Amp installed now not voice command or call volume
Discussion in 'Audio & Video' started by Dank Donkeh Luvver, Dec 20, 2021.
  1. Dec 20, 2021 at 3:04 PM
    Dank Donkeh Luvver
    Dank Donkeh Luvver [OP] Well-Known Member
    Eric
    Maryland
    2020 TRD OR White 6MT
    OVTune/Coyoza, Eibach Pro Lift, Mobtown Sliders/Skid, Softopper, Martin Offroad Rack
    So I added an amp to my stock HU by using an LP7-2 LOC. Both the amp and the LOC are getting power from the battery. I used the ttunes harness to connect to the HU and to connect the amp back to the factory speaker connector.
    It works great for radio, xm, and bluetooth (music) however there is no volume on the voice command menu (when I push the button there isnt a beep or anything) and there is no sound from phone calls (they can hear me so the mic is working).
    I had seen a few posts about using a 2ch input on the amp to push the front speaker signal to all four doors and I went ahead and did that. Could that be the issue here?
  2. Dec 20, 2021 at 3:53 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    My assumption is that you’re getting your audio signal from the rear speakers and not the front.
    fade the radio all the way to the front and see what happens
  3. Dec 20, 2021 at 5:25 PM
    Dank Donkeh Luvver
    Eric
    Maryland
    I'll pull out the head unit tomorrow and double check all my wires. I think you might be right, because when I was checking the voltage output from the LOC at 100hz i was only able to get 0.75-ish volts with the gain maxed out, which seemed odd.
    I followed this for which wires and stuff - thread https://www.tacomaworld.com/threads/2020-key-amp-and-hideaway-installation-complete.658383/
    Initially I thought the LOC/amp were turning off, but I realized I can hear a little bit of output from the speakers even with the hu volume at zero which I'm pretty sure is the amp. I put the amp behind/under the hu so I can't check without pulling everything.
    Edit - I also followed your post #2 in this thread - https://www.tacomaworld.com/threads/2020-tacoma-sr5-non-jbl-wiring-diagram.656554/
    Will check tomorrow and get pics.
  4. Dec 21, 2021 at 4:42 AM
    Dank Donkeh Luvver
    Eric
    Maryland
    Yep you were spot on with the rear speakers. Fader to front and everything turns off. Glad I'm working from home today
