
  4. May 7, 2015 at 11:24 AM
    #64
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    HDPE Skids
  5. May 7, 2015 at 11:28 AM
    #65
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    HDPE :rofl:
    Why not Teflon :D
  6. May 7, 2015 at 12:17 PM
    #66
    OZ-T
    Peter North
    British Columbia
  7. May 7, 2015 at 12:17 PM
    #67
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    UHMW-PE is actually what most use. Especially under UTVs. Occasionally under rock buggies too. For trucks, since it flexes too much under hard point loads, its used with a structural tube structure or as sheeting under a traditional skids or sliders. I think the exception is gas tank skids where UHMW is fairly common.
  8. May 7, 2015 at 12:27 PM
    #68
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    I know, I've seen quite a few UTV's with them. I've looked into that HDPE skid for gas tanks before too and will probably go that direction at some point. I was laughing because we are talking about sliders, which have to be solid to protect the body from impact damage. Not a good use for HDPE.
    I actually know a company that carries sheets of HDPE and Teflon for use in machinery locally. I'm going to get the cost of both materials at several thicknesses and go for one of either of the two for my gas tank skid/
  9. May 7, 2015 at 12:36 PM
    #69
    plurpimpin
    PDX
    yeah I had a total brain fart there hahaha
  10. May 7, 2015 at 12:37 PM
    #70
    Lostsheep
    Lostsheep Well-Known Member
    NorCal
    2015 6spd 4x4 OR
    6112s and 5160 , Dakars , Superbumps x4 , u-bolt flip , All Pro Skids (hacked and raised) , 265/70R17 KO2s, SEMA wheels, couple of machined things here and there
    My thinking for light duty aluminum sliders is to just mount them to the body. :crapstorm:
    My TJ had body mounted sliders and those things were bomber. Hanging the weight of my Heep off of them always made me nervous but my body mounts never ripped out and the sliders protected the tub.
    WRT my Tacoma, I think one could easily pick up the factory nerf bar holes and then maybe also pick up the 9 holes that currently have rubber plugs in them. Ideally a nutsert could be put in there but even just using them as bumpers when the sliders see a vertical load would probably work good enough for light duty.
    ETA: Mcmaster has quite a few to choose from but here is one nutsert that looks pretty good. The holes in the rocker are aprox 14.75mm and I believe the sheetmetal is about the right range.
    http://www.mcmaster.com/#94020a399/=x2wy5c
    ETA2: These look even better, I'm gonna add some to my order today and see of they work http://www.mcmaster.com/#93495a431/=x2x1cd
  11. May 7, 2015 at 12:43 PM
    #71
    Lostsheep
    NorCal
    2015 6spd 4x4 OR
    I'm not talking about milling out skid plates, plates by there very nature should be made of plate and bent.
    The basic concept I have in my head is to make sliders out of barstock aluminum and machine the appropriate contour/profile lengthwise. An extrusion would probably be a better solution but that's outside of my fabrication abilities (machining is not).
  12. May 7, 2015 at 1:20 PM
    #72
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Not a joke. 1/2" hdpe with a steel frame under my Ford :eek:
  13. May 7, 2015 at 1:36 PM
    #73
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    So I'm wrong that aluminum and steel together form a battery because high carbon steel is more corrosion resistant than lower carbon steel? I'd suggest reading before replying in future..
    Also, why would you bother using a high carbon bolt when you plan on sleeving it anyway? It's not in contact with anything but the sleeve, so it will outlast the life of the truck 2 or 3 times over.
  14. May 7, 2015 at 1:40 PM
    #74
    plurpimpin
    PDX
    Yeah I realized I misread your first post, you said skids and I was already thinking sliders. :frusty: HDPE skids are badass, I've seen a few pics of guys builds with them, I've been eyeing up an HDPE gas take skid lately for my truck.
    ruggedT[QUOTED] likes this.
  15. May 7, 2015 at 1:44 PM
    #75
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Y
    That would be wrong. Not because of galvanic potentials, but because you still need an electrolyte to form a battery.
    PS: I'm just bugging you, we all know that even air can act as an electrolyte in some cases.
  16. May 7, 2015 at 1:47 PM
    #76
    WheelInTheSky
    G
    Jackson Hole
    Ok I'll rephrase. On this planet, anywhere the humidity is above 0% and you are not in a vacuum, aluminum and steel form a battery.
    Better?:p
  17. May 7, 2015 at 3:36 PM
    #77
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    No, your not wrong because "aluminum and steel together form a battery." They do. What I am trying to tell you is aluminum and stainless steel together make a more powerful "battery" to use your terminology. Don't put them in contact with each other in the presence of water and road salt. Stop telling people to do it. Because science. Look at the chart I posted for gawds sake. It isn't rocket surgery.
  18. May 7, 2015 at 7:20 PM
    #78
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Like almost everyone with aluminum skids and bumpers? Its a slow process for for sure but the deterioration is happening none the less.
  19. May 7, 2015 at 9:18 PM
    #79
    Lostsheep
    NorCal
    2015 6spd 4x4 OR
    They would be more durable and tuck up tighter to the body than the BS factory steps or any of the others I am familiar with.
    WRT other real sliders, they would be lighter, tuck up tighter, and I am a machinist by trade so I have the tools readily available. FWIW, I currently have BAMF sliders and while I have nothing against them, they are not really what I want. They add a lot of weight and hang lower than I care for. While this is a bit nit picky, I hate tube work hanging off all over the place, I prefer armor that blends with the body lines of the vehicle.
  20. May 7, 2015 at 9:55 PM
    #80
    OZ-T
    Peter North
    British Columbia
    Just get Avid bolt ons if you just want a tucked slider look without slider protection
