Any reason not to consider the TRD Pro wheels?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by greg8765, Jun 6, 2019.
  1. Jun 6, 2019 at 12:16 PM
    #41
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    I just bought RX350 retros for what’s probably less money and better output :cool:
    OP - you also just missed the sale of the decade a month or two ago for all TRD goodies. Bad timing :(
    tonered[QUOTED] likes this.
  2. Jun 6, 2019 at 12:19 PM
    #42
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I have been thinking about that also. But then, the stock lighting seems to work, esp after adjusting them just a bit. We'll see what drops and what happens over the next few years.
  3. Jun 6, 2019 at 12:24 PM
    #43
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    And the grill...wonder how many added the side bed stickers too?
  4. Jun 6, 2019 at 12:28 PM
    #44
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    I use chemical guys ez creme to polish, then just any wax each time i do the truck. That particular picture just had Meguiars Ultimate on it. I've used others with good luck as well. The key is to not let too much time pass as anything will eventually lose it's shedding ability.
    shakerhood likes this.
  5. Jun 6, 2019 at 12:39 PM
    #45
    Trah
    Trah Licensed Class C Driver...
    San Diego
    2017 Barcelona Red TRD Sport ACLB
    stuff and things...
    i think on the rims it helps distinguish from aftermarket clones...
  6. Jun 6, 2019 at 12:44 PM
    #46
    Aldo98229
    Aldo98229 Well-Known Member
    Aldo
    Bellingham, Washington
    2019 Tacoma TRD Off-Road
    Ridgeline seems to be the default punching bag on TW.
    Love it!
  7. Jun 6, 2019 at 12:53 PM
    #47
    ICU1
    ICU1 Well-Known Member
    I like the wheels coming on the 2020 TRD PRO. :crapstorm:
  8. Jun 6, 2019 at 12:54 PM
    #48
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    It’s marketing. Double dipping on people who want Pro wheels and those who *need* to have TRD stamped on everything.
    Inside of the wheels will have OEM stamping.
  9. Jun 6, 2019 at 12:57 PM
    #49
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Wrong.
    285's fit on the 16" Pro wheels, with minimal amount of heatgun work on the inner fender wells.
    Ran them for nearly 40k miles on stock suspension. No spacers anywhere. Cleared the UCA and CM just fine.
    rlx02 likes this.
  10. Jun 6, 2019 at 1:00 PM
    #50
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Sure you did.
    Toki and kakwvu like this.
  11. Jun 6, 2019 at 1:03 PM
    #51
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    Driving in a straight line.
    Plenty of folks run 285s on the 17” Pro wheels just fine. I’m pretty sure the 3rd Gen forum was founded on those wheels being paired with on it with 33” tires.
    16” Pro wheel width is within specs for 285s.
  12. Jun 6, 2019 at 1:20 PM
    #52
    Woodman500
    Woodman500 Well-Known Member
    Palmdale, Ca
    2018 Toyota Tacoma TRD Sport 4x4 DCLB Quicksand
    I have these on my Quicksand Taco with General AT2 tires. My only complaint is they don't balance very well. Everytime I have the tires rotated, they have to pull them off and balance them. Plus the weight are silver on a black wheel.
  13. Jun 6, 2019 at 1:32 PM
    #53
    greg8765
    greg8765 [OP] Well-Known Member
    Greg
    Utah
    2023 Tacoma TRD Off-Road
    Tuff Country Lift, Smart Cap, Tint, Pop & Lock, Door Sill Decals, Rooftop Tent
    not a freaking bad idea!
  14. Jun 6, 2019 at 1:38 PM
    #54
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Plenty of folks run 285s on the TRD Pro wheels... yes. But (again) >TECHNICALLY< they are too narrow for 285s (I should have specified for SOME 285s)
    Example... BF Goodrich says their 285s should be mounted on 7.5-9 inch wheels. The TRD Pro wheels are 7 inch... therefore you may experience problems getting them mounted because some shops will not mount a tire on a wheel that is less than/more than the manufacture recommended wheel size. Can it be done? Sure. But, not all shops will do it for you.
    kakwvu[QUOTED] likes this.
  15. Jun 6, 2019 at 1:39 PM
    #55
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
  16. Jun 6, 2019 at 1:46 PM
    #56
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    That’s only the 17” model, and I’m aware. I was also saying it can be done, but it’s outside of spec. Unlikely to have issue in most applications, but worth noting that if you blow a bead or something .. well, ya rolled the dice.
  17. Jun 6, 2019 at 1:54 PM
    #57
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    No... that's on the 16" model BFG as well.
  18. Jun 6, 2019 at 1:56 PM
    #58
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    I’m talking wheel. You’re talking tire. The TRD Pro wheels are 16x7.5 or 17x7.
  19. Jun 6, 2019 at 1:56 PM
    #59
    STrooper
    STrooper For HIS glory!
    Jack
    NC
    2018 TRD Sport QuickSand / 2020 TRD Sport Cement!
    Cause they are 16's and not 17's, also. Lol
  20. Jun 6, 2019 at 1:57 PM
    #60
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    16’s don’t fit on a 4R
